Re: GSXS 1000 - Mofo's Gixxus
Posted: Mon Jul 22, 2024 9:13 pm
You quite likely did a better job than the dealer!
Motorbikes, Sportsbikes, Adventure bike, Supermotos, banter, chat, friends and whatever else you can imagine. KTM, Ducati, Aprilia, Suzuki, Yamaha, BMW, Moto Guzzi, Laverda
https://revtothelimit.co.uk/
Hope so, only odd thing for me is the whole torque setting for the filter! I'd normally just do it hand tight. The book says 20nm. The HiFlo filter says 'Do not use the nut on the end for fitting" but it does go on to say unless specified. In the end I did it up as tight as possible by hand and then did a bit more with the socket. I don't have any lockwire anymore but will stick a mark at 12 o'clock on the filter.
Don't know if mine was pre lubed as my brother opened it (and got it in place) but the packaging said lube with oil so presume not. Either way it got pre lubed with fresh Castrol fully synthetic.KungFooBob wrote: Tue Jul 23, 2024 10:56 am I put a HiFlo on the Beemer a couple of weeks back, no nut, but I was impressed that the rubber seal came pre-lubed!
I've only ever hand tightened a spin on filter. Once it stops freely spinning about an 8th or so more by hand. Never had a leak or one come loose etcSupermofo wrote: Tue Jul 23, 2024 8:21 amHope so, only odd thing for me is the whole torque setting for the filter! I'd normally just do it hand tight. The book says 20nm. The HiFlo filter says 'Do not use the nut on the end for fitting" but it does go on to say unless specified. In the end I did it up as tight as possible by hand and then did a bit more with the socket. I don't have any lockwire anymore but will stick a mark at 12 o'clock on the filter.
SameKungFooBob wrote: Tue Jul 23, 2024 12:06 pm My filter had a cellophane wrap over the seal that you had to pull off before fitting.
Me too. On the GSXS forum some people seem to think the torque setting is due to the type of sealing ring on the OE part?? Other say its in the manual so do it regardless. I sort of went in the middle. Hand tight and a little more with a socket. The OE filter that came off wasn't overly tight and came off easily enough unlike a lot I've had in the past where they've been welded on!Taipan wrote: Tue Jul 23, 2024 12:33 pmI've only ever hand tightened a spin on filter. Once it stops freely spinning about an 8th or so more by hand. Never had a leak or one come loose etcSupermofo wrote: Tue Jul 23, 2024 8:21 amHope so, only odd thing for me is the whole torque setting for the filter! I'd normally just do it hand tight. The book says 20nm. The HiFlo filter says 'Do not use the nut on the end for fitting" but it does go on to say unless specified. In the end I did it up as tight as possible by hand and then did a bit more with the socket. I don't have any lockwire anymore but will stick a mark at 12 o'clock on the filter.
They do all seem to get put on by ham fisted apes! I cant recall ever taking one off easily. Actually, thinking about it, some of them were put on gently by me!?Supermofo wrote: Tue Jul 23, 2024 12:39 pmMe too. On the GSXS forum some people seem to think the torque setting is due to the type of sealing ring on the OE part?? Other say its in the manual so do it regardless. I sort of went in the middle. Hand tight and a little more with a socket. The OE filter that came off wasn't overly tight and came off easily enough unlike a lot I've had in the past where they've been welded on!Taipan wrote: Tue Jul 23, 2024 12:33 pmI've only ever hand tightened a spin on filter. Once it stops freely spinning about an 8th or so more by hand. Never had a leak or one come loose etcSupermofo wrote: Tue Jul 23, 2024 8:21 am
As I nipped it with a socket I was wondering if this'll be me in 12 months time. I'll have to hit myself over the head with a rachetTaipan wrote: Tue Jul 23, 2024 12:58 pmThey do all seem to get put on by ham fisted apes! I cant recall ever taking one off easily. Actually, thinking about it, some of them were put on gently by me!?Supermofo wrote: Tue Jul 23, 2024 12:39 pmMe too. On the GSXS forum some people seem to think the torque setting is due to the type of sealing ring on the OE part?? Other say its in the manual so do it regardless. I sort of went in the middle. Hand tight and a little more with a socket. The OE filter that came off wasn't overly tight and came off easily enough unlike a lot I've had in the past where they've been welded on!Taipan wrote: Tue Jul 23, 2024 12:33 pm
I've only ever hand tightened a spin on filter. Once it stops freely spinning about an 8th or so more by hand. Never had a leak or one come loose etc![]()
That's what I would do, depends on what you want, Felixstowe or Harwich have more to offer, the roads are better and each would take about the same time to get to as Shotley.Supermofo wrote: Fri Aug 02, 2024 5:56 pm Maybe miss it out then, just do Manningtree and then go north west from there
Think I've seen it. Reckon I'm missing the beard, waistcoat and shit chop to be allowed inLe_Fromage_Grande wrote: Fri Aug 02, 2024 6:07 pmSupermofo wrote: Fri Aug 02, 2024 5:56 pm Maybe miss it out then, just do Manningtree and then go north west from there
There's a bikers cafe on Walton sea front that's an experience.
Find I need a destination and then that gets me out and aboutv8-powered wrote: Fri Aug 02, 2024 6:53 pm I really must drag my bike out and ride some local roads with you guys, I've only ridden to the MOT centre and back this year!
