Chain lube/wax/paste
Has thanked: 2636 times
Been thanked: 1523 times
Re: Chain lube/wax/paste
mangocrazy wrote: Tue Mar 23, 2021 2:39 pm I wasn't being entirely serious. I had hoped the smiley might convey that.
I agree with most of what you say, but trying to keep road grit off a chain is simply a doctrine of perfection. My answer is a Scottoiler. That keeps the O/X/W rings lubricated and isn't overly sticky.
Fair do's re smiley tho people often use them for the opposite reason. A lot of riders DO think "the stickier the better" and simply spray on more gloop over the nasty mess that's already on the chain.
Scottoilers are good (if expensive), I've used a home-made version in the past.
Has thanked: 4362 times
Been thanked: 2852 times
The Spin Doctor wrote: Tue Mar 23, 2021 2:46 pm
Yeah that was my problem as well with some of the waxes. Especially in summer when the b-roads are dusty the chain would attract a lot of dust.
Hoping I can get on with the Tutoro, just don't like flicks on oil on the tyre :evil: And I don't think I'll stop that.
Been thanked: 2617 times
Has anyone on here tried dry graphite lube? Used by the desert racers, but I wonder if it works on road bikes well enough to be worth it.
Has thanked: 2552 times
Been thanked: 2286 times
The Spin Doctor wrote: Tue Mar 23, 2021 12:57 pm What you see on the outside is - AFAIK - designed to stop the chain rusting in shipment and storage.
If you rode 500 miles in the wet, why didn't you do something about it? Don't blame Honda!
I lubed it about as much as I used to on the Bonnie and the VFR, ie checked it every 1000 miles or so and lubed it if it looked as though it needed it. After a service when I knew it had been properly lubed I might leave it a bit longer.
Cousin Jack wrote: Tue Mar 23, 2021 4:35 pm
I might think about changing your lube. The chain on my XJ is about four years old, and topping 30k miles and despite standing for 5 months there's no rust on it. Did you watch the FortNine video?
Thanks, I've only ever used dry in locks and the like.
Has thanked: 5451 times
Been thanked: 13087 times
My Silkolene has just arrived
Has thanked: 15957 times
Been thanked: 10248 times
Based on that video, is no one else going for gear oil then?
Taipan wrote: Thu Mar 25, 2021 9:07 am Based on that video, is no one else going for gear oil then?
NOt really watched it matey. I went with Silkolene because i respect Trickys knowledge and my Wurth Dry Lube experience hasn't filled me 100% with happiness.
Has thanked: 261 times
Been thanked: 1265 times
It smells.
JackyJoll wrote: Thu Mar 25, 2021 10:06 am
It smells.
I'm putting it on the chain not using it as after shave? :wtf:
:D
Has thanked: 2551 times
Been thanked: 6247 times
Historically I've used engine oil quite a lot. As above, the main thing is cleaning so I clean with good old fashioned paraffin and lube with oil....gear oil would make a bit more sense though.
My method also flings quite a lot!
I've also used WD40s dedicated spray stuff too, but as above being clean it what really matters.
Mr. Dazzle wrote: Thu Mar 25, 2021 10:13 am My method also flings quite a lot!
This is why I haven't used gear oil. And the problem I'm getting with the Tutoro. Probably nothing wrong with it, but don't like even odd flicks of oil onto the road surface of the tyre.
Supermofo wrote: Thu Mar 25, 2021 11:13 am
My classic Triumph has (or rather, is supposed to have) a system to spray hot engine oil on the chain. Dunno what you're worried about :D
See how the return line also has a little tee off to the drive chain...
Mr. Dazzle wrote: Thu Mar 25, 2021 11:14 am My classic Triumph has (or rather, is supposed to have) a system to spray hot engine oil on the chain. Dunno what you're worried about
I've noticed a few classics wear the chain is soaked in wet oil, that's probably why then!
I think on a lot of bikes the tutoro isn't so bad, but think cos the Duke has narrow tyres it doesn't help.
Supermofo wrote: Thu Mar 25, 2021 11:35 am
It's 'cause the chains aren't sealed. Chains are 'roller chains', like this:
The rollers (5) are the bits which actually touch the sprockets, they're supposed to stay still relative to the sprocket and spin around on their pins (3). That way there's never any sliding/scraping between parts and eveything runs efficiently and last a long time. That's why chains are so common - they're very efficient 'cause they only use rolling contacts, never sliding (when they're working properly that is).
The rollers are lubricated by something, either grease packed in there, solid bushes (4) or oil. Modern O-ring and X-ring chains seal that oil/grease in (replacing bush 4 in the pic). Ideally that grease does everything and you don't ever need to lube the chain. Older vehicles use unsealed chains which need periodic lubricaiton to replace the stuff that's escaped. Things like timing chains also use the same principals, but they can be unsealed 'cause they run inside a clean engine with a steady supply of fresh oil.
Been using it for years... chains last 30-odd thousand miles.
Has thanked: 2405 times
Been thanked: 3630 times
Mr. Dazzle wrote: Thu Mar 25, 2021 12:19 pm It's 'cause the chains aren't sealed. Chains are 'roller chains', like this:
All motorcycle final drive chains are roller chains. It's just that modern chains use O/X rings to keep factory lube sealed inside whereas on older style chains there was a gap between the outer rollers and the side plates to permit primitive (and largely inefficient) lubrication of the inner/outer roller interface. Which is why Linklyfe was A Thing.
That's what I said isn't it?
I'd go further and say you're unlikely to find a chain of any sort that isn't a roller chain. 'Cept maybe the one on your bog handle.
Boat anchor chains, security chains, blockchains, to name but three.
