They're all out to get you!
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
off to work yesterday at 0530, admittedly i was making 'progress', but along a dead straight bit of road, some oncoming numpty thought it would be a good idea to overtake into my path.
A knee/mirror interface occurred after I put it into the gutter to avoid the twat.
Apart from me going slower...any advice?
Has thanked: 7525 times
Been thanked: 5862 times
Re: They're all out to get you!
First off: glad you didn't get dreaded :)
Guessing at numbers, if the oncoming car and yourself were both a tad over the limit (*cough*) ...
... Say a combined closing speed of around 160 mph, that's the gap closing at over 70 metres each second.
Again, plucking numbers, if the oncoming driver was passing the slower car at 30 mph, that's 13 metres each second.
Starting from a two second following distance, I have no idea how long (time and distance ) it would take a driver to check it's clear, accelerate, then pass and pull back in. But, using a technical term, it's a farkin long way :)
From that distance, the driver would have struggled to see you, you were just a dot in the far distance. Worse still, because you were on a straight line head-on approach, there would have been little or no movement against the background.
What could you have done?
- Seeing the slower car, expect to following car to move out.
- If there's any hint, give a good long flash of full beam.
- Weave within your lane.
Sadlonelygit
Hmmm
If they couldn't see a modern headlight against a black background coming towards them from @ 300m, perhaps an eyetest might be in order.
As for judging the speed of the oncoming traffic, it was 0530, and drizzling and very dark.
Glad my trousers have knee armour!
I appreciate drivers make mistakes, but when its my sphincter gripping the seat cover, the milk of human kindness gets thrown out.
Sadlonelygit wrote: Sat Dec 14, 2024 9:11 pm If they couldn't see a modern headlight against a black background coming towards them from @ 300m, perhaps an eyetest might be in order.
It's probably near impossible to judge the speed of a approaching single headlamp at 300 metres.
The other driver might have made a mistake. But you chose to help set it up.
And eye test? I helped run eyetests on 85 people, almost all were drivers. We referred 12 to opticians.
Been thanked: 1224 times
If you know about you going slower, you can advise yourself.
Has thanked: 695 times
Been thanked: 1982 times
For all he knew at dark o'clock that could have been another car approaching with a fucked headlamp what would have been messy.
Horse wrote: Sat Dec 14, 2024 8:43 pm Say a combined closing speed of around 160 mph,
AKA "four seconds to impact".
Vehicles move way faster than you actually realise and humans are AWFUL at judging the distance to a point light source.
Mr. Dazzle wrote: Tue Dec 24, 2024 12:59 pm
I've posted several times about 'IPV' crashes.
These are trucks used to stop vehicles before they plough into road workers.
Just on the English major roads network, 30-40 of these are hit every year. Despite massive signs, flashing lights, etc.
Before
After
Has thanked: 2801 times
Been thanked: 3462 times
Too many modern cars using touchscreen for basic operations, Telsa being the worst. Baffles me how they get past scrutineering. 🤷🏻‍♂️
