INCOMING, Happy 50th to me.... Yeah, it's a Yamaha... it's the easy option.
Been thanked: 15493 times
Re: INCOMING, Happy 50th to me.... Yeah, it's a Yamaha... it's the easy option.
Skub wrote: Thu Mar 17, 2022 4:28 pm Is the damage really that bad?
If that was fixed and touched in,you'd never know,plus it's not like you'd be hiding something that's going to cause catastrophic failure for any future owner.
Well either way, i've canned the claim and i'll take the adjuster out and see what happens with a new bolt and straightening the swinger there, then maybe get that other one on if needed.
Fowlers Parts
Your order has been placed successfully.
I've spoken to @crust who's seen this on Monsters with a similar setup too. We'll get it sorted in the coming days/weeks after we've done our trip to Belgium.
Got some more pics of the swingarm, it's used in a few bits, but the bits that are used are bits that I have on mine undamaged. So I've thrown them a bid of £110 for it. That way I can fit the swingarm and give the other one to @crust off the bike so he can sort it easier, just in case like.
For £110 I might as well
Images-l1600 by Steve Weeks, on Flickr
Images-l1600 (1) by Steve Weeks, on Flickr
Images-l1600 (2) by Steve Weeks, on Flickr
Images-l1600 (3) by Steve Weeks, on Flickr
Images-l1600 (4) by Steve Weeks, on Flickr
I checked the part numbers before throwing the bid in and it's all the same for 19-21.
They came back at £120.... So it's bought and paid.
Has thanked: 20859 times
Been thanked: 13679 times
Well done. Being a new bike it'll all come apart easily and nothing will be rusted in etc. Should be an easy job. :thumbup:
Taipan wrote: Fri Mar 18, 2022 9:44 am Well done. Being a new bike it'll all come apart easily and nothing will be rusted in etc. Should be an easy job. :thumbup:
Yeah will be 2 weeks time as got racing this weekend, then off to Belgium cycling the weekend after.
It doesn't look too tricky a job, couple of spacers, bearings/sleeves etc... but essentially getting there shouldn't be too tough.
Yeah was the right decision in the end i think. Glad you guys told me off a bit.
I'm guessing this is perfectly rideable ? I've got to shoot to the office later today and it'd be nice to jump on the bike for the trip in.
Tricky
Has thanked: 3043 times
Been thanked: 3309 times
Post by Tricky »
Am assuming you've got an adjuster block back in there and the wheel properly aligned?
I defo wouldn't be riding it without that
Tricky wrote: Mon Mar 21, 2022 8:06 am Am assuming you've got an adjuster block back in there and the wheel properly aligned?
No, not currently. Hence my question.
I assumed the axle nut holding things in place would be sufficient. But if not, i'll take the car into work.
I've got the parts if i wanted to go down he quick fix route, but as i've got the swingarm coming, i may as well keep the Fowlers parts aside and if i don't need them at all i can get £60 back by returning them bits.
Looking at the tracking, the swingarm is out for delivery today..
So if either @dern or even @Tricky fancy coming over to sanity check, i may even get it whipped on there later :)
Looking at the exploded diagram https://www.yamahapartshouse.com/oempar ... f/rear-arm There's nothing remarkably complex about it, it's just a question of fitting all the right bits in the right places lol.
No it isn't rideable. The torque will likely move the wheel out of alignment with the possibility of the chain coming off and locking up the rear wheel etc.
If you had an endplate and some nuts, yeah.
Without them you're relying on the clamping force of the axle nut to stop the axle moving in the slot.
It might be fine, but it might not.
Not worth the risk on a shiny new bike, imho.
Yeah no worries... the replacement swingarm has arrived this morning... UPS always come early here for some reason.
I can't fit it by 9am though that's for sure :D
KungFooBob wrote: Mon Mar 21, 2022 8:23 am If you had an endplate and some nuts, yeah.
Wot he sed.
I wouldn't want to ride it without those bits,just asking for trouble,even at a slow pace. It's not worth having to buy more bits..or worse.
Swingarm is nice... most happy with it... but thought i'd look and see how the chain adjuster ends worked as it is.
Here's the bent one
Image2022-03-21_12-23-18 by Steve Weeks, on Flickr
Straight one in there
Image2022-03-21_12-22-58 by Steve Weeks, on Flickr
Loosely fitted.
Image2022-03-21_12-22-48 by Steve Weeks, on Flickr
Image2022-03-21_12-22-40 by Steve Weeks, on Flickr
Image2022-03-21_12-22-29 by Steve Weeks, on Flickr
So the metal coloured end cap fits into the slot of the swingarm, so 95% of it is fully attached and correct. It's going absolutely nowhere.
So it'll stay like that until me and Crust get time.
Yes, i've torqued up the nuts this time lol
Couchy
Has thanked: 360 times
Been thanked: 2246 times
Post by Couchy »
Just get a small drift on that and tap away it'll be barely noticable, the second hand swingarm will have more marks, get that one powdercoated and swap when it's like new
Couchy wrote: Mon Mar 21, 2022 12:38 pm Just get a small drift on that and tap away it'll be barely noticable, the second hand swingarm will have more marks, get that one powdercoated and swap when it's like new
Yes possibly matey. I'll let @crust look in person in 2 weekends time.
Lets be honest, it's going into a dealer when it goes and even if they notice it and knock off a couple of hundred quid i won't much give a toss anyhow.
Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
weeksy wrote: Mon Mar 21, 2022 6:43 am I'm guessing this is perfectly rideable ? I've got to shoot to the office later today and it'd be nice to jump on the bike for the trip in.
If it was, why would they bother fitting one?
slowsider wrote: Mon Mar 21, 2022 5:06 pm
To allow you to tension the chain with accuracy
