Windows Oddity
Has thanked: 713 times
Been thanked: 2036 times
Windows Oddity
Has anyone seen, came across this before? Every now and then this black box appears and goes up and down with the courser. Only way to stop it is a reboot. This is a monitor plugged into a laptop via HDMI. Makes no difference if both screens are on or using one, nor disconnecting the monitor and just use the laptop one. Reason the huge courser is the owner is partly sighted so needs the larger screen. Not sure if this is a nasty bug or not. He says there is no pattering to when it starts. I was thinking its a nasty attached to his courser (Edge) so left him with Brave for the time being.
Has thanked: 2556 times
Been thanked: 4166 times
Re: Windows Oddity
I take it that when the problem occurs, the black (lower) part of the screen image goes up and down following the movement of the cursor? I've never seen that before, but would suggest buying a new, decent quality HDMI lead to see if that is causing the weird sh1t...
Re: Windows Oddity
Yes but only up and down. It is a cheap Tesco HDMI but been fine for the past three month but worth a try.
ogri
Has thanked: 1274 times
Been thanked: 337 times
Re: Windows Oddity
Post by ogri »
windows + oddity = normal procedure :)
dern
Has thanked: 1183 times
Been thanked: 2277 times
Re: Windows Oddity
Post by dern »
Felix wrote: Wed May 06, 2026 6:22 pm Has anyone seen, came across this before? Every now and then this black box appears and goes up and down with the courser. Only way to stop it is a reboot. This is a monitor plugged into a laptop via HDMI. Makes no difference if both screens are on or using one, nor disconnecting the monitor and just use the laptop one. Reason the huge courser is the owner is partly sighted so needs the larger screen. Not sure if this is a nasty bug or not. He says there is no pattering to when it starts. I was thinking its a nasty attached to his courser (Edge) so left him with Brave for the time being.
Has your monitor got a PBP (or PIP) mode? This is where it displays 2 inputs side by side (or on top of each other). Check if you have that mode and you haven't accidentally enabled it.
This will be a setting in the monitor menu, not in windows.
Has thanked: 781 times
Been thanked: 1072 times
Re: Windows Oddity
I think the cursor is causing it. I find accessibility options can start and do odd things when I don't want them to, is the cursor setting a windows one or something downloaded?
Re: Windows Oddity
dern wrote: Thu May 07, 2026 11:49 am
Disconnect the monitor the issue is staying in the laptop
Re: Windows Oddity
Mussels wrote: Thu May 07, 2026 6:56 pm I think the cursor is causing it. I find accessibility options can start and do odd things when I don't want them to, is the cursor setting a windows one or something downloaded?
Windows but cant turn it off as he wont see the thing.
