Never mind all this Bracknell business Mango....get tapping! Enough distraction activities.mangocrazy wrote: ↑Fri Sep 15, 2023 1:48 pmI'm intrigued - where is the Bracknell reference on that site? Or am I just being a bit thick and you're cracking a joke...?Supermofo wrote: ↑Wed Sep 13, 2023 7:30 pmIt's obvious that the ice caps are melting due to measuring the temps on a housing estate in Bracknellmangocrazy wrote: ↑Wed Sep 13, 2023 6:09 pm
The 0.14 deg increase is in degrees F from 1880 to 1981. The rate of warming since 1981 is more than twice as fast: 0.32° F (0.18° C) per decade.
Source: https://www.climate.gov/news-features/u ... emperature
When the media narrative goes awry...
- Has thanked: 6375 times
- Been thanked: 4746 times
Re: When the media narrative goes awry...
- Has thanked: 2402 times
- Been thanked: 3625 times
But, but, but... distraction activities are what I'm best at!Count Steer wrote: ↑Fri Sep 15, 2023 1:52 pm Never mind all this Bracknell business Mango....get tapping! Enough distraction activities.
Probably a lot better than I am at drilling and tapping..,
- Has thanked: 1507 times
- Been thanked: 1410 times
ABC World News actually mentioned the condition of the dams last night without talk of rising sea levels. I assume some grown up at the network heard the original report & kicked some sense into the dull fuck on the spot.Supermofo wrote: ↑Fri Sep 15, 2023 8:00 am https://www.bbc.co.uk/news/world-africa-66799518
Does sounds like the dams are very likely suspects. Record rainfall wouldn't have helped though. Looking at the pics/satellite images it looks like something from a war zone the poor bastards
- Has thanked: 4359 times
- Been thanked: 2850 times
Only reason the temp is going up is cos they are measuring it in different places apparently. I assume the ice caps have noted this and melted in panic rather than the temps are actually going up.mangocrazy wrote: ↑Fri Sep 15, 2023 1:48 pmI'm intrigued - where is the Bracknell reference on that site? Or am I just being a bit thick and you're cracking a joke...?Supermofo wrote: ↑Wed Sep 13, 2023 7:30 pmIt's obvious that the ice caps are melting due to measuring the temps on a housing estate in Bracknellmangocrazy wrote: ↑Wed Sep 13, 2023 6:09 pm
I don't suppose they raised the question that maintenance of infrastructure had gone out of the window after NATO tore the country in two by supporting the rebels? No? Thought not.ZRX61 wrote: ↑Fri Sep 15, 2023 4:28 pmABC World News actually mentioned the condition of the dams last night without talk of rising sea levels. I assume some grown up at the network heard the original report & kicked some sense into the dull fuck on the spot.Supermofo wrote: ↑Fri Sep 15, 2023 8:00 am https://www.bbc.co.uk/news/world-africa-66799518
Nope, altho they hinted at problems caused by the country having two governments.
There's a term for measuring temps in between large buildings surrounded by concrete instead of out in a field, but it escapes me right now. The temp swings are very noticeable* riding across town here in the desert at night during Winter. We have huge open spaces in town with no buildings. Warm when riding in the built up areas, quite nippy crossing the open spaces between the built up areas.
* as in would be comfortable riding in a Tshirt in the build up areas, but needing several layers in the open areas.
- Has thanked: 2940 times
- Been thanked: 1882 times
Urban Heat Island effect
- Has thanked: 2550 times
- Been thanked: 6241 times
The term is "measuring temps in between large buildings surrounded by concrete instead of out in a field". HTH.
- Has thanked: 221 times
- Been thanked: 878 times
My 3 dogs are something like 170kg between them. Greta will be crying......Mr. Dazzle wrote: ↑Wed Sep 13, 2023 4:40 pm Ask a vaguely technical question and the only response you can believe is "it depends"
https://www.ed.ac.uk/impact/research/on ... alculation.
I think it's fair to say a carnivorous pet is significant from a CO2 point of view. Get yourself a good mouser though and you won't have to feed it. Or listen to bird song any more.
