Abba stands?
Beancounter
Has thanked: 3126 times
Been thanked: 684 times
Re: Abba stands?
Post by Beancounter »
Taipan wrote: Mon Oct 31, 2022 12:41 pm
Skub wrote: Tue Oct 25, 2022 5:10 pm
Taipan wrote: Tue Oct 25, 2022 1:53 pm I've finally used my abbastand and I'm quit impressed at how much more accessible it makes the bike over a paddock stand. Thinking of adding the front wheel lift, as it looks like a good accessory for it. Anyone got one? Happy with it?
The front stand works ok for most bikes,but I found with mine it was hard to get your body weight over the rear end at the same time as pulling tight on the strap. There's probably a technique,but I didn't use mine enough to perfect it. Should be ok with the Yam,I think my bike carries a lot of weight on the front.
Sadly it isn't. I cant seem to lift the front and pull the strap at the same time. Think I'll have to trolley jack it up then secure it with the strap! :roll:
The previous 'front lift' incarnation was better in my opinion - it was simply a 'J' shaped tube with castors, wheel under the sump and push down to lift the bike. Simples but probably not as secure as the current strap arrangement.
Keep meaning to take the GS to them to see if I can find an appropriate fitting kit for it.
Re: Abba stands?
Taipan wrote: Mon Oct 31, 2022 12:41 pm *edit* Managed it easily once i'd put the strap through the clasp the right way round! :roll:
That's half the battle!
Re: Abba stands?
Pretty impressive set up for what it costs. I certainly prefer it to being up on front and rear paddock stands. I’ll leave it on there overnight and clean it tomorrow! :o
I finished and was just taking my tools though the door when it pissed down! I was proper chuffed to have got in done snd missed the rain. Then I saw I’d locked the shed but left the lawnmower out! D’oh!
GuzziPaul
Has thanked: 59 times
Been thanked: 195 times
Re: Abba stands?
Post by GuzziPaul »
As well as the front lift I also have the uneven ground base. They are about 10 miles from me and got it at the same time as the front lift. My hydraukic bench is too narrow to use the stand, but with the base bolted to it I can get the Tuono up on it. I also have a blue stand which was left over from a bike show in about 2005.
This phot was taken this weekend
abba stand.jpg (319.26 KiB) Viewed 405 times
