- Has thanked: 15601 times
- Been thanked: 9847 times
Took the campervan for its MOT which it passed with no advisories!
So far today I've been doing doner kebab farts after having a kebab last night after a few beers with some guys I used to work with. I can still taste the doner meat, chips, chilli sauce now my farts are all kebabby
- gremlin
- Has thanked: 776 times
- Been thanked: 4514 times
Managed to break my phone.
Was getting set up to get rid of this old donkey (Galaxy S8) to reach the dizzying heights of an S10 hand-me-down from Mrs. Gremlin.
Went to take out the sim and...well, this came off in my hand: Sim is still in situ as I can still make calls, but not sure how to winkle out the sim without damaging it. Plus, this phone being sent back to Samsung is conditional on Mrs. Gremlin getting £150 trade in on her new S23 Ultra.
Hmmm. Thoughts?
Hmmm. Thoughts?
- Has thanked: 1068 times
- Been thanked: 703 times
A gentle tap into your hand May free it off and fall out. If not I would go with poking around with a screwdriver option, that’s my usual way.
Good luck
Mick
Good luck
Mick
- Has thanked: 6263 times
- Been thanked: 4613 times
Can you see the end of the SIM? How deep inside is it? They tend to be sit quite firmly in the contacts. If a pair of v fine nose pliers won't get it, could you put a dab of superglue on something (or a couple of things) and attach to the edge of the SIM to give something to pull on? Bit of a long shot though.
If all else fails...local dodgy phone shop can probably take it apart and may have a replacement SIM carrier.
- Has thanked: 852 times
- Been thanked: 1225 times
Request a replacement SIM card, transfer your number and leave that in there, put the broken front back on and pretend you have no idea.
- gremlin
Nope. Tighter than a nun's nasty in there. Can't see owt and my poking about has obviously moved the card as I'm now not on the network.Count Steer wrote: ↑Thu Apr 06, 2023 12:48 pm Can you see the end of the SIM? How deep inside is it? They tend to be sit quite firmly in the contacts. If a pair of v fine nose pliers won't get it, could you put a dab of superglue on something (or a couple of things) and attach to the edge of the SIM to give something to pull on? Bit of a long shot though.
However, in the depths of my despair came Mrs. Gremlin. Being the paragon of common sense and practicality she said, 'Why don't you just order a new SIM, put the broken cover back in and we'll send the phone back. When you get the new sim just put it in the new phone'.
God damn it, I knew there was a reason I married that woman!
- Has thanked: 9677 times
- Been thanked: 9700 times
Yeahbutt,then you've been beaten by an inanimate object. When that happens,the word goes out and all the other inanimate objects in your future will know you're a surrendering easy touch.gremlin wrote: ↑Thu Apr 06, 2023 1:09 pm Nope. Tighter than a nun's nasty in there. Can't see owt and my poking about has obviously moved the card as I'm now not on the network.
Life will become very difficult when that happens.
- Has thanked: 2914 times
- Been thanked: 1846 times
Put a deposit down on a new car. What with SWMBO eternity ring it’s been a spendy month
- Been thanked: 2499 times
Another tip run, after a morning larking about on the beach.
A dead pressure washer and bits, a dead compressor and a supermarket crate trolley. And not just any supermarket, this is an M&S one. With a wonky wheel.
Scuttles off to check the sanctimnious I'd never sell a car with a fault' thread.gremlin wrote: ↑Thu Apr 06, 2023 1:09 pmNope. Tighter than a nun's nasty in there. Can't see owt and my poking about has obviously moved the card as I'm now not on the network.Count Steer wrote: ↑Thu Apr 06, 2023 12:48 pm Can you see the end of the SIM? How deep inside is it? They tend to be sit quite firmly in the contacts. If a pair of v fine nose pliers won't get it, could you put a dab of superglue on something (or a couple of things) and attach to the edge of the SIM to give something to pull on? Bit of a long shot though.
- Has thanked: 1446 times
- Been thanked: 1329 times
Ran some errands, one of which involved dropping by the bank to get some cash.. so when asked "how would you like that?" I requested $20 of it in Jeffersons ($2) as it screws with the youth when you pay for something with them
- Has thanked: 626 times
- Been thanked: 4063 times
- Has thanked: 66 times
- Been thanked: 1235 times
2 out of the 3 rooflights replaced.
Bit hot out on top of the van so I'll wait for a cooler/earlier day to finish off.
Can't believe moho repair shop quoted 2k to supply and fit them. Spent €320 on the vents and sikaflex, down to 40 mins now to strip and refit on the second one!
Not moaning too much as I get to keep the labour charge.
I just pulled off what may be one of my best pranks...
Went to Lowes early this morning for some hardware. There's some guy in the parking lot with a Guzzi that is trying to fire up, but not making it. The first thing I notice is that the damn thing is really rusty so can't be local, it's beat to shit & covered in extremist religious stickers that appear to be holding it together. I also notice that one of the plug caps is off.
At this point my brain went off the rails a bit...
I make a big show of casting a magic spell to make it start & during the arm waving manage to pop the plug cap on without him seeing me do it.
He looks a bit alarmed at this mumbling performance & I tell him to try again. It fires up with a spectacular BOOM from the mufflers which is accompanied by smoke rings from the loud end. I tell him the demon has been destroyed & walk into the store before he can say anything.
Come back out the store a few minutes later to find hm gone, which is a pisser as it didn't occur to me to get a pic until I was at the check out.
- Has thanked: 532 times
- Been thanked: 7217 times
- Has thanked: 16251 times
- Been thanked: 3745 times
Had a scary morning as a transfer booked for today (client gave and confirmed the dates!) was actually for tomorrow - luckily the driver went to check the flight arrival and it wasn't coming til tomorrow!!), PLUS a tour operator transfer turned out not to be in the system (bloody good job that he needed to change the times for part of the group as otherwise we wouldn't have known!!)
Anyway - a bit of stress as I'd managed to take a booking for an empty return that was confirmed just before all this happened!!
BUT - also managed to sort out all the extras and now have every driver doing a full out and return trip So, despite the stress, good result!! LOL
And, just been to my local shop to buy 'proper' bacon* so i can make some bacon butties in the morning for me and a mate to eat on the first lift. Yup, I'm skiing in the morning On a Saturday!!
*ok, it's not Really good bacon, but it's bog standard 'wet' cured bacon. Which, when you don't get it much is pretty darned good Must make more effort to source the cut of meat and ingredients to do dry cured bacon at home
- wull
- Has thanked: 870 times
- Been thanked: 1495 times
Work! Took the bike today as well, proper cold this morning, heated grips came in handy but the ride home was superb, sun was shining, roads were decent.
