Are bikes getting too complicated?
Has thanked: 6203 times
Been thanked: 5091 times
Re: Are bikes getting too complicated?
Mr. Dazzle wrote: Mon Jan 17, 2022 11:01 pm
Horse wrote: Mon Jan 17, 2022 9:39 pm
mangocrazy wrote: Sat Jan 15, 2022 1:50 pm The big problem would be spares availability of course.
It's been quite surprising how much of The Priest's Triumph has decayed, rotted or crumbled.
Its 20 years old now I think? Bikes aren't built for 20 year lives I wouldn't have thought.
Perhaps not, but it was non-critical things like connectors in the fuel system that particularly surprised me.
If '20 years', that would be an average. What could the worst case be? After all, it's only petrol ;)
Has thanked: 2556 times
Been thanked: 6263 times
The fuel thing effected that particular bike pretty much from new. It's worth remembering that model of Triumph* was the first to have fuel injection, plastic fuel tank, in house twin spar ally frame etc. The fuel thing is more debugging than anything else.
*Nearly. Priests bike is not the very first T595/T509 family but the fuel system for example is the same as the very first 1997 "brand new design Triumph".
I.e. from when they went all in properly on an in house bike with loads of tech
Has thanked: 6383 times
Been thanked: 4773 times
MingtheMerciless wrote: Mon Jan 17, 2022 8:19 pm I had a mini, I grew to hate "points" with a passion.
The problem with Minis was compounded by where they put the distributor. I saw all sorts of wheezes to try and protect them from the elements. A common one was to use a rubber glove with the leads through the fingers. The number of times one of my housemates had to get out in the rain and spray the distributor he should have had shares in the spray company (can't remember what it was but most Mini owners had some).
Has thanked: 15999 times
Been thanked: 10262 times
Points were fine in their day. The trick was to set them using a dwell angle meter and the key to reliability was to use a locking "star" washer. But, yes they were still shite compared to the first CDi...
Has thanked: 2636 times
Been thanked: 1523 times
slowsider wrote: Sat Jan 15, 2022 9:16 am Manual advance/retard and hand oil pump ftw :)
Don't forget acetylene lights.
Has thanked: 1264 times
Been thanked: 1188 times
Post by slowsider »
The Spin Doctor wrote: Tue Jan 18, 2022 1:16 pm
How dim do you think I am? ;)
Bigjawa
Has thanked: 221 times
Been thanked: 879 times
Post by Bigjawa »
Yorick wrote: Mon Jan 17, 2022 2:54 pm I bet you all drive with loads of leccy stuff but nobody moans about that.
Leccy windows?
Central locking?
Power steering?
ABS
Just bikers moaning again :obscene-birdiedoublered:
Up to a couple of years ago, I drove a Scudo with no ABS, leccy windies or central locking. PAS was just a mechanical pump. Ironically what killed it was the electronic control for the immobilizer would make the damn thing die at random intervals and you didn't have the wee mechanical stop on the pump that would let you dump the solenoid and just use a cable.
Yorick wrote: Mon Jan 17, 2022 8:03 pm If points were good, cars would still be using them.
Last car I had with points was an 89 Panda, was going to replace them but the child in the local motor factors didn't know what the hell I was talking about.
Has thanked: 487 times
Been thanked: 1433 times
Bigjawa wrote: Tue Jan 18, 2022 11:56 pm Up to a couple of years ago, I drove a Scudo with no ABS, leccy windies or central locking. PAS was just a mechanical pump. Ironically what killed it was the electronic control for the immobilizer would make the damn thing die at random intervals and you didn't have the wee mechanical stop on the pump that would let you dump the solenoid and just use a cable.
Was it the 1.9D? I had the same van but the Pug Expert version. You could bin the Lucas Delphi pump for the Bosch out many a French/Italian motor for a simpler life and running on veg oil.
