Aye, the actual car engine was pretty awful even by 1970s standards.Mr. Dazzle wrote: ↑Wed Aug 02, 2023 7:23 amAFAIK they made a proof of concept with a pug engine but then developed their own for the actual K100?Bigjawa wrote: ↑Wed Aug 02, 2023 12:31 amYeah, it was the old suitcase engine that was in loads of old late 70s froggy stuff, it was built to lie nearly horizontal in the car, so lying it flat wasn't a problem.Count Steer wrote: ↑Tue Aug 01, 2023 9:34 pmNever knew this but the K100 engine was based on a Peugeot car engine apparently.
What's your "i think i'm the only person that likes these" bike ?
- Has thanked: 221 times
- Been thanked: 878 times
Re: What's your "i think i'm the only person that likes these" bike ?
I've got a 911cc race engine for one sat in my garage, I really should get round to putting it in my FZporter_jamie wrote: ↑Wed Aug 02, 2023 7:27 amI do like fz750s. I had a fully faired one but the half faired one is much nicer. There's a few resto mod 750s around with 17" wheels and posh suspension and they look really cool imo.Bustaspoke wrote: ↑Tue Aug 01, 2023 10:16 am Maybe my Gen 1 FZ750 in Lawson colours.Back in the day everyone gushed about Suzuki GSXR 750's,I also liked them but being a contrary fecker I didn't want a Gixxer like everyone else,I wanted a FZ750.
Mines currently parked up in a corner of the man cave awaiting a resto
I could write a long list of bike's that are popular but hold no appeal to me..
- Has thanked: 1295 times
- Been thanked: 872 times
I’ve also heard the earlier Ks had unpinned piston rings letting oil seep past when leant to the left on the sidestand,later models had pinned rings but this didn’t totally cure it.David wrote: ↑Wed Aug 02, 2023 10:20 amIt's because the oil settles over the valve stems when they stop. As the motor cools the cylinder on the compression stroke starts to pull oil past the valve stem seals due tovthe partial vacuum created. Plus as the seals and valves wear, the oil can enter the cylinder anyway.Count Steer wrote: ↑Wed Aug 02, 2023 7:38 amMy abiding memory of mine (later 1200 version) was the very brief puff of blue smoke on starting after it had been stood for a while. I was told 'they all do that when they've got a few miles on because of the angle of the engine'. Never did work out if it was true, or why.Bigjawa wrote: ↑Wed Aug 02, 2023 12:31 am
The BMW engine was reliable though, the car one ate head gaskets. I remember pulling the engine out of a Renault 14 with my Uncle when I was about 13, to go into a Talbot Samba.
I’ve got an 87 which can smoke like an absolute bastard if left on the sidestand, using the centrestand or a block of 2x4 under the sidestand cures this.
To leave it in a corner all sealed up until I've finished everything else, I bought it for when my 65,000 mile standard FZ engine dies, but it didn't die, it keeps on running as fast as ever.Potter wrote: ↑Wed Aug 02, 2023 2:38 pmSo what's the plan?Le_Fromage_Grande wrote: ↑Wed Aug 02, 2023 11:34 am
- Has thanked: 2636 times
- Been thanked: 1523 times
Covers most bases... just needs some pop-out wings!
- Has thanked: 6198 times
- Been thanked: 5088 times
They fix it on the 11s and 12s.David wrote: ↑Wed Aug 02, 2023 10:20 amIt's because the oil settles over the valve stems when they stop. As the motor cools the cylinder on the compression stroke starts to pull oil past the valve stem seals due tovthe partial vacuum created. Plus as the seals and valves wear, the oil can enter the cylinder anyway.Count Steer wrote: ↑Wed Aug 02, 2023 7:38 am
My abiding memory of mine (later 1200 version) was the very brief puff of blue smoke on starting after it had been stood for a while. I was told 'they all do that when they've got a few miles on ...
'Fixed' as in the early 100s often used to leave a 1/4 mile plume of smoke as you rode away
- Has thanked: 6382 times
- Been thanked: 4763 times
Yup. It was just the briefest bit of smoke on my 12 if I left it on the side stand...which I did quite often being lazy (weedy ) and the LT being just a tad lardy.Horse wrote: ↑Wed Aug 02, 2023 6:13 pmThey fix it on the 11s and 12s.David wrote: ↑Wed Aug 02, 2023 10:20 amIt's because the oil settles over the valve stems when they stop. As the motor cools the cylinder on the compression stroke starts to pull oil past the valve stem seals due tovthe partial vacuum created. Plus as the seals and valves wear, the oil can enter the cylinder anyway.Count Steer wrote: ↑Wed Aug 02, 2023 7:38 am
- Been thanked: 7537 times
My brick 1200 was the easiest bike to get on the centre stand I've ever had, I could do I one handed!
Anyone 9 1/2 stone upwards can do it easily.KungFooBob wrote: ↑Wed Aug 02, 2023 6:49 pm My brick 1200 was the easiest bike to get on the centre stand I've ever had, I could do I one handed!
The knack is to use body weight - 'hop' on the stand. Handle is only used for the initial tug to help get it moving.
If it feels like a back-straining lift, put it back down and reset.
OK. Just lazy (you had to take it off the centre stand too).
Reverse gear was nice.
(It always went on the centre-stand when parked up at home).
