Aye aye
wull
Has thanked: 965 times
Been thanked: 1827 times
Aye aye
Post by wull »
As i said on the Friday post I had a little accident at work a week ago today, in fact a week ago right now I was in A&E, maybe the eye clinic at this point. To say I am a little bit fucked off is an understatement, completely self inflicted, nobody to blame but myself, just a lapse in concentration.
The day itself was a bit of a fuck up from the word go with regards to the weather and the boss being all over the shop with delegating jobs, chopping and changing his mind which was throwing me off a little, so many things in my mind needing doing and not being able to get them done in the time frame that I would like.
I was cutting the paddocks on the Kubota BX2350 when I came by the workshop and seen one of the workers who was out in the Massey Ferguson 5420 tractor cutting large areas, it had the front mounted TriMax Stealth fitted and the rear tow along TriMax Pagasus. He was at the workshop because he was trying to replace a spring which had came loose, it’s a very heavy duty spring that solely aids in the cutting deck lowering and raising, it works perfectly fine when it’s not in place but I always replace it when it comes loose. I’ve replaced it many times including other springs through my working life and have specific tools for doing the job and always do it in such a way that it never puts myself in danger, except for this time.
For whatever reason I did it differently this time, if anything were to go wrong I would potentially be in the way, another mistake was I was using the two piece spring hook tool that I have, it would not have been my choice but it was the one they had grabbed from my tool box and were using when I had arrived, so stupidly I used this tool instead of my usual go to one piece. Another stupid mistake was not wearing eye protection, I started to force the spring back into place when it all went wrong, in a split second there was an almighty force to my face, I went down to the ground but I was not knocked out, I wasn’t even dazed if I’m being honest, I was always fully aware of what was going on and the immediate pain was quite bad. My initial thought and worry was how bad is this going to be, how bad is my eye going to be and whilst I’ll was lying on the ground I could see the handle of the tool I was using just laying there, the tool had failed. It had clearly failed whilst trying to get the spring in place leading to it all going horribly wrong.
I couldn’t open my eye initially, there was already brushing to the eye, eye lid and surrounding area, my cheekbone had taken a fair impact as well. I was taken to A&E where the eye was inspected initially, there was bleeding within the eye and a scratch to some degree on the eye itself. At this stage I couldn’t really see, initially I couldn’t see then it got to the point where I could just see shapes, it was very cloudy, milky looking. I was told this was due to the blood build up. I was then moved to the eye clinic within the hospital where they tried to get pictures of my retina, they were struggling due to the blood but they were positive they could see enough of it to determine that there were no issues with the retina.
I was discharged 5 hours later with 3 different drops to take, I was asked to go back two days later for a check up. My sight gradually got better out the left eye but it was still blurry, at the check up they were able to see the retina better and confirmed it was absolutely fine. As for the blurriness they told me that was still due to some blood within the eye and the pupil being dilated from one of the drops, they are convinced that it should go back to normal, the only concern would be pressure and that I might need drops for that in the future.
So we’re now one week on and the sight out the left eye is much better but it’s still blurry, if I cover my right eye and look at words it’s blurred, what concerns me is I haven’t had any drops for a few days now as I was told to stop them and my pupil is still dilated, I have a sneaky feeling that it won’t return to normal and I will require glasses but I suppose I’ll have to be patient and see. I have to go back in 6 weeks for a check up so I’ll know more then but I’m hoping the pupil will go down and the blurriness goes away.
I’m signed off until next week, I’ll be going back on Thursday. I have a few other jobs to do just now at the golf course to keep me going, and at an estate where I look after the machinery. I was strictly told because they know what I’m like that I can’t go in and work when I’m signed off, I was at the racing on Sunday there purely as a spectator, it was good experiencing it from that point of view, but I can’t wait to be back at it.
Has thanked: 7508 times
Been thanked: 5858 times
Re: Aye aye
Hope it sorts out ok.
ogri
Has thanked: 1255 times
Been thanked: 334 times
Re: Aye aye
Post by ogri »
Hope it turns out all good.
Had a week in hospital after priming a tank pump and getting sprayed in the eye by some plating solution, 10 percent sulphuric plus various other chemicals. Waiting in a&e for 1/2 hour before they washed my eye didnt help. Main reason i need glasses now tbh.
Has thanked: 20505 times
Been thanked: 13424 times
Re: Aye aye
Eyes are amazing things and i bet it does come back, albeit in time! :thumbup:
Good luck.
Has thanked: 756 times
Been thanked: 3160 times
Re: Aye aye
Poor obs, oh...........
Has thanked: 7895 times
Been thanked: 5575 times
Re: Aye aye
Hope you get back to 20/20 Wull...or pretty close. It'll take time for that blood to clear but AFAIK the pupil should stop dilating. Even if you have to wear specs 🤓 😎🥸 it's a better result than it could have been!!
Has thanked: 1074 times
Been thanked: 5718 times
Re: Aye aye
Eyes take a long time to settle down. Be patient.
GWS.
Has thanked: 13059 times
Been thanked: 14126 times
Re: Aye aye
We've all done it. A moment's inattention,then repent at leisure.
The brain is great at compensating. As an apprentice I took a bit of hot,sharp swarf to my left eye which left my vision ever so slightly blurred in that eye. I don't even notice it now and at nearly 71 I still don't use glasses for reading.
Think positive Wull,you'll get there man. :thumbup:
Has thanked: 3598 times
Been thanked: 2457 times
Re: Aye aye
GWS Wull.
Has thanked: 10803 times
Been thanked: 3906 times
Re: Aye aye
Fingers crossed for you. Hopefully it'll all sort itself out.
Trinity765
Has thanked: 3102 times
Re: Aye aye
Post by Trinity765 »
That was as like reading an episode of Casualty and I Googled the farm machinery you mentioned.
Really sorry that you're hurt and hope you make a full recovery very soon :wub:
Has thanked: 2186 times
Been thanked: 2540 times
Re: Aye aye
Might want to remove the "nobody to blame...." part in case of insurance claim/payout
Ian
Has thanked: 1309 times
Been thanked: 556 times
Re: Aye aye
Post by Ian »
Fuck! GWS, I hope it recovers ok
Has thanked: 2784 times
Been thanked: 3430 times
Re: Aye aye
It happens, whether it's complacency or short cuts, we've all done it. My mate worked in a wood yard. Been doing it years, then one day he chopped his thumb off. Got a bit casual he said, his own fault.
Think yourself very lucky I say, GWS. 👍
Has thanked: 685 times
Been thanked: 1961 times
Re: Aye aye
I suffer or suffered Iritis. I say suffered as it not flared up for a good eight years. One of the drops i took also made the eye dilated and if its any consolation it would take four or five days to start looking normal after finishing the drops . Not that i ever remember getting a smack on the eye but it is a reason why it could flayer up.
https://www.mayoclinic.org/diseases-con ... c-20354961
Has thanked: 623 times
Been thanked: 9345 times
Re: Aye aye
It's a shame you're getting better, cos I've heard that chicks dig eye patches and you could have formed your dream Dr Hook tribute band :p
Has thanked: 2901 times
Been thanked: 2473 times
Re: Aye aye
GWS Wull.
Has thanked: 5853 times
Been thanked: 3529 times
Re: Aye aye
That's crap news, hope it sorts itself out.
Sunny
Has thanked: 3449 times
Been thanked: 1514 times
Re: Aye aye
Post by Sunny »
Oof. Glad to hear it's improved, and hope it continues to! Take it easy in the meantime mate.
katana
Has thanked: 77 times
Been thanked: 54 times
Re: Aye aye
Post by katana »
wull wrote: Wed Jun 10, 2026 2:09 pm As i said on the Friday post I had a little accident at work a week ago today, in fact a week ago right now I was in A&E, maybe the eye clinic at this point. To say I am a little bit fucked off is an understatement, completely self inflicted, nobody to blame but myself, just a lapse in concentration.
Not to be rude, go to an optometrist and get checked out.
Something you all should do regularly.
In a side note, having had a scratched cornea, don't ask if you get a free Labrador. Those people do find it funny.
