Result! I'm pretty sure as the brakes are,I'd wait to fall off after hitting the dog.mangocrazy wrote: Thu Jul 20, 2023 2:17 pm I was able to lock the front and fall off when a dog ran out in front of me...
Kawasaki H1 1971
- Been thanked: 14167 times
Re: Kawasaki H1 1971
- Has thanked: 245 times
- Been thanked: 1224 times
- Contact:
An 8” (or nearly 8”) twin leading shoe brake should work well enough for sensible road riding, though it’ll get hot if you have racing daydreams and brake into all the corners.
Obviously it has to be adjusted so that both shoes actually meet the drum, but even then linings can take a few hundred miles to bed into the exact curvature.
- Has thanked: 2536 times
- Been thanked: 4122 times
^^^^JackyJoll wrote: Thu Jul 20, 2023 2:35 pm Obviously it has to be adjusted so that both shoes actually meet the drum, but even then linings can take a few hundred miles to bed into the exact curvature.
This.
Good luck doing it though, it's a fiddly job and very easy to make the braking performance worse. I'd be inclined to get some engineer's blue, paint it on the drum, reassemble, ride it for a bit and see if all the blue has been cleaned off. That would be a start.
- Has thanked: 7926 times
- Been thanked: 5591 times
Puzzled. That will tell you if the drum is out of round ie if part never touches the pads but if part of the pads touches the drum (across the width of the drum) and the drum is round won't that clean all the blue off?mangocrazy wrote: Thu Jul 20, 2023 2:43 pm^^^^JackyJoll wrote: Thu Jul 20, 2023 2:35 pm Obviously it has to be adjusted so that both shoes actually meet the drum, but even then linings can take a few hundred miles to bed into the exact curvature.
This.
- Has thanked: 19270 times
- Been thanked: 4903 times
Sounds blooming awesome! Love to read about making someone smile THAT much!!!
(I know, the smile goes all through
Yes, I was suggesting that to test roundness of the drum. If you want to test whether all the shoe surface is touching the drum it might be possible to paint the shoes, but the blue would probably soak into the shoe material and negate the test. It might also cause the brakes to grab violently, throw you off and kill you.Count Steer wrote: Thu Jul 20, 2023 2:57 pmPuzzled. That will tell you if the drum is out of round ie if part never touches the pads but if part of the pads touches the drum (across the width of the drum) and the drum is round won't that clean all the blue off?mangocrazy wrote: Thu Jul 20, 2023 2:43 pm^^^^JackyJoll wrote: Thu Jul 20, 2023 2:35 pm Obviously it has to be adjusted so that both shoes actually meet the drum, but even then linings can take a few hundred miles to bed into the exact curvature.
This.
Good luck doing it though, it's a fiddly job and very easy to make the braking performance worse. I'd be inclined to get some engineer's blue, paint it on the drum, reassemble, ride it for a bit and see if all the blue has been cleaned off. That would be a start.ie it won't tell you if all the pads surface is in contact. Am I missing something?
Perhaps...
- Contact:
- Ian
- Has thanked: 1334 times
- Been thanked: 573 times
Also you said it's 'only' done 800 miles since a total rebuild
If the pads are pretty hard you may still not have full contact across the whole pad as others have suggested
If you take the wheel out you will see where contact is occurring on the shores without resorting to blue, it will be darker and shinier where it has made contact
You could find someone to reline them with a softer compound ( or AM4 asbestos for the win, none of this modern shite )
Glad you are enjoying it
asmethurst99
- Has thanked: 1316 times
- Been thanked: 481 times
What would be the symptoms?JackyJoll wrote: Thu Jul 20, 2023 6:14 pm You’ll know if the drum is out of round, when you try to brake.
- Has thanked: 12466 times
- Been thanked: 8460 times
Bart is a fat guy. Marj has blue hair.mangocrazy wrote: Thu Jul 20, 2023 9:07 pmWhat would be the symptoms?JackyJoll wrote: Thu Jul 20, 2023 6:14 pm You’ll know if the drum is out of round, when you try to brake.
- Contact:
On-off-on-off juddering.mangocrazy wrote: Thu Jul 20, 2023 9:07 pmWhat would be the symptoms?JackyJoll wrote: Thu Jul 20, 2023 6:14 pm You’ll know if the drum is out of round, when you try to brake.
I’m surprised at the need for explanation. When you have the juddering going on when you brake, that’s when you address the oval drum problem.
It's been nearly 50 years since I rode a bike with a drum front brake, and I can't remember ever experiencing that kind of sensation. So not really surprising.JackyJoll wrote: Thu Jul 20, 2023 11:08 pmOn-off-on-off juddering.mangocrazy wrote: Thu Jul 20, 2023 9:07 pmWhat would be the symptoms?JackyJoll wrote: Thu Jul 20, 2023 6:14 pm You’ll know if the drum is out of round, when you try to brake.
- Has thanked: 5889 times
- Been thanked: 3536 times
Skub, that looks and sounds great (experience and sound).
As it's 1971 you can blitz around the ULEZ stinking up the place with 2 stroke goodness
Not much of a holiday mind
Tom Pemberton was the only person I remember who could race these competitively. I did run in the same race once at Brands hatch. He won easily enough and I was placed somewhere about half a lap behind on a Honda 500 four. ( Long lap on the Brands full circuit !)
- Has thanked: 7531 times
- Been thanked: 5870 times
On my Z1 I had high bars,a worn rear tyre and a topbox,I'd only have been about 10 stone too. It bucked me off at around 120mph.
The perfect storm.
Tony Dunnell was leading the 1969 500cc Proddy TT by a fair margin and looked set to win until his H1 spat him off at the 33rd milestone on the 2nd lap...
The most spectacular one I recall was an early Fireblade going into one and ejecting the rider down Bray hill at a rate of knots.mangocrazy wrote: Sat Jul 22, 2023 2:28 pm Tony Dunnell was leading the 1969 500cc Proddy TT by a fair margin and looked set to win until his H1 spat him off at the 33rd milestone on the 2nd lap...
