Happy new bike day.... WTF, what do you mean it's a Yamaha ???
Been thanked: 15506 times
Re: Happy new bike day.... WTF, what do you mean it's a Yamaha ???
Mr. Dazzle wrote: Sun Jan 24, 2021 9:52 am I always find that with these various throttle modes - in cars at least - that you rapidly 'dial out' the difference mentally anyway. Once you've driven for more than a few minutes you subconsciously recalibrate and there's no difference.
Maybe they're more pronounced on bikes? I've never driven a fast car or one with modes to know. My Volvo S60 d5 is the fastest car I've owned or indeed driven.
Apparently i need to reset the fault codes with an OBDII code reader....
I'm just waiting for confirmation on the specfics, but this is looking to be the sort of thing.
https://www.ebay.co.uk/itm/Yamaha-FI-OB ... %3A2334524
Mt09 exhaust removed today and bike now ready for the Leo Vince when it gets shipped. Snowy here though so not like it'll be leaving the garage.
Well that's interesting
https://www.fz09.org/threads/why-are-pe ... 781/page-7
for example, on a stock '14 09, when you open the throttle grip to 20%, 'std' mode opens the butterflies to about 18%, but in 'b' mode it will only go to 10.5% or so. you'll definitely feel this difference and if you were to put the bike on a dyno and do a part throttle run (instead of 100% which is the norm for dyno runs), you'd see the difference in the torque/power curves.
as you roll the throttle open, 'a' mode will feel more responsive than 'std' which will feel more responsive than 'b' because they're giving you larger actual throttle openings sooner.
The dyno chart above (thanks blkbrd) doesn't show the results the way you explained it.
with the stock ecu mapping, 'b' mode only opens the throttle butterflies to 70% even if you turn the throttle to the stop. the reason why the power curves are identical between 'std'/'a' and 'b' modes until about 6k rpm is because the engine's breathing isn't being choked when the throttles are only open to 70% until the revs are past 6k.
'a' and 'std' power curves are identical because they both give 100% throttle when you ask for it, and the dyno runs are done at full throttle.
notice that last 30% of throttle butterfly opening only gives about 10hp.
And this is more!
Yes, has a top speed limiter which kicks in at 10,000 rpm in 5th and 8500rpm in 6th
Its interesting that it actually restricts opening at low revs.
The bit about twist grip position vs. butterfly opening is what I was referring to. Every vehicle I've driven with different modes does that, as I said I find after a very short while my brain dials it out and I just open the throttle more/less to compensate.
For example in my car the default Eco mode means the first 3/4 of pedal movement does only about 1/3 of the throttle to encourage sedate driving. Sport mode is almost the opposite. However after driving for more than about 10 mins in either mode I find they're the same. Full throttle is the same in either mode.
If the computer actually stops you getting full throttle then no amount of compensation is gonna make up for it.
jk1994
Has thanked: 1 time
Been thanked: 3 times
Post by jk1994 »
Put the akra carbon on my 19 plate over Christmas. Just trying to decide where to get the ecu flashed. Needs to be a postal due to where I live but don't mind paying more for one made specific for the model and exhaust. Any suggestions?
https://www.wizperformance.co.uk/produc ... -ecu-flash
That's who i've used along with another guy on here and several over on the FZ09/MT09 forum.
There used to be a guy locally who Tricky used for his MT10 called S-Tec, but he's now retired and no longer does them. Wiz gets good reports from people who've used him, so that's who i went for
P3 tuning up near/in Liverpool also get good reports.
jk1994
Has thanked: 1 time
Post by jk1994 »
weeksy wrote: Sun Jan 24, 2021 4:21 pm https://www.wizperformance.co.uk/produc ... -ecu-flash
Perfect thanks for the info! Wonder what the price or flash difference is between the wiz and P3
£50. Wiz are £150 + post, P3 seem to be £200 but i don't know if that includes post or not.
jk1994
Has thanked: 1 time
Post by jk1994 »
weeksy wrote: Sun Jan 24, 2021 4:41 pm £50. Wiz are £150 + post, P3 seem to be £200 but i don't know if that includes post or not.
For the exact same standard flash or?
jk1994 wrote: Sun Jan 24, 2021 4:51 pm
I wouldn't even begin to know the answer to that. I doubt it though. In theory they'll both have needed a bike that they've done manually on the dyno, then use that as the base custom map. Another option of course would be to get hold of a bike that has the custom map from somewhere then extract that map, but i doubt that would be ethical, so i'm guessing not.
They have to pay £83 of their money to Woolich, who own the 'key' to your ECU which allows the modifications.
jk1994
Has thanked: 1 time
Post by jk1994 »
weeksy wrote: Sun Jan 24, 2021 4:54 pm
Yeah getting the bike on the dyno would have been ideal. Unfortunately no places remotely close in the North of Scotland.
Ah I didn't know that, both wiz and P3 need to pay Woolich to do the flash?
It's classed as the key to unlock your ECU facilities.
However if you were for example to want say the blipper, you wouldn't need a 2nd key.
jk1994
Has thanked: 1 time
Post by jk1994 »
weeksy wrote: Sun Jan 24, 2021 5:15 pm It's classed as the key to unlock your ECU facilities.
Yeah makes sense, thanks!
Davie lad
Has thanked: 193 times
Been thanked: 238 times
Post by Davie lad »
Dont know where about you are, in the North, but try this guy, he owns the cromarty brewing company, and had a Dyno next to the brewery, His names Chappy
Highland Motorcycle Dyno Centre
Address:Canon St Postcode/City:IV11 8XD Davidston County:Highland Scotland
Phone: 01381 600300
Mobile: 07801 951816
jk1994
Has thanked: 1 time
Post by jk1994 »
Davie lad wrote: Sun Jan 24, 2021 5:46 pm
Phone: 01381 600300
Thanks a lot for that! Pretty close to me so I'll give him a call
jk1994
Has thanked: 1 time
Post by jk1994 »
Also what fueling issues did yous have before you got your ecu's flashed?
jk1994 wrote: Sun Jan 24, 2021 11:12 pm Also what fueling issues did yous have before you got your ecu's flashed?
None at all. But euro 4 bikes are notoriously lean, so adding a de-cat system wouldn't be wise without changing fuelling
Tricky
Has thanked: 3045 times
Been thanked: 3309 times
Post by Tricky »
weeksy wrote: Mon Jan 25, 2021 7:03 am
Wow, I've missed a few posts it seems- You going de-cat? - I thought you didn't want loud (although yeah I know, wants change daily in Weeksy world :D )
