ACF50
- Has thanked: 7991 times
- Been thanked: 2588 times
- Has thanked: 543 times
- Been thanked: 7692 times
Re: ACF50
If you spray it on a cloth and use that rather than spraying directly on the bike it will last ages.
- Has thanked: 2598 times
- Been thanked: 6375 times
- Has thanked: 1773 times
- Been thanked: 2134 times
Re: ACF50
Aerosol tin yes, it goes a long way. I warm it up in fairly hot water for a few minutes then spray directly on engine. Then use paint brush to spread, a rag would work aswel.
- Has thanked: 1062 times
- Been thanked: 374 times
Re: ACF50
Thanks for the tip - the pump spray bottle goes everywhere.KungFooBob wrote: ↑Tue Nov 26, 2024 6:17 am If you spray it on a cloth and use that rather than spraying directly on the bike it will last ages.
- Has thanked: 5498 times
- Been thanked: 13284 times
Re: ACF50
About 6 years up to now and i'd guess it's still more than 50% full. I do exactly that, clean cloth and spray till damp. It's quite 'greasy' so i wear a pair of gloves when using it.KungFooBob wrote: ↑Tue Nov 26, 2024 6:17 am If you spray it on a cloth and use that rather than spraying directly on the bike it will last ages.
- Has thanked: 10040 times
- Been thanked: 10350 times
Re: ACF50
Probably the best way to apply ACF is getting a fine mist with a compressor,but not all of us have one and the spray bottle you get with the non aerosol stuff is crap even when you warm the bottle.
As mentioned,dunking whatever bottle you use into hot water for a few minutes makes life a lot easier.
- Has thanked: 630 times
- Been thanked: 414 times
Re: ACF50
I have a plastic bottle (about 500ml from memory) which I apply with a paintbrush. It seems more effective then the aerosols I used in the past but I'm not an expert. It does seem to keep the corrosion at bay.
I think I've had the bottle for quite a few years. I put some on any vulnerable looking areas of the underside of my old Ford Tourneo mini bus the other day, also cleaned up the inside of the wheel arches and put some in there.
- Bigyin
- Has thanked: 1429 times
- Been thanked: 2711 times
Re: ACF50
I use the spray tins like dodgy and a cloth and brush for the fiddly bits. Leave it in hot water to thin it out and remember it never properly dries so looks wet all the time. I cover the wheels, tyres and brakes with some old towels then spray
Here is the first Multi i sprayed a few years ago
I use it on the bikes for winter riding and dont clean them while the ACF is on as it lets the crap build up on top of the ACF then wash the lot off in early the next year.
I get both bikes coated with a tin and normally have some left over.
- Has thanked: 4421 times
- Been thanked: 2890 times
Re: ACF50
I bought some for the GSXS the other year but never actually used it. Despite my garage being fairly damp at times the finish has held up really well with it just being clean. The oily finish puts me off a bit so not bothered
- Has thanked: 2466 times
- Been thanked: 3769 times
Re: ACF50
I bought the 32 oz./0.95 litre tribal size bottle a while back and on current usage it's almost certain to outlast me. I wonder if it has a secondary use as embalming fluid?
- Bigyin
