Page 1 of 1
Changing a fixed shed window to one that can open
Posted: Sun Mar 02, 2025 11:55 am
by formula400
As above really, I think it would be good to allow some air in to the shed at time’s.
From what I can tell it’s a bit of plastic held in my a tiny bit of silicon and some small wooden battons.
How would I make it so I can open and close it??
Cheers
Re: Changing a fixed shed window to one that can open
Posted: Sun Mar 02, 2025 1:18 pm
You could see what kind/size of glass louvres are available for greenhouses then make the hole the right size to fit. IIRC (without going out to look
) you just screw the mechanism on each side and slide the glass into the slots so, in theory, provided you can get the glass slats cut to size you can make 'em fit just about anything.
Otherwise you could get someone to make you a window to drop in and secure. The double glazing folk seem to be able to get any size made up to fit.
Posted: Sun Mar 02, 2025 6:57 pm
by ChrisW
Perspex pane? Drill some holes in it and make a flap to cover it when you want to.
Posted: Sun Mar 02, 2025 7:21 pm
by formula400
ChrisW wrote: Sun Mar 02, 2025 6:57 pm
What kind of flap??
Posted: Sun Mar 02, 2025 8:08 pm
by ZRX61
formula400 wrote: Sun Mar 02, 2025 7:21 pm
What kind of flap??
Another piece of perspex that slides side to side in a channel, kinda like this:
- options-ventilation-window.jpg (32.89 KiB) Viewed 1505 times
Posted: Sun Mar 02, 2025 8:09 pm
What kind of flap??
External hinged piece of wood? Pref made out of the same stuff as the shed for the aesthetics of it. Hinge at the top and a prop to hold it up when open. (With a hasp and padlock if you want security when closed, although it looks like only a small thief could get in).
Posted: Sun Mar 02, 2025 8:10 pm
by Rockburner
What kind of flap??
Phnaaar.
He said flap.
Posted: Sun Mar 02, 2025 8:11 pm
What kind of flap??
Piss.
by ZRX61
or drill a hole in the wall for a reversible bathroom fart fan..
Posted: Sat Mar 08, 2025 5:01 pm
by formula400
ZRX61 wrote: Sun Mar 02, 2025 8:08 pm
What kind of flap??
Another piece of perspex that slides side to side in a channel, kinda like this:options-ventilation-window.jpg
That’s cool, where can I order it?
Posted: Sat Mar 08, 2025 5:06 pm
by formula400
I’ve removed 2 panels from the windows at either end, hoping that will create some air flow.
Water/condensation seems to be forming on the center roof, quite a bit to be fair since completing the insulation.
Hoping the windows will sort that.
I’ll probably order some Perspex to fit the window and either fit a hinge or just leave them loose until I can work out how to fit something
The windows are too narrow for a person to get though
Posted: Sat Mar 08, 2025 9:13 pm
by ZRX61
formula400 wrote: Sat Mar 08, 2025 5:01 pm
That one is intended for aircraft so comes with aviation pricing that would make your eyes bleed...
Posted: Sat Mar 08, 2025 9:16 pm
When it's all dry you could give the areas that are getting the condensation a coat of polyurethane sealant or some such. Won't stop the condensation but should stop the staining. I'm guessing that the area you've photo'd get the coldest.
Ventilation + air movement is the answer. (Or a dehumidifier).
For ~ £8 you can get a digital humidity meter with max and min levels from Amazon. For ~£12 you can get the Blutooth version so you can monitor the humidity from indoors. Supposed to work at 80m distance but I'm not sure I believe it.
Posted: Sun Mar 09, 2025 12:03 am
by demographic
Seems hard work to replace the window when you can use a holecutter/jigsaw to put a hole in the timber wall and just fire a bit of placky pipe and a vent in there.
Maybe a lecky Expelair like ZRX suggested.
Posted: Sun Mar 09, 2025 7:11 am
by formula400
ZRX61 wrote: Sat Mar 08, 2025 9:13 pm
Good job I need 2
Posted: Sun Mar 09, 2025 7:13 am
by formula400
Posted: Sun Mar 09, 2025 8:14 am
On the subject of damp, in a fit of 'clickyitis' I bought one of these for the kitchen.
https://www.lakeland.co.uk/46634/lakela ... humidifier
It's a compact electric dehumidifier with a 1 litre capacity and can pull 250ml a day out of the air. £35.
It's got to be better than those tubs of hygroscopic crystals. Probably not man enough for a whole kitchen but might work in localised condensation spots like a window ledge. (I've got a particular problem in that above one bit of kitchen ceiling is a girder in the loft which gets v cold - I'm going to lag it - and so I get a line of condensation on the ceiling when it's cold out and there's a lot going on on the hob. The 1 litre jobbie can sit on top of a cupboard near the problem).
I'm contemplating getting a couple more.
