Snatchy throttles
A_morti
- Has thanked: 412 times
- Been thanked: 824 times
Re: Snatchy throttles
In scenario 2, the rpm will only be high if I'm giving the TPS a signal of >0. Then it should match that, but at the same time I want it to give *at least* enough to keep the engine at idle. Which is what I believe it's doing.
The bike must think hands are off the clutch rn, as it won't start in gear. Past that, IDK how the switch works. After riding the bike through town to work today, I'm not in a hurry to plug it back in.
The rpm will be high just 'cause the engine is spinning? it's got an engine speed sensor so it knows which part of the map it's on.
A_morti
@Screwdriver I suspect it's a different case on that bike than on mine, as I assume that won't have been a Euro 4 bike, so it wouldn't have been a problem specific to deceleration fuel cut?
A_morti
@Mr. Dazzle I think I'm picking up what you're putting down, now. I may have it backwards. It won't start in gear so it must think clutch is engaged. I want it to think clutch is disengaged.
Either way I'd swear it's riding better.
I'll try a direct back to back test this afternoon.
- Been thanked: 9495 times
A_morti
Unbolting is kind of a swine, you have to remove the lever and get all greasy pulling the switch through.
Putting a bit of paper clip in there is easy though
A_morti
Do you suppose rather than just being 0/1 it's clever enough to be aware that the switch is unplugged? Maybe it has a resistor in there and sees it or not? That way if it saw no switch, it could default to the safest option.
Idk... Will have a look later.
There's always the 'problem' that EFI is able to respond much more quickly than carbs. When you open the throttle on a carb bike (assuming you're got CV carbs) there's an inherent delay and 'softening' of the power because it takes a finite amount of time for the vacuum to build up and hence lift the needles. In fact, if you consider how snappy slide carbs can feel, you'll see what I mean. Yamaha actually fitted carb style vacuum operated slides to the early EFI R1s, did they not?
EFI on the other hand goes "you wanna open the throttle? Let's open the throttle! - here have some petrol!!!". It's doubly difficult on a bike (vs. a car) because bikes often don't have an air flow meter (in fact, I don't think I've even seen a bike with one?) so the ECU only has the rpm and throttle position to go on.
Part of the advantage / point of FBW is that when you come off/one the throttle the ECU is able to regulate what the butterflies are doing in a less on/off fashion.
Gregor
- Has thanked: 1756 times
- Been thanked: 1153 times
Early BMW K100s have an air flow meter.Mr. Dazzle wrote: Thu Oct 13, 2022 2:44 pm There's always the 'problem' that EFI is able to respond much more quickly than carbs. When you open the throttle on a carb bike (assuming you're got CV carbs) there's an inherent delay and 'softening' of the power because it takes a finite amount of time for the vacuum to build up and hence lift the needles. In fact, if you consider how snappy slide carbs can feel, you'll see what I mean. Yamaha actually fitted carb style vacuum operated slides to the early EFI R1s, did they not?
- dern
- Has thanked: 1183 times
- Been thanked: 2277 times
The 1150gs was the worst throttle response of any bike I've ridden. It made the superduke feel like a superdream.
- Has thanked: 8036 times
- Been thanked: 5694 times
Did you ever ride someone else's? Never noticed anything snatchy on mine or heard anyone complain about theirs. Sounds like something had either been 'tweaked' or was out of whack. R1200 was slightly smoother generally but not a world away..dern wrote: Thu Oct 13, 2022 8:37 pm The 1150gs was the worst throttle response of any bike I've ridden. It made the superduke feel like a superdream.
- dern
No but putting a booster plug or getting a remap was common talk on the forums for those bikes. It was a shocking bike in terms of reliability but the fueling was the worst experience.Count Steer wrote: Thu Oct 13, 2022 8:47 pmDid you ever ride someone else's? Never noticed anything snatchy on mine or heard anyone complain about theirs. Sounds like something had either been 'tweaked' or was out of whack. R1200 was slightly smoother generally but not a world away..dern wrote: Thu Oct 13, 2022 8:37 pm The 1150gs was the worst throttle response of any bike I've ridden. It made the superduke feel like a superdream.
- dern
I fitted the throttle spacers to the 1190 adv and did a couple of hundred miles on it over the weekend. It wasn't as snatchy as the 1290 sd but was still not brilliant. It's made more of a difference to the 1190 and I wish I'd done it when I bought it. It felt a lot more predictable in the wet leaves and rain. Best ten quid spent.
- Has thanked: 4088 times
- Been thanked: 2513 times
On my Gen II SV650 you can short the clutch switch to get you home,( I've done it myself) but it affects the fueling. It comes up often on the forums as a lot of SV's get used on track & modify the looms.A_morti wrote: Thu Oct 13, 2022 10:21 am @Mr. Dazzle I think I'm picking up what you're putting down, now. I may have it backwards. It won't start in gear so it must think clutch is engaged. I want it to think clutch is disengaged.
Not sure how it affects Honda's.
Here's something from one of the SV forums;
Default Re: Clutch switch start
Dont bypass the clutch switches on the injected SV or any other injected Suzuki. Even if bypassed the bike will run in a neutral ignition and gear map loosing performance and in some cases like the GSXR1000, revs. The GSXR600 is particulary one that reacts badly to it making circa 80-90bhp with it bypassed.
I was reading reviews on the Kawasaki Z900RS last week & the common complaint/fault with the bike is the snatchy, on/off throttle on the earlier versions,cured by flashing the ECU.I'll have a demo on one in the spring & decide if I want to swap the Street Triple...dern wrote: Thu Oct 13, 2022 8:37 pm The 1150gs was the worst throttle response of any bike I've ridden. It made the superduke feel like a superdream.
- Has thanked: 2317 times
- Been thanked: 1822 times
Not read the whole thread but you can have my 2 penneth anyway
I had a Gen 1 990 Superduke which many people criticised for snatchy throttle.
I never had a problem with it... ever
However my previous bike was a KTM625 SMC which had got me into the habit of feathering the clutch on slow speed stuff.
Maybe it's worth giving that a go? I f you like the part apart from that one thing, it's go to be worth a shot?
- dern
I had a 990 SD and that was quite bad at low speeds but sort of ok most other places. I didn't get on with it though. It was better than the 1290 is that regard though.
