Suspension Help
- Been thanked: 4125 times
Re: Suspension Help
It sounds like the damping has gone in the rear shock if it's chucking you out of the seat.
- Trinity765
- Has thanked: 2442 times
- Been thanked: 2398 times
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
Re: Suspension Help
No it isn’t , give Sarah a call now as she is expecting to hear from youTrinity765 wrote: ↑Mon Jun 20, 2022 11:29 am It's booked in with Steve Jordans 1st August - that was the earliest they had.
- Has thanked: 10280 times
- Been thanked: 6892 times
Re: Suspension Help
Is that such a thing ? I've seen many front forks with blown seals, but never seen a leaking shock. Maybe I've missed out
Re: Suspension Help
I can send you a couple in the post, both from 30 year old Yamahas, FZ750 widdled it all out on the garage floor, FZR400 just had a mild leak.
I've also had an XR250 blow it's seal out mid enduro, I spent the next two hours being smacked in the arse by the seat through the whoops, and my 86 KTMs White Power shock used to regularly blow the seal, despite only being two years old.
- Trinity765
Re: Suspension Help
Bigyin wrote: ↑Mon Jun 20, 2022 11:38 amNo it isn’t , give Sarah a call now as she is expecting to hear from youTrinity765 wrote: ↑Mon Jun 20, 2022 11:29 am It's booked in with Steve Jordans 1st August - that was the earliest they had.
It's not what you know.............Thank you so much - If everything keeps working out as it has been working out (for the best) I'll be able to buy you a beer at Pembery
Booked in for 7th July.
Re: Suspension Help
Just a wee half for the big Sweaty JessieTrinity765 wrote: ↑Mon Jun 20, 2022 11:49 amBigyin wrote: ↑Mon Jun 20, 2022 11:38 amNo it isn’t , give Sarah a call now as she is expecting to hear from youTrinity765 wrote: ↑Mon Jun 20, 2022 11:29 am It's booked in with Steve Jordans 1st August - that was the earliest they had.
- Bigyin
Re: Suspension Help
Glad it worked out and could help.Trinity765 wrote: ↑Mon Jun 20, 2022 11:49 amBigyin wrote: ↑Mon Jun 20, 2022 11:38 amNo it isn’t , give Sarah a call now as she is expecting to hear from youTrinity765 wrote: ↑Mon Jun 20, 2022 11:29 am It's booked in with Steve Jordans 1st August - that was the earliest they had.
- Has thanked: 2636 times
- Been thanked: 1523 times
Re: Suspension Help
I've seen a few rear shock seals fail. One of mine went, on a s/h bike soon after I bought it. IIRC, the chrome was rusty and I suspect I might have been a bit heavier than the original owner, or maybe riding it a bit harder, because it looked like I'd used more travel. I didn't pay much for it, so a replacement didn't break the bank
- Has thanked: 310 times
- Been thanked: 568 times
Re: Suspension Help
You certainly have missed out on some real excitement, by not (recently at least) owning any old knackered bikes.
When the oil pisses out your rear shock, it's prety much terrifying. The rear becomes a pogo stick, so you get bucked out the seat over bumps plus it becomes impossible to hold a line at any kind of speed. Sounds like what was described by the top poster, eh? You'd get similar symptoms from properly seized rear linkage bearings, or if some dickhead had "hilariously" wound all your damping settings out to zero or max, depending how much adjustment the shock had in it in either direction.
My money had been on seized steering neck bearings until the mention of getting bucked out the seat.
- Has thanked: 5455 times
- Been thanked: 13103 times
Re: Suspension Help
Outstanding work sir.Bigyin wrote: ↑Mon Jun 20, 2022 11:38 amNo it isn’t , give Sarah a call now as she is expecting to hear from youTrinity765 wrote: ↑Mon Jun 20, 2022 11:29 am It's booked in with Steve Jordans 1st August - that was the earliest they had.
Re: Suspension Help
That would be me...
...on my own bike.
I'd been to Spa and setting off on the way back, the rear end of the FZ750 was all over the place.
Only as I bounced slowly back in the direction of Blightly did the memory surface of me lying under the bike at 3am with a beer in one hand and demonstrating how easy it was to change the damping on my Ohlins!
When I got home I ended up phoning Steve Linsdell to get the factory settings, and worked around those till it felt right again!
Mind you, when I got the GSX-R750 a few years later, it was the previous owner who'd turned everything up to the max for that rigid frame feel.
- Trinity765
Re: Suspension Help
Just got back from Steve Jordans and it was money well spent!!! Thank you @Bigyin
My headrace bearings need replacing - which is probably what I could feel. He dropped the forks through the yoke so the front was a little more weighted. What with a new front tyre, it feels bloody marvellous.
I'll get the bearings done when I get new brake disks.
Re: Suspension Help
Get the bearings done as soon as you can, they'll get worse and the bike could become dangerous.
Re: Suspension Help
Interesting Thread - if it helps a bit and as you had such a belter of a time @ Pembrey last time... if it's Ok I'll get Will - our suspension specialist to do some work with you.
He's very experianced and does a lot of Road Bike Stuff - very friendly and his missus Sarah works with him as well - you'll have a great time.
All FOC - we'll foot the bill.
Cheers
Alan.
Cheers
Alan.
- Trinity765
