Weber BBQ, not staying alight.
Has thanked: 5451 times
Been thanked: 13087 times
Got a BBQ we've used loads now over the years, but recently it's started losing it's light. 50% goes out, or 100% goes out... then a different part.
I've swapped the regulator and hose which i thought fixed the issue, but it's now come back.
The gas is delivered through this.
I've checked to see if any of the holes are clogged up, but seem OK...
Any other things i'm missing ?
Has thanked: 143 times
Been thanked: 497 times
Re: Weber BBQ, not staying alight.
Post by Silly Car »
Mine does that every now and again, I’ve found cleaning that part with a wire brush helps.
Has thanked: 218 times
Been thanked: 689 times
We have one ( not webber) that wont staylit...its a bad contact in the batteryboxi thonk. I just put a clamp on the control knob which over rides the ff device.
Watching that about 5:20 in, it's a pretty simple swap.
https://www.ebay.co.uk/itm/Weber-Q200-Q ... 2508156715
It's only a cheap part, i'll look for one in the UK.
