Yeah,there's a definite element of those things at work. I'd have been horrified to rear end another bike.Horse wrote: ↑Fri May 26, 2023 4:01 pmMaybe not. There's a possibility that by choosing to ride at his pace, you mentally went into low power mode and didn't do some of the 'what if?' planning that you would have usually done. So your reaction time would have been slower. Also, your braking would have been affected by the presence of the other bike and that you couldn't be sure what he would do.
I can't go round corners anymore?
- Has thanked: 9836 times
- Been thanked: 10149 times
Re: I can't go round corners anymore?
- Has thanked: 10276 times
- Been thanked: 6891 times
- Has thanked: 6198 times
- Been thanked: 5089 times
Less time out in the danger.
[/quote]
Trade off is possibly more danger within that time
[/quote]
Damn your logic hoss.
- Has thanked: 459 times
- Been thanked: 235 times
Makes sense to me. To turn right you push the right hand bar which turns the wheel to the left, hence counter steer to the left.Wossname wrote: ↑Thu May 25, 2023 11:51 amI’ve never heard that instruction. It’s always been ‘push right to turn right’, which seems fairly straightforward.Screwdriver wrote: ↑Thu May 25, 2023 10:02 am
I find that is the best way to describe counter steering without the confusing instruction to "turn right to go left". Just use your shoulder to steer you where you want to go.
The latest version, and probably lots of earlier ones, of the IAM’s Roadcraft has a diagram showing a bike approaching a right hand bend. The advice in a little box is, at this point, ‘counter steer left’.
Eh?
I can assure that yesterday I spent hours positive steering
My arms ached to prove it.
Only time counter steered was on the long fast bends when I had the back end hanging out chucking crap up at the lads behind me
Only wish I could slide the back end on tarmac
And this why people steer clear (sorry ) of SS ...westers151 wrote: ↑Mon May 29, 2023 11:56 amMakes sense to me. To turn right you push the right hand bar which turns the wheel to the left, hence counter steer to the left.Wossname wrote: ↑Thu May 25, 2023 11:51 amI’ve never heard that instruction. It’s always been ‘push right to turn right’, which seems fairly straightforward.Screwdriver wrote: ↑Thu May 25, 2023 10:02 am I find that is the best way to describe counter steering without the confusing instruction to "turn right to go left". Just use your shoulder to steer you where you want to go.
the IAM’s Roadcraft has a diagram showing a bike approaching a right hand bend. The advice is, at this point, ‘counter steer left’.
It really is as simple as:
Press left, go left
Press quickly, lean quickly
Press longer, lean further
Then relax the pressure
- Has thanked: 1750 times
- Been thanked: 2085 times
I had a go at this "consciously counter steering" malarkey, didn't like it. I'd rather lean into the bend and let the bike do the steering. It's only to get the initial tip.
Whatever you do, never counter steer the whole bend.
- Has thanked: 229 times
- Been thanked: 575 times
SS?Horse wrote: ↑Mon May 29, 2023 1:37 pmAnd this why people steer clear (sorry ) of SS ...westers151 wrote: ↑Mon May 29, 2023 11:56 amMakes sense to me. To turn right you push the right hand bar which turns the wheel to the left, hence counter steer to the left.
Press left, go left
Sorry, inaccurate typing on the phone: SA - Staying Alive.
It's still you doing it
Yup. You lean the bike. When it's over enough, take the pressure off and the front wheel will turn the side it's leaning. Then you're into the corner.
Sortof
If its a tightening spiral, you'll need to keep leaning further over (unless you slow down and left gravity lean it a bit further). Even on a constant radius, if you accelerate then you'll need to kean further.
