I had simple, reliable, bespoke and standalone in mind. After fitting an aftermarket alarm once and it never quite working properly I want any solution to be simple and easily bypassed if you know how.MrLongbeard wrote: ↑Wed Apr 05, 2023 10:00 amStealth / Ghost Immobilizer, operates by means of a PIN code that's entered by any random buttons (of your choice) that are already in the vehicle
In todays news...
- Has thanked: 852 times
- Been thanked: 1226 times
Re: In todays news...
I wonder if those are the ones that look to me like they are on a dipped beam but still manage to be blinding.Mr. Dazzle wrote: ↑Wed Apr 05, 2023 12:01 pmMine goes one further than that. It's got megapixel resolution on the beam (the reflectors are arrays of microscopic mirrors) so it can draw boxes of dark around oncoming cars. It's bloody witchcraft, you get daymaker highbeam with little squares of black tracking the other cars.JamJar wrote: ↑Wed Apr 05, 2023 11:24 amMy new car has adaptive headlights that can dip a portion of the beam so that you have high beam on your side of the road but not in the face of incoming traffic ... bloody clever.Count Steer wrote: ↑Wed Apr 05, 2023 11:14 am Bit of a sideways thought but some cars used to have a foot operated dip/main beam, which actually seemed quite a good idea. (Bit irrelevant now cars can decide - quite often rather late - when you need to dip the beam).
Not sure who makes the system, several of the OEMs use it now under different brands.
- Has thanked: 2611 times
- Been thanked: 6015 times
No-one has flashed me yet.
Probably still trying to find the stalk after being blinded
I found this reply to a Skoda owner complaining he gets regularly flashed using matrix lights.Mr. Dazzle wrote: ↑Wed Apr 05, 2023 12:06 pm No-one has flashed me yet.
It doesn't look like full beam but is still dazzling, it might just be early ones that are bad.
Sensitivity setting is for light sensor, where matrix LED uses camera to detect cars. This setting should not affect matrix in any way.
I think problem with matrix LED (not only in Skoda) is the fact, that... other drivers are not used to them. What i mean, is that when passing a car with matrix, you can clearly see it's using long beam BUT you're not really dazzled. Many drivers are flashing, even though they are not dazzled.
So yes, matrix works as expected and is not dazzling, but you're being flashed by "overly sensitive" drivers, that are over-reacting.
Only situations where matrix do not work as expected are related to trucks. On some dual carriage roads, the barrier can block visibility of truck's lights to the camera, but it's driver is dazzled. On those roads system should not switch on high beam on the left (or right in UK) side to avoid this, but this is based on the sat-nav a believe, and not all roads seems to be marked correctly. Also when coming to a hill top, truck driver will be dazzled.
I was analyzing recordings from the dash cam, where i've been flashed, and i could clearly see, that matrix worked as expected, it was just other driver that was over-reacting.
- Potter
- Has thanked: 2216 times
- Been thanked: 4612 times
I don't find any of this stuff charming at all, I just want my lights to illuminate enough for me to not drive off the road or hit an object in my path, I don't want intelligent systems for things like this. I'm happy to operate them manually as long as there is a path for the electrons to flow.
That's gen 1 matrix too, if you will. Multiple bulbs in a grid/array, hence the name.
Mine is a single big bulb and a clever reflector. It can even project a funky animation on a wall (like a projector TV) but UK law doesn't allow it. Something about headlights being "constant" only.
It's not just a gimmick, driving on unlit roads at night it's amazing. Night becomes day.
- MrLongbeard
- Has thanked: 579 times
- Been thanked: 2289 times
Just pull a couple of coil packs, or fit one of them current limiting battery connectionsMussels wrote: ↑Wed Apr 05, 2023 12:02 pmI had simple, reliable, bespoke and standalone in mind. After fitting an aftermarket alarm once and it never quite working properly I want any solution to be simple and easily bypassed if you know how.MrLongbeard wrote: ↑Wed Apr 05, 2023 10:00 amStealth / Ghost Immobilizer, operates by means of a PIN code that's entered by any random buttons (of your choice) that are already in the vehicle
Yeah that's what mine does it's brilliant.Mr. Dazzle wrote: ↑Wed Apr 05, 2023 12:01 pmMine goes one further than that. It's got megapixel resolution on the beam (the reflectors are arrays of microscopic mirrors) so it can draw boxes of dark around oncoming cars. It's bloody witchcraft, you get daymaker highbeam with little squares of black tracking the other cars.JamJar wrote: ↑Wed Apr 05, 2023 11:24 amMy new car has adaptive headlights that can dip a portion of the beam so that you have high beam on your side of the road but not in the face of incoming traffic ... bloody clever.Count Steer wrote: ↑Wed Apr 05, 2023 11:14 am Bit of a sideways thought but some cars used to have a foot operated dip/main beam, which actually seemed quite a good idea. (Bit irrelevant now cars can decide - quite often rather late - when you need to dip the beam).
- Potter
I've just watched the latest Harrys Garage clip and he's with Gordon Murray, who is suggesting they're having a big rethink now because of the EU turnaround on ICEs, so that sublime Cosworth V12 might be around for a while longer yet.
- Has thanked: 10117 times
- Been thanked: 6649 times
- Has thanked: 626 times
- Been thanked: 4070 times
- Has thanked: 2322 times
- Been thanked: 3374 times
I certainly do. In fact I have one for my LC and am debating whether to fit it, or keep it original. From memory the Cibie was way better than Yam OE. With a modern LED bulb it would be even better.
The Cibie is a lot better than the standard LC light, I had one with a concave lens
Mine was/is standard convex I think. Back in a mo' - just checking...Le_Fromage_Grande wrote: ↑Wed Apr 05, 2023 3:37 pm The Cibie is a lot better than the standard LC light, I had one with a concave lens
- Has thanked: 5945 times
- Been thanked: 4933 times
Oh yes, superb. Fitted one to my 400Four - but had to use a headlamp shell from a Honda 750 to get the bigger diameter.
One of the mags did a comparison. The Z's dip beam was further than main on a Yam XS750!
I'm not sure it was a Cibie lens, it came in one of my LCs, worked better than the headlight my previous LCs had and someone told me it was Cibie, it was yellow
Concave was \_ patternLe_Fromage_Grande wrote: ↑Wed Apr 05, 2023 3:37 pm The Cibie is a lot better than the standard LC light, I had one with a concave lens
ZBeam had an extra 'drop' on the right, so it could be tilted higher without dazzling oncoming drivers.
Yep, standard convex. It was Cibie 'kit 911 - Z180 Halogen conversion'. Also fitted various Honda, Suzuki and Yamaha models of the day according to the box.
I believe that the Cibie Z beam range are still produced in France, but now branded as Valeo. I bought four of them for my Beta Spider and can switch hi/lo beam on all four units. High beam with four headlights is very impressive. And pisses off oncoming drivers a treat...
- Has thanked: 1448 times
- Been thanked: 1331 times
My F350 had a pair of 200W *manually switched reversing lights* under the rear bumper. The drivers side one pointed straight back & the PAX side one was angled to intercept the other beam about 40-50ft back. Worked great on tailgaters with their brights on. Most times I'd hear the screech from their tires as they stood on the brakesmangocrazy wrote: ↑Wed Apr 05, 2023 3:48 pm I believe that the Cibie Z beam range are still produced in France, but now branded as Valeo. I bought four of them for my Beta Spider and can switch hi/lo beam on all four units. High beam with four headlights is very impressive. And pisses off oncoming drivers a treat...
