Fantic Caballero 500 and Kove 450 Rally kickstart mod
Dave G
Has thanked: 88 times
Been thanked: 71 times
Post by Dave G »
Here are details of the kickstart mod that I did on my Fantic Caballero 500. The mod is applicable to all bikes that use the Zongshen NC450 and NC450S engines which includes the Kove 450 Rally. Any questions please ask.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Re: Fantic Caballero 500 and Kove 450 Rally kickstart mod
Post by A_morti »
Very cool mod.
It looks like the engine was designed with a kickstart in mind, perhaps due to its rally intent? Or is it like many other Chinese engines, and actually a clone of an old Japanese bike which might have had a kicker?
Were the parts (lever and gear) available from an OEM?
Has thanked: 12604 times
Been thanked: 8535 times
Why did you feel the need to add a kick-start?
Dave G
Post by Dave G »
Just because I noticed that the engine case had provision for a kickstarter and I also thought it would be good to have backup setup in case the battery died on me. Parts are also dirt cheap from China
Dave G
Post by Dave G »
A_morti wrote: Thu Jan 29, 2026 12:35 pm Very cool mod.
Some bikes that the NC250 engine is fitted to do have a kickstarter fitted as standard and the NC450/NC450S uses alot of the NC250 parts. The kickstart cluster and lever are easily obtainable but the other parts took nearly a year to arrive directly from Zongshen so I had to improvise for a while (see pdf).
Dave G wrote: Thu Jan 29, 2026 12:52 pm Just because I noticed that the engine case had provision for a kickstarter and I also thought it would be good to have backup setup in case the battery died on me. Parts are also dirt cheap from China
None of my last 3 enduro bikes had kick-start and had no problems ever.
If any failed it would be easy to bump them.
But do admire your work.
Dave G
Post by Dave G »
Yorick wrote: Thu Jan 29, 2026 1:14 pm
I'm too ancient to bump start. Just fancied a new project really if I'm honest.
I kinda like kickstarting bikes.
Nice work btw.
Dave G
Post by Dave G »
Oldschool stuff, like the look and lever shines up nicely,
Has thanked: 8034 times
Been thanked: 5692 times
Dave G wrote: Thu Jan 29, 2026 2:09 pm
What more reason does a chap need eh? 'Because I can' usually works for me. :thumbup:
Dave G
Post by Dave G »
Count Steer wrote: Thu Jan 29, 2026 3:16 pm
Anything to do with Bikes beats DIY!.
Dave G
Post by Dave G »
Share permissions changed, hope that the PDF is now accessible!
Has thanked: 24 times
Been thanked: 355 times
Post by ..... »
Doesthe gear engage off the centre of the clutch bsketoroff the outer teeth had all thinner teeth shear off ahusky610
Dave G
Post by Dave G »
Yes it does, here's a pic showing rear of clutch basket.
basket rear.jpg (82.22 KiB) Viewed 1462 times
