Helmet and gloves
Helmet and gloves
Hi
I'm looking to get myself a helmet - where do I start?
Can you buy online (the local shops do not appear to sell many.. and i'm not sure if you can 'try before you buy now anyway?
I have a jacket but need gloves - again advice
How do i know my size? fit etc?!
Thanks
Thanks
- Has thanked: 253 times
- Been thanked: 328 times
Re: Helmet and gloves
Buying a helmet - first and foremost buy one that fits.
Sounds obvious really, but a badly fitting helmet's not very sensible. If you can try on as many different makes and styles as possible. Whether you then buy from the shop or online is between you and your conscience.
- Has thanked: 6020 times
- Been thanked: 4995 times
- Has thanked: 5408 times
- Been thanked: 12939 times
Sportsbikeshop.com
Buy loads, try loads, free returns
Sizes are in cm around your head, may help to have someone with a bendy tape measure
And you need to know what a good fit is!
A new lid will be snug, to say the least. But you don't want it so tight that it presses on your forehead and, after an hour riding, gives you a headache.
But the comfort foam will compress slightly with use.
Not everyone agrees with it, but www.sharp.co.uk is worth checking.
Do you wear glasses or shades? Make sure you can get them inside.
For gloves, will you be riding in wet and cold weather? If so, get waterproof insulated gloves. Then get an unlined set for next summer.
Top tip: if your gloves are wet don't, out of force of habit, leave them tucked inside your lid all day as it will smell like a wet dog for three days.
Pm arrived.
- chutzpah
- Has thanked: 21 times
- Been thanked: 96 times
As it's your first helmet, I really recommend getting to a physical shop and getting them to check it it.
Our local Helmet City is brilliant for helpful, no pressure sales.
- chutzpah
Just checked your previous posts and this store shouldn't be a millions miles from you
https://www.helmetcity.co.uk/helmet-cit ... eld-surrey
It's not the one we've used but I can't believe the experience there would be much different.
- Bigyin
- Has thanked: 1405 times
- Been thanked: 2653 times
Buy a helmet that fits YOUR HEAD and dont be drawn in by brand ..... If you go to a shop wear it for 15 minutes walking about the shop to see where the pinch points are just in case. Buy it at a tight fit as the padding will settle down over a few weeks and months. Think "hamster face" as it pushes in on the cheeks
For example i cant wear AGV helmets as they push in on my forehead after 10 to 15 minutes which is no good to me as i can spend 8 hours a day on a bike and i pay more for the helmets i use as the padding can be removed and cleaned and put back in. Cheaper helmets dont have that facility and maybe poorer venting and visor systems but as long as they are ECE22.05 certified they do the job of protecting your head from 40 quid to 1400 quid as it all comes down to materials used like Polycarbonate to Carbon Fibre, construction methods and comfort levels.
Gloves, i currently have 6 pairs depending on weather, rain, sunshine, speed and such like, eveyrthing from shorty armoured airmesh for low speed and high temp to full on thick winter gloves for maximum heat retention. Buy what you need as a starter and build on kit as your use and experience expands
- Has thanked: 2622 times
- Been thanked: 1518 times
Another vote for Helmet City... I've been to the Biggin Hill branch a couple of times, from Canterbury and from NW London to buy new helmets and they were helpful unboxing stock from the store both times.
One store lost interest almost as soon as I didn't buy the first one out of the store room.
Something that hasn't been mentioned yet is COVID-19. Don't forget that it remains active on surfaces for several days. You may not want to be sticking your head into a helmet that's sitting on a shelf and that an unknown number of other people have been trying on. Some stores are selling balaclavas to allow you to try their stock. Or buy your own and give it a good wash after use...
...and leave the helmet for a week or so before use!
- Has thanked: 475 times
- Been thanked: 308 times
My son, who lives in Reading, tells me there's a branch of sportsbikeshop there now, and you can order multiple items of kit online, to try on in the shop. It's what he did when buying a jacket and gloves recently. I think they only have 4 or 5 branches in the whole country though.
- Has thanked: 1728 times
- Been thanked: 2047 times
I got my last helmet, shark evo one 2 flipper from sportsbikeshop. Their customer service is always top notch, plus free returns. It was tight on cheeks to the point where it was uncomfortable. I rung them and he told me to wear it around the house for 15min sessions to see if it gives, and it did.
They also told me I could try different thickness cheek pads so you can custom fit, sort of. That helmet comes in 2 shell sizes but I think, 3 different thickness cheek pads. It's now just right.
You do want a good snug comfortable fit. They do give a bit and sbs would be my shop of choice if you cannot go to shop yourself.
- Has thanked: 1371 times
- Been thanked: 253 times
And SHARP gives a handy guide about how to know the right fit, etc: https://sharp.dft.gov.uk/get-the-right-fit/Horse wrote: ↑Fri Sep 11, 2020 6:00 pm And you need to know what a good fit is! [...] www.sharp.co.uk is worth checking.
Correct. Basically you order online for shop try-on and they're in the shop 24 hours later... as many things as you want it's ace.Scootabout wrote: ↑Sun Sep 13, 2020 10:58 pmMy son, who lives in Reading, tells me there's a branch of sportsbikeshop there now, and you can order multiple items of kit online, to try on in the shop. It's what he did when buying a jacket and gloves recently. I think they only have 4 or 5 branches in the whole country though.
Thanks all
I visited helmet city tried some on - was really impressed at how much they left me alone.. I have measured my head and looked at the shape - and think I have decided on a HJC i70 (followed sharps fitting advice.. still felt a bit weird) .. but I guess helmets take a little getting used to
Was tricky as a novice to know if it fitted at the top of my head - or if I felt pressure points..
- chutzpah
If it's pushing on your cheeks I guarantee* after a few hours of wearing it'll begin to feel just fine It's pressure elsewhere that can be a problem. Both my helmets I felt like I was going to bite the insider of my mouth if I opened it. It soon went as it moulded perfectly to my face.
* No compensation offered if I'm wrong
- DefTrap
- Has thanked: 2225 times
- Been thanked: 2142 times
Def try before you buy. Most standard sizes are roughly right (once you know what "your size" is, anyway) but sometimes they're way off. I bought a Bell in an Amazon sale once, should have been perfect, couldnt
even get my noggin through the aperture, miles off.
- Bigyin
As the others have said and i did earlier, hamster face is ok as the pads should push on the cheeks and will settle down. As long as they are not pushing on the forehead etc all should be ok. Wear it around the house and dont feel daft as you need to get used to it.
Did it come with a pinlock in the box as a lot of the HJC range does ....... the shop should have fitted it but if they didnt and its included in the box take it back to them for them to fit it correctly as they can be tricky to get a proper fit. Pinlocks are a godsend in crap weather as they keep your visor clear from fogging etc
I only mention it as i had a group of 4 today on CBT and 2 had brand new HJC helmets and both had free pinlocks included in the box and had the shop fit them
