Has thanked: 20814 times
Been thanked: 13617 times
Guzzis seem to be flavour of the month lately...
Lutin
Has thanked: 365 times
Been thanked: 383 times
Post by Lutin »
Taipan wrote: Sun Jan 31, 2021 6:24 pm Guzzis seem to be flavour of the month lately...
This one appears to be turbocharged.
Has thanked: 12562 times
Been thanked: 8520 times
Lutin wrote: Sun Jan 31, 2021 6:39 pm
It might need a bigger seat hump :D
Been thanked: 4527 times
Yorick wrote: Sun Jan 31, 2021 6:57 pm
It needs parking two metres to the left
rodbargee
Has thanked: 397 times
Been thanked: 1114 times
Post by rodbargee »
More agricultural equipment
Tarmacsurfer
Has thanked: 100 times
Been thanked: 111 times
Post by Tarmacsurfer »
Guess the donor bike
(Should be an easy one)
rodbargee
Post by rodbargee »
Saachs rotary!
This is a Sachs rotary
That Hercules appears to have a weird two stroke engine that is intriguing
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Post by DefTrap »
weeksy wrote: Mon Mar 23, 2020 7:29 pm Far from convinced i like it... but...
Still my favourite bike on this thread.
A lot of them (XVs) have been done, few are as good.
rodbargee
Post by rodbargee »
the discussion about the hercules was that the reed valve inlet and odd exhaust positioning was a rotary. I I get that its not like the other one pictured, I would love more info on it. if thE chamber was 90deg putting it inline? and finned without that huge air intake.
rodbargee
Post by rodbargee »
Has thanked: 7592 times
Been thanked: 5916 times
The DKW is a rotary like the Norton F1. 'Triangular' piston.
rodbargee wrote: Mon Feb 01, 2021 3:52 pm Here....https://motocrossactionmag.com/bikes-yo ... 02-rotary/
That is a Wankel, and very interesting, I wonder how they've geared the rotor to the clutch.
Horse wrote: Mon Feb 01, 2021 3:59 pm The DKW is a rotary like the Norton F1. 'Triangular' piston.
So is the Hercules MX bike, the rotor is vertically above the crankcases.
Ah, ok, apologies. First glance it just looks like a normal 2t barrel at an angle.
Has thanked: 1059 times
Been thanked: 1643 times
That Hercules is a new one on me, thanks for putting it up.
Been thanked: 9461 times
New Benelli Leoncino 800, looks alright I reckon.
Has thanked: 6116 times
Been thanked: 15468 times
Yeah not bad. What engine/config.
Stolen off the Benelli website...
754cc Bore x Stroke - 88x62mm Engine layout - Parallel twin Engine details - 4-stroke, liquid cooled, 4 valves per cylinder, dohc Power - 80bhp Torque - 50lb-ft Top speed Est - 135mph Transmission - 6 speed, chain drive Tank size - 15 litres Frame - Steel Trellis Front suspension - 50mm USD hydraulic forks Front suspension - adjustment Compression, rebound and pre-load Rear suspension - Single Hydraulic Shock Rear suspension - adjustment Preload and rebound Front brake - 2 x 320mm discs, mono block Brembo 4 pot calipers Rear brake - 1 x 260mm disc, twin pot caliper Kerb weight - 220kg
I saw another picture of it side on, the tank is quite an odd shape.
80bhp twin, yeah that works for most bits
