Buying a van
Re: Buying a van
Take it to an aircon refill place. It'll cost £45.
They do a drain down and leak test before filling. It there's a leak they won't go ahead with the refill and most won't charge.
Chances are it just needs regassing.
Re: Buying a van
If a regas doesn't help they take the gas back out IME, then charge you way less.
Has thanked: 8039 times
Been thanked: 5694 times
Re: Buying a van
KungFooBob wrote: Wed Apr 09, 2025 6:54 pm Take it to an aircon refill place. It'll cost £45.
Never worked this one out - if it needs regassing and there's no leak, where's the gas gone? :think:
Re: Buying a van
Often there's no lack of gas and there's something else wrong :D
"Just needs a regas" seems to be something of a standard refrain.
Re: Buying a van
Mr. Dazzle wrote: Wed Apr 09, 2025 6:56 pm If a regas doesn't help they take the gas back out IME, then charge you way less.
Ah, that's what they did with mine last time. The time before that they added the dye as mentioned ^^^^. (It did leak and they found it).
When it happened on the MX5 it needed new everything :( (but they got recon units and it saved £££s).
Has thanked: 12607 times
Been thanked: 8537 times
Re: Buying a van
Our motor is 6 year old and has air-conditioning on every day. Still not needed gassing.
MyLittleStudPony
Has thanked: 831 times
Been thanked: 586 times
Re: Buying a van
Post by MyLittleStudPony »
It's the old* R1234YF gas so a regas is about £135.
Can I see if the compressor is trying by listening?
*rather new. I think all cars from 2017 have this, more expensive, gas.
Has thanked: 779 times
Been thanked: 3216 times
Re: Buying a van
Yorick wrote: Wed Apr 09, 2025 7:03 pm Our motor is 6 year old and has air-conditioning on every day. Still not needed gassing.
Pffft, mine is 12 years old, and has the air con on every time it's used, it's had one top up of gas.
Re: Buying a van
MrLongbeard wrote: Wed Apr 09, 2025 8:36 pm
When we got our first MX5 the air con was fitted after the vehicle shipped to the UK - and that was the one that went kaput. The later MX5s had it installed in Japan and never had a problem with them.
The Volvo needed attention around the 180k mark (and it was never switched off - it's been on all the time in every car we've had with it fitted - climate control thermostats :thumbup: ).
Has thanked: 714 times
Been thanked: 2040 times
Re: Buying a van
Re gassed the last car myself with a Halfords kit. Easy enough and only needed half the gas so getting two fill ups for your money.
MyLittleStudPony
Re: Buying a van
I sold this recently. My oldest (and his g/f) don't come nearly so often so I don't really need it any more.
I'd had it almost two years. Took a c.£10k hit which is so much more than any other vehicle I've bought and sold. I think people became aware the wetbelt was an issue during my stewardship and that made prices fall a bit more than they might have otherwise.
Has thanked: 357 times
Been thanked: 919 times
Re: Buying a van
A £10k hit in less than 2 years would focus the mind! I can’t see what you could have done about that, apart from not buy it, or not sell it.
Been thanked: 15493 times
Re: Buying a van
Wossname wrote: Thu Feb 26, 2026 10:20 am A £10k hit in less than 2 years would focus the mind! I can’t see what you could have done about that, apart from not buy it, or not sell it.
Mine has taken the same hit, but i've put 75,000 on the clocks and owned for 3 years, taking from 42,000 to nearly 120,000 and counting. So my loss is partly/mostly justified and OK. At the end of the day you can't own a vehicle and stack the miles on it and expect not to lose.
I love my Transit though :D
Re: Buying a van
With the reported reliability issues of wet belts and the £1k+ cost to change them they'll do more for the EV cause than anything else.
