The gap on the points needs adjusting, if that doesn't work change the condenser.Jody wrote: Fri Jul 26, 2024 5:41 pmTuesday, but I don't think I'll make it to the party.
Soapy £10 to anyone that can tell me the reference !![]()
- Pirahna
- Has thanked: 3005 times
- Been thanked: 1742 times
- Has thanked: 8022 times
- Been thanked: 5675 times
Personally, I'd say sod the expense and buy a new gap.Pirahna wrote: Fri Jul 26, 2024 8:15 pmThe gap on the points needs adjusting, if that doesn't work change the condenser.
- Pirahna
I thought they'd stopped trading?
- Has thanked: 781 times
- Been thanked: 1072 times
If you stick it under your pillow it's less likely to go missing before the morning.DefTrap wrote: Fri Jul 26, 2024 5:23 pmAs a stoodent, my housemate used to wrap up the remnants of his post-pub-takeaway and just wedge it down the side of the sofa so that he could continue eating it in the morning. How none of us died ....Yorick wrote: Thu Jul 25, 2024 8:24 pm Nah. Have it cold for brekky with that half full can you found behind the sofa![]()
- Has thanked: 12570 times
- Been thanked: 8528 times
Spanish websites. Just booked ferries to Fuerteventura and took nearly as long as the ferry itself.
I was a programmer for many years and I'd have been sacked if I'd produced the 2 shit sites I had to use today
- Ditchfinder
- Has thanked: 859 times
- Been thanked: 1068 times
I love broad beans, especially in a ham and broad bean risotto, but they are difficult to find fresh in this country (well up north anyway) yet we export or use as animal feed most of what we grow in the UK
https://www.theguardian.com/science/art ... -scientist
- Has thanked: 2554 times
- Been thanked: 4160 times
I really like broad beans as well, but the only way to get hold of them on a regular basis is in the frozen supermarket aisles. If I ever see them fresh I snap them up, but that doesn't happen often.
They're great in a green Thai curry.
I used to do PYO broad beans with my Mum when I was a kid. I'm gonna see if I can find somewhere to do it with Baby D, now I think on it
I suppose I could just grow them
Those pods look so comfortable inside.
- Been thanked: 2721 times
The water stop cock in my house. When the valve is open the lever is across the direction of flow and when closed it's in line with the direction of flow. Aha I thought, I'll take the handle off and rotate in 90 degrees on the shaft. Nope, it has a stadium shaped* driveshaft and socket not a square one.
*A similar shape to the pistons used in the Honda NR750 engine. They aren't oval, ovals are curved all round, stadiums have straight sides.
- Has thanked: 10947 times
- Been thanked: 3982 times
Weird. I wonder if the internal parts were assembled 90 degrees out somehow? (Or the wrong internals used).cheb wrote: Tue Jul 30, 2024 7:25 am The water stop cock in my house. When the valve is open the lever is across the direction of flow and when closed it's in line with the direction of flow. Aha I thought, I'll take the handle off and rotate in 90 degrees on the shaft. Nope, it has a stadium shaped* driveshaft and socket not a square one.
Seems totally counter-intuitive to have the lever aligned that way.
I doubt that much thought went into the manufacturing specs. It's not a quarter turn tap, just the usual windy up and own one.
I dealt with the wrongly aligned quarter turn taps soon after arrival.
- gremlin
- Has thanked: 1100 times
- Been thanked: 5866 times
Stadia, surely.
And with any mains tap, as long as it turns when needed, then it's a good 'un.
Hypercorrection apparently: https://en.wikipedia.org/wiki/Hypercorrection
Not as bad as shouting 'Bravo' instead of 'Brava' at the opera though.
An industrial ceramics academic at Leeds Uni insisted on pronouncing the word as keramics because 'the Greek root is keramos' (potter's earth). He wasn't the only one - it was a bit of an academic snobbery thing for a while.
A bit like surgeons calling themselves Mr or Mrs as historically they weren't physicians.
But then most doctors aren't Doctors.
I've just had the 6th (I think) visit from the Stoves techs to fix my cooker. Their fault finding methods sounded normal to me so not a big rant about them but the problem turned out to be* loose power cables inside the cooker, not impressed with what is meant to be a premium brand.
* Needs more testing.
The local boulangerie has no bread! None at all! Not one baguette!
Revolutions have started for less in France...
- Has thanked: 20822 times
- Been thanked: 13629 times
B&Ms not having any Tingly Teds in!
I had to make do with the last croissant.
