Honda VT250F - Buzz Buzz!
Soupdragon
- Has thanked: 46 times
- Been thanked: 70 times
Bought this little 1983 baby V-twin yesterday - DOHC, 4 VPC, liquid cooled... but sadly not a Ducati!
Rising fuel prices and a major job coming up on my car means I've decided to buy a bike for the summer to save money. Not sure how I got it passed Mrs Soupdragon, but result!!
It's remarkable original, 20k which I believe is true and is really tidy. Rode it from Manchester to Norwich, 230mls on VERY old Avon Roadrunners which was interesting, especially with a 16in front. Certainly kept me alert and the squid's beak twitching.
And so to my first question - it seems the only 'premium' tyres still available are BT46s. Are they any good? Never ridden on them so some real world experience would be great please.
- WhatsApp Image 2026-05-02 at 12.13.33.jpeg (259.94 KiB) Viewed 1413 times
- Has thanked: 624 times
- Been thanked: 9377 times
Re: Honda VT250F - Buzz Buzz!
I've seen people racing and putting in respectable lap times on BT46s in Earlystocks.
Keep an eye on that inboard front brake, they've got a bit of a bad reputation.
Soupdragon
Ha-ha, yes, that's first on my job list. It would be unfair to call it a brake really. Caliper seems fine so new braided hose and pads.KungFooBob wrote: Wed May 06, 2026 9:11 am I've seen people racing and putting in respectable lap times on BT46s in Earlystocks.
The later jdm only models looked a lot like Ducati Monsters.
- images.jpeg (31.4 KiB) Viewed 1400 times
- Has thanked: 5889 times
- Been thanked: 3536 times
No idea on BT46s, but happy new bike day. That looks in very decent nick.
A_morti
- Has thanked: 404 times
- Been thanked: 809 times
Whatever else you get, I'd skip Avons even if they're still available. They're quite a steep profile which can make cornering feel like the bike is falling over. Fine for modern sport bikes maybe, but sketchy AF on the classic bikes the tyres are made for.
The BT46 replaced the venerable BT45 some while ago. Those were the go-to for daily-use bikes for many many years. Stable steering, good performance including wet and cold weather, long life. Their only issue was feathering of the tread blocks, but it was rarely a big deal. I can't imagine Bridgestone would have messed with the formula too much.
- Been thanked: 14167 times
Happy new Homda day.
I run Avon Roadriders and Bridgestone BT46s on my two H1s. Much easier to run out of ground clearance than grip.
If I had to choose,I'd pick the Roadriders,but in all truth it won't actually matter a damn.
- Has thanked: 10836 times
- Been thanked: 3916 times
I used to run BT45s on the Mirths (ZR550 Zephyrs): more grip than it ever needed!A_morti wrote: Wed May 06, 2026 12:14 pm Whatever else you get, I'd skip Avons even if they're still available. They're quite a steep profile which can make cornering feel like the bike is falling over. Fine for modern sport bikes maybe, but sketchy AF on the classic bikes the tyres are made for.
Soupdragon
Thanks chaps, appreciated.......
I can't get Avons even if I wanted them as, sadly, the company stopped all GB production a few years ago. I think they make a few in France but not in the fitment I need. The profile on the existing Road Runners isn't bad, definitely not triangulated at the front, just very old with plenty of cracks in the sidewalls.
I've never particularly liked Bridgestones (though not really sure what I base that on) but will give the 46s a go I think. All the other makes offering the correct fitment are Die Yungs and similar.
Had quite a productive day so far - sorted out the static sag front and rear, put a little air in the forks, put the chain in a cleaning tank and re-greased it, sorted the broken trip, adjusted the pilots, gapped the plugs and repaired a small crack in a side panel. It's been a pleasure so far because it's clear the bike has been loved in its past and everything has come apart easily.
I'm not really a Jap bike bloke but I think I'm going to get on just fine with this little VT.
- Has thanked: 20617 times
- Been thanked: 13507 times
I used to run BT46s on my Honda Bros. Good tyres but the front tread suffers from cupping when it gets low, but its time to change them then anyway.
Soupdragon wrote: Wed May 06, 2026 1:57 pm Thanks chaps, appreciated.......
I'm not really a Jap bike bloke but I think I'm going to get on just fine with this little VT.![]()
I hate Bridgestones with a vengeance....... apart from the BT45.
- Has thanked: 602 times
- Been thanked: 4525 times
Change the oil in about twice as often as Honda recommend, they're hard on oil as they spend a lot of time flat out, the brakes are a really bad idea, changing the pads is time consuming compared to normal discs. If it were mine I'd investigate fitting 17" wheels.
- MyLittleStudPony
- Has thanked: 820 times
- Been thanked: 583 times
What a lovely little bike.
I'd put new tyres on and not worry too much what make they are.
- ogri
- Has thanked: 1258 times
- Been thanked: 337 times
It is a Honda, check the cam seat/bearings for wear
- Pirahna
- Has thanked: 2942 times
- Been thanked: 1724 times
The BT56 has been around for quite some time, I used to use them on my Fireblade. They're a sports tyre and very good, on your 250 they'll give all the front grip you'll ever need. I used to get 10k plus miles out of one on the Blade.
46 not 56Pirahna wrote: Fri May 08, 2026 8:17 pm The BT56 has been around for quite some time, I used to use them on my Fireblade. They're a sports tyre and very good, on your 250 they'll give all the front grip you'll ever need. I used to get 10k plus miles out of one on the Blade.
They've not made BT56's for 20 years... I used to run them (and the SS version) on my Fireblade 25 years ago.
Anyway, Michelin HiSports TX15 and TX25 FTW!
TX11 was betterKungFooBob wrote: Fri May 08, 2026 8:22 pm46 not 56Pirahna wrote: Fri May 08, 2026 8:17 pm The BT56 has been around for quite some time, I used to use them on my Fireblade. They're a sports tyre and very good, on your 250 they'll give all the front grip you'll ever need. I used to get 10k plus miles out of one on the Blade.
Soupdragon
Productive couple of hours yesterday.... The pilot circuits were holding up so I pulled the carbs off and gave everything a clean. In addition to the semi-blocked pilots, the butterflies were out of synch. All fine now and running loads better.
Next will be an oil/filter change and trying to source lighter springs for the carb diaphragms. I don't think Dynojet ever made a kit for this bike so I'll have to improvise
All good fun though and it's a sweet little bike, I quite like it.
Soupdragon
Further progress on the VT....
Fitted a braided line to the front brake. I think at 43 years old, the original was a bit passed its best! I've also reversed the gear change as that's what I'm used (and it's better anyway for loads of reasons) and machined new bearing inserts to remove the slop in the linkage. Last job may not work well as the engine has so little torque, but I've put a slightly smaller rear sprocket on to make cruising speed a bit more relaxed. It may not like it though as 6th was already an overdrive. We'll see anyway.
Definitely want to find some lighter springs for the carb slides. Any ideas where I could find some?
You'd need to measure up to be sure.
https://amalcarb.co.uk/mk-i-concentric- ... rings.html
