Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
mangocrazy wrote: Mon Mar 08, 2021 10:34 pm Compare what it's like to back off the throttle completely in gear, and then do the same out of gear. When in gear you slow down quite rapidly, as the engine is acting as a brake. When in neutral (i.e. out of gear) the engine is removed from the equation and you freewheel for way further than if you were in gear. So it is the engine and whether it is in circuit or not that makes the difference, not some notional wheel 'reverse force'.
'Acting as a brake' to the force transmitted from the wheel...
Post by slowsider »
Mr. Dazzle wrote: Mon Mar 08, 2021 9:21 pm You misunderstand what I'm saying with the factor 5. Most cars have 4 or 5 stuf hubs, done up to 100Nm. Replacing that with a single nut means you need very roughly five times the torque for the same clamp force. "Roughly" cause the size of the thread comes into it to.
Doesn't the pcd of the studs have some relevance too?
Has thanked: 7606 times
Been thanked: 5921 times
mangocrazy wrote: Mon Mar 08, 2021 10:25 pm The only time the drive shafts are in reverse motion is when reverse gear is selected. That is why drive shafts have to work both ways.
Good heavens.
Engine braking when reversing must really confuse those poor shafts.
slowsider wrote: Tue Mar 09, 2021 7:33 am
Yes and no.
"No" because five bolts is five bolts right?
"Yes" because in practical terms those bolts/studs are mounted in a 'real' component that doesn't obey they idealised laws of calculations. The wheels and hub distort as you bolt them up, so the spacing of the bolts effects the clamping load achieved. That's also part of the reason you're advised to tighten in stages, the distortion of the bits would potentially effect how much of your tightening torque is turned into useful clamp.
Bigger PCDs generally come with bigger wheels and bigger hubs. Hubs might be bigger cause they have bigger bearings etc. for higher forces, but they also allow you to transmit more torque for the same clamp load (and hence bolt torque). But they also tend to be heavier....which is one of the reasons you would then go for a centrelock wheel. Which in turn forces you to have a really high tightening torque.
Has thanked: 2317 times
Been thanked: 1821 times
Post by Jody »
People who know better (Including the likes of Adam Savage, Colin Furze, Ethan from Grid hard plumbing and too many others) that say "half" when they mean "two"
' The hub broke in half"
Really? half? exactly half?..... is that half by weight, or by volume, or by mass or do you actually mean
" The hub broke in two "
Jody wrote: Tue Mar 09, 2021 8:30 am People who know better (Including the likes of Adam Savage, Colin Furze, Ethan from Grid hard plumbing and too many others) that say "half" when they mean "two"
Ha....never really thought of it in those terms, but you're quite right. :D Thanks for the new annoyance.
Post by Jody »
Mr. Dazzle wrote: Tue Mar 09, 2021 8:33 am
Happy to help :lol: :lol: :lol: :banana-wrench: :banana-wrench:
Has thanked: 10951 times
Been thanked: 3990 times
Shouldn't it be "... into two"?
(as in, a shortening of "... into two pieces".)
(or.... into two halves. :D)
Rockburner wrote: Tue Mar 09, 2021 8:45 am
Parts, not halves.....
Post by Jody »
Quite possibly.
Saga Lout
Has thanked: 598 times
Been thanked: 748 times
Post by Saga Lout »
Hmmm....
"There were two of us so I cut the cake in half."
"There were two of us so I cut the cake into two."
They both work, they both convey what I mean with an adequate amount of accuracy. You're getting upset over nothing*.
* Which is the point of the thread, I suppose. Carry on. :P
Wreckless Rat
Has thanked: 666 times
Been thanked: 704 times
Post by Wreckless Rat »
Shit "deals" in stores...
The dog food we use is £59.99 a bag... or... the deal of "£135 for two bags". When you select two, you get automatically given the "deal" price. Now anyone that knows me, knows I ain't no maths genius (slightly odd see the job I do, but we digress), I can however add up 59.99 + 59.99 and it sure as shit is less than 135!!
Has thanked: 1101 times
Been thanked: 5871 times
I like the ones that suddenly present you with the bargain 'Buy two for £4!' when the individual price is, say £2.20 each. Fair play, you might say, but then you think back and realise they were only £1.79 each last week and that this is the supermarket equivalent of pointing up into the empty sky and shouting 'Look! An eagle!!' before running off...
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Post by DefTrap »
To be fair, two of those are furriners and isn't Furze from effing Lincolnshire FFS? ;)
I'm more concerned that despite their poor use of the Engrish longwidge they're living the dream - I'd kill to have half the skills they have. The Grind Hard boys must still be under 30 n'all.
Has thanked: 19524 times
Been thanked: 4946 times
Wreckless Rat wrote: Tue Mar 09, 2021 9:32 am Shit "deals" in stores...
gremlin wrote: Tue Mar 09, 2021 11:01 am I like the ones that suddenly present you with the bargain 'Buy two for £4!' when the individual price is, say £2.20 each. Fair play, you might say, but then you think back and realise they were only £1.79 each last week and that this is the supermarket equivalent of pointing up into the empty sky and shouting 'Look! An eagle!!' before running off...
Yup
I also check the price per kilo on the 'fantastic' offers. Also with bigger packs - everyone is so used to larger packs being cheaper per slice/kg than smaller ones that it's automatic to reach for a bigger pack - but definitely worth checking
Noggin wrote: Tue Mar 09, 2021 12:07 pm
Yup
Mrs. Gremlin is the shopping equivalent of a special forces raid. First, menus are meticulously planned for the week ahead and cupboards, fridges and freezers are checked for existing supplies. The list is drawn up, with the week's menus at the bottom. Discount cards are obtained from supermarket-employed siblings and then we get the 'Go! Go! Go!'. Where as I dawdle, enjoying the full supermarket experience, she's in, shopped, done, trolley full, reduced items selected, 2-for-1 offers either taken up or ignored with razor-sharp mental arithmetic and menus changed on the hoof, The exfil at the till is brutal, with the poor cashier struggling to keep up. Once finished, coupons, staff discount cards, etc are presented and we're out, me following behind, staggering like a recently-freed hostage choking on a flash-bang.
I think her motto is, 'Train hard - shop easy' :D
Has thanked: 6123 times
Been thanked: 15476 times
I dont even know which shop Mrs weeksy goes to, i'm out cycling.
DefTrap
Post by DefTrap »
Every time my missus goes in to a certain boulangerie and is offered the 'meal deal' she points out that their deal costs more than the individual items (in most cases, certainly the ones I want) priced separately.
They all think she's mad. :)
I've always been hugely irritated by folk not being able to add up - or at least being so bad at guesstimating that you can throw any old figure at them.
gremlin wrote: Tue Mar 09, 2021 12:34 pm
Yup
I like Mrs Gremlin! Shopping skills I only aspire to!! :banana-dance: :banana-dance:
But then I'm only shopping for one and it's a lot easier (in some ways!!) :D :D
Trinity765
Has thanked: 3134 times
Been thanked: 3180 times
Post by Trinity765 »
I'm not a sucker for deals - it's only a bargain if you wanted it in the first place.
Supermarkets now give a price per weight on the shelf label, which is great for finding a good deal however, they'll give the price per gram for one coffee and the price per kilogram for the next. It's ok, I can do the maths, but if they were actually trying to help, they'd stick with one unit of weight. It gets really complicated when there is a deal on, like buy one get one half price because then you're left wondering if the price per kilo is the deal price or the original price :think: More maths.
I used to hate shopping but it has become the only thing I do that could be called leisure during lockdown, the hours I've spent wandering around Sainsburys with an empty basket, studying labels :hmmm:
