Recommendations for bike/garage security
- Has thanked: 664 times
- Been thanked: 1159 times
I'm grateful that I've got a double garage so space isn't really an issue.
Keen to get recommendations for security. Not sure I want to go down the ground anchor route- but maybe.
Thanks
Thanks
- Has thanked: 5449 times
- Been thanked: 13084 times
Re: Recommendations for bike/garage security
Mine have Almaxx Series IV locks. I have a couple of smaller locks for the other bikes... weirdly the most expensive bike doesn't have the best lock. LOL. Maybe i need to switch that about a bit.
- Has thanked: 7810 times
- Been thanked: 2526 times
My workshop is wooden, not sure what yours is, so not sure what to recommend.
I've got a couple of these : https://securityforbikes.com/proddetail.php?prod=ShSh (if you want one, order fast, Pragmasis are shutting down).
and large steel bars across the outsides of the doors to prevent the doors being able to be opened.
(there's only so much you can really do with wooden buildings, if the scrotes really want something, the could just cut through the walls).
Make sure the doors are properly secured.
- Has thanked: 9819 times
- Been thanked: 10143 times
If it's an up and over garage door,I have one of these. At least it'll slow them a bit,or make them move onto an easier target.
- Has thanked: 1507 times
- Been thanked: 1409 times
If the door is a sectional roll up & there's separate mandoor:
A couple of mole grips clamped on the tracks just above the lower rollers.
Or....
Or....
- ChrisW
- Has thanked: 2903 times
- Been thanked: 2052 times
If you're not locking it to something solid (ground / wall anchor) just make sure it's properly insured and don't worry about it!
- MrLongbeard
- Has thanked: 599 times
- Been thanked: 2428 times
I like the idea, but they scream 'there's something in here worth nicking'
Yeah maybe. Everything's a trade off in some way i suppose. One advantage is living in a quiet cul-de-sac so anyone cruising will be noticed.MrLongbeard wrote: ↑Tue Nov 12, 2024 10:02 pmI like the idea, but they scream 'there's something in here worth nicking'
- Has thanked: 1829 times
- Been thanked: 1469 times
I have one of those and have never fitted it. I remember someone telling me it acts more as a sign you have something to nick
Mostly my thoughts really. I don't have a single bike in here i couldn't replace within an hour on Ebay like for like. If i had something really custom it may change things a bit.
You doing the double bluff?
Re the comment above:
Although I currently have a set of these locks on my shed :
https://www.amazon.co.uk/gp/product/B00 ... TF8&psc=1
I would hesitate to recommend them.
Mainly because a scrote (apparantly) only needs a large screwdriver like this:
To do this.
Internally, they do not seem very solid:
