Suspension Help.
Has thanked: 12607 times
Been thanked: 8537 times
Suspension Help.
When I was racing and instructing I always had free suspension set up so never really learned much.
I sort of know the theory, but not the practice.
The suspension on the GSXR has always been perfect, but recently I can feel every bump on the rear suspension.
So should I make it a bit softer? Harder?
Adjust compression or rebound?
It still handles amazingly well so don't want to bugger it up as I'm at Portimao next week
Ta. :)
crust
Has thanked: 959 times
Been thanked: 713 times
Re: Suspension Help.
Post by crust »
Eat less pies.
Wear an extra pair of skiddies.
HTH
crust wrote: Wed Jun 03, 2026 12:21 pm Eat less pies.
HTH
Fewer darling, fewer 😉
Set the sag on the bike for your weight. Then you can toosh about with damping. Loads of videos on the Tube from the likes of Dave Moss and others. Having a mate to hand is useful,or you can buy a Motool Slacker and do it on your own.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
Is it the same as it ever was but you've become more sensitive to bumps, or has it deteriorated over time?
If it's deteriorated over time, then considering the bike's age, track use, and hot ambient temperatures, the damping oil could have gone bad or the pressurising gas may have escaped. If that's the case you could try to mask it by turning any damping screw in just a little, but it won't play well when you ride it extra hard so it might just be time to get it serviced or replaced.
Could also be that the linkages need a service. If the bearings seize, they prevent the shock from absorbing small impacts.
Is this just the universe telling you it's time for a brand new bike? Might be the longest you ever kept a gsxr.
Check the tyre pressures first
A_morti
Post by A_morti »
Yorick wrote: Wed Jun 03, 2026 10:55 am When I was racing and instructing I always had free suspension set up so never really learned much.
Ta. :)
Did it play nicely?
A_morti wrote: Fri Jun 12, 2026 7:00 pm
Ta. :)
Did it play nicely?
Aha. Gotcha.
Yes, it's fine on track. Just road bumps upset it a bit.
The suspension guy had a fiddle both ends but it didn't change much on track today.
But might help on road. I'll report back when I'm home
Has thanked: 19573 times
Been thanked: 4950 times
Ask the suspension guy at track about the road stuff. If yr seeing him to get stuff checked for track, worth an ask for when you get home.
Might not be anything you can do, and if you’ve lost weight in yr butt, maybe you’ve just lost some natural padding (wanted to use a suspension word but have zero idea if it’s damping or rebound 😇😇)
The guy is there for track but pretty sure he’ll be able to help for road too 👍🏻👍🏻
Noggin wrote: Sat Jun 13, 2026 8:47 am Ask the suspension guy at track about the road stuff. If yr seeing him to get stuff checked for track, worth an ask for when you get home.
Every time I've had a bike set up for track, it's been perfect on road.
Not too much difference.
Yorick wrote: Sat Jun 13, 2026 9:17 am
I found that, but I am, was, a lot slower than you, so didn't want to assume :lol: :lol: :lol:
mboy
Has thanked: 854 times
Been thanked: 696 times
Post by mboy »
Two words...
Dave Moss...
https://davemosstuning.com/free-vidoes/ ... 0-dial-in/
Really knows his stuff... Another ex-pat northerner like yourself too... 👍🏻
Yorick wrote: Fri Jun 12, 2026 7:20 pm
Ta. :)
Did it play nicely?
Aha. Gotcha.
The bike still feels slow and heavy so paying the proper suspension man today.
He's got all the gear and measures everything. Not just twirling a screwdriver.
Getting tired after 5 laps as it's slow and ponderous.
Didn't pay the F.E. lad as he made it worse
Hopefully this lad can improve stuff :)
Well. Just spent 75€ at the suspension dude.
Transformed it. So much lighter feel and balance.
Only did 1 session but my arms didn't hurt after.
Previously 6 laps and I'd to pull in.
It's so much lighter to handle.
But biggest thing was braking. So much more stable. Like a new bike
At end of straight I now see it was braking early to avoid the effort.
Can probably go another 50m tmrw so hope to crack the 180 :D
He spent 40 minutes buggering about. Sorry to be a bit technical ;)
Had it up on ramps to set static and rider sag.
Also he knew the Showa forks well, and obviously knew how to set them up for silly track braking.
It's a transformation.
He told me not to go silly at first, but get used to the new handling and agility.
Woo hoo !!!!@
