Electric bikes, the next step
Scootabout
- Has thanked: 587 times
- Been thanked: 373 times
Re: Electric bikes, the next step
By the way, Santa kindly dropped one of https://www.decathlon.co.uk/p/electric- ... rget%20300these off early for me.
For urban use, they're brill.
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Whatever the next stop is, I don't think it's one of these:
https://thedriven.io/wp-content/uploads ... 00x450.jpg
https://thedriven.io/2020/12/15/austral ... otorcycle/
- Been thanked: 15503 times
- Has thanked: 602 times
- Been thanked: 4529 times
Would you pay £12.5K for a lardy SV650 that has to be charged overnight between rides?
No, but i don't believe i'm their target market.Le_Fromage_Grande wrote: Thu Dec 17, 2020 3:38 pmWould you pay £12.5K for a lardy SV650 that has to be charged overnight between rides?
- G.P
- Has thanked: 1994 times
- Been thanked: 1283 times
0I think the first Leccy motorcycle I get will be a groovy little trailie for going to the shops (pub) and playing with on the ridgeway.
like a stage 2 eMTB but without bothering with Pedals
Given the rights of way laws in England and Wales you'd be better off with an EMTB, you could have a derestrictor for when you want to use it on "private" land and go faster.
- Has thanked: 2857 times
- Been thanked: 3514 times
Thankfully, I won't need to worry about these at my age.
Scootabout
But if you assume the variable element of the running cost is 2.5p per mile plus 1p for the belt wear plus 3p for tyres, whereas the SV would be maybe 12p per mile more than that, it starts to look more comparable. Break-even would be after about 50,000 miles, I think. I'm assuming fixed costs would be the same.Le_Fromage_Grande wrote: Thu Dec 17, 2020 3:38 pmWould you pay £12.5K for a lardy SV650 that has to be charged overnight between rides?
- Has thanked: 7630 times
- Been thanked: 5934 times
Servicing costs would be a tad lower too.Scootabout wrote: Thu Dec 17, 2020 10:15 pm
A_morti
- Has thanked: 412 times
- Been thanked: 824 times
It's lighter than an sv650.Le_Fromage_Grande wrote: Thu Dec 17, 2020 3:38 pmWould you pay £12.5K for a lardy SV650 that has to be charged overnight between rides?
And yes, I would.
It weighs 190kg, I think an SV is about 170A_morti wrote: Fri Dec 18, 2020 6:43 amIt's lighter than an sv650.Le_Fromage_Grande wrote: Thu Dec 17, 2020 3:38 pmWould you pay £12.5K for a lardy SV650 that has to be charged overnight between rides?
And yes, I would.
And on the running costs thing, if break even mileage is 50,000 miles, that's going to take a long time
Dry weight of an SV is 170kg, kerb weight is 190kg like the Zero.
Edit. Zeros website says 142kg kerb for the S...so much lighter than an SV650.
I got the 190 from the MCN report - should've known better
I reckon in any other context a 60bhp bike which weighs 140kg would have people all over it. Consider that the Duke 390 everyone loves is 10kg heavier and 15bhp less powerful. The leccy bike will be far gruntier too.
My Husqvarna 610 weighed about 140KG and made about 50BHP, it was great fun, with an electric motor you should be able to adjust the torque curve to whatever you want (within reason)
The only problems I see with the electric bike are price (it's easily twice what I'd be willing to pay for it) and refuelling, most supermotos only have ranges of about 60 miles, so this would be fine, but recharge time needs to be 30 minutes maximum.
If all the motorcycle manufacturers got together and came up with a common battery you could stop at a filling station and exchange the flat battery for a fully charged one (a similar process to gas bottles) and then the recharging problem would be solved.
A_morti
Dry weight of the Zero is a claimed 142kg. I guess you have to add fork fluid and brake fluid to that and probably get to around 145kg.Le_Fromage_Grande wrote: Fri Dec 18, 2020 9:21 amIt weighs 190kg, I think an SV is about 170A_morti wrote: Fri Dec 18, 2020 6:43 amIt's lighter than an sv650.Le_Fromage_Grande wrote: Thu Dec 17, 2020 3:38 pm
And yes, I would.
Apparently Suzuki claim 197kg wet for the SV with ABS. That has to include engine oil, coolant, battery acid, fuel, fork oil, brake fluid, etc.
50kg is a really big difference.
A_morti
www.electrek.co/2020/09/04/honda-yamaha ... eries/amp/Le_Fromage_Grande wrote: Fri Dec 18, 2020 11:01 am If all the motorcycle manufacturers got together and came up with a common battery you could stop at a filling station and exchange the flat battery for a fully charged one (a similar process to gas bottles) and then the recharging problem would be solved.
- Has thanked: 10967 times
- Been thanked: 3999 times
5 years -ish? How long do people normally keep commuting bikes?Le_Fromage_Grande wrote: Fri Dec 18, 2020 9:21 amIt weighs 190kg, I think an SV is about 170A_morti wrote: Fri Dec 18, 2020 6:43 amIt's lighter than an sv650.Le_Fromage_Grande wrote: Thu Dec 17, 2020 3:38 pm
And yes, I would.
Because that's what this is - a commute bike, there's little point (at the moment) in buying a leccy bike for 'fun'*, but for saving money over the life of a commuting bike they're ideal (regular journey of known length, charged overnight etc). I'm basically waiting for these things to start appearing on the 2nd hand market**.
* opinions vary.
** - well - I was. Pandemic inspired working from home has changed commuting requirements somewhat.
It's not a new idea, and it has been proposed, and I believe some are already going down this road.Le_Fromage_Grande wrote: Fri Dec 18, 2020 11:01 am If all the motorcycle manufacturers got together and came up with a common battery you could stop at a filling station and exchange the flat battery for a fully charged one (a similar process to gas bottles) and then the recharging problem would be solved.
The only real issue with it as an idea is that battery tech is changing so fast, as soon as you brought out that kind of infrastructure to the public, it'd be 2 generations out of date. Petrol hasn't changed (fundamentally) in nearly 100 years.
