Re: Triumph Street Scrambler
Posted: Tue Jan 27, 2026 4:14 pm
Post New Year, too cold, wet, icy etc to head out and enjoy so it's about this time of year I generally set about tinkering with things.
Ever since modding the rear end a couple of winters ago I've been a bit meh regards the Lucas style rear light that came with the tail tidy I fitted.
It kind of floats out in mid air and sits at an odd angle.
It also did not have a clear section for the numberplate light, but the LEDs are white inside so back then I cut out a small section from the bottom and glued in a clear plastic 'lens' I made from a cassette case, most on here will have no problem remembering them.
I'd picked up a simple round retro rear light for peanuts last summer, it was less than a tenner, worth a punt.
I could mount this atop the mudguard and then the number plate could be shifted up to cover the Lucas light mounting and fitting a bit more snuggly under the rear mudguard.
Cheap it was so I swapped out the supplied nuts and bolts for some stainless hex head and nylock parts, used some stainless and black nylon washers to secure it to the mudguard.
Also cut a small section of some 3mm rubber sheet I had left over from making a mudguard extension for under the seat a few years back. Placed this between the light and the mudguard to help with vibrations.
I also needed to cut a small section of aluminium tubing to sit in the middle of the mounting bracket. When clamping the light in place onto the mounting bracket, the thin walled counter bracket on the light simply deformed so would not clamp tight. This short section of tube fits in the gap to give the clamp something to resist the nut and bolt deforming the bracket so it can be tightened up. Without this I'm 100% certain it would not be possible to get it tight enough to stop it rotating.
I still want to build up the courage to take an angle grinder to the rear subframe and fit a hoop, but as I said before I don't have the resources for that. There are a couple of kits available that I could buy that a are more shed build friendly, but they all include the seat, lights etc and cost a fortune with the cheapest £799.
Then in the end, yes I'd have the chopped rear, but it would be a serious chunk of change and not really be a one off cheap and cheerful mod like all of the other things I have done.
So for now I'll head into the 2026 riding season with a slight change in the look, and still the itch to keep tinkering.
