Tool purchases
Has thanked: 316 times
Been thanked: 1078 times
Re: Tool purchases
Post by Silly Car »
Got this as well
So I can use the Hikoki batteries in my Ryobi tools as it seems a shame to have 2 x 5Ah batteries plus a 4Ah battery doing nowt when my max capacity Ryobi batteries are 4Ah.
The original badapter website shows they’ve closed, so I took a punt on https://www.akuadapter.eu/, ordered at the weekend, turned up today in a badapter box as shown in the image.
Has thanked: 1059 times
Been thanked: 1643 times
Re: Tool purchases
Silly Car wrote: Fri May 10, 2024 4:35 pm IMG_0146.jpeg
18v 90mm gas less framing / first fix nailer - plus around 8000 various length nails - courtesy of eBay discount vouchers 15% off IIRC. Hikoki have a spend £xxx get a free etc deal on at the moment, so a third battery is on its way
I have the second fix Hikoki brad gun (25-64mm 16 gauge brads) which although slightly less powerful than the Paslode brad gun is quieter, plus its far and away more reliable.
I have the De-Walt first fix nailer (50-90mm nails) and again wouldn't swap it for a manky old Paslode even if someone paid me.
Plus the bump fire facility (especially on a first fix gun) pisses all over Paslodes non bump fire guns.
The Paslodes are knocking on £650-700 and the De-Walt was about £260 and I can use the batteries in other tools
Re: Tool purchases
Post by Silly Car »
demographic wrote: Fri May 10, 2024 7:48 pm
I used it for the first time in anger last weekend to build a stud wall in a loft bedroom to hide the awkward wedge shape alcove. What a beast, 90mm smooth and 75mm ring shank fired to just below the surface, first time, every time. The battery lasted for the entire job, 3.6m wide x 2.6m high, 400mm on centre and there’s probably 50% life left.
In other news, the free 4Ah battery arrived today which is cracking service. I can’t help myself, so I’m currently looking at the Hikoki / Metabo 18v tool range… :D
Has thanked: 2842 times
Been thanked: 1599 times
Re: Tool purchases
My ancient little compressor finally gave up the ghost today, so ordered a compact unit from SGS. Hope this one lasts as long......
Re: Tool purchases
Silly Car wrote: Wed May 15, 2024 3:27 pm [
Watch out with that under the surface driving if yer nailing something like OSB sheets on cos it's easy to overdrive fixings into sheet materials and they don't hold as well.
Also often the simplest way to remove sheets of ply or OSB from studs is to punch the nails in deeper , that often means you can take it off in one instead of in little bits.
Re: Tool purchases
Post by Silly Car »
demographic wrote: Wed May 15, 2024 6:20 pm
Cheers for the tip, I’ll wind back the depth stop next time I use it to get them closer to the surface. Spookily, another job for it is adding some OSB ‘cladding’ around the garage roof to hopefully divert rainwater away from the unrendered block walls. Numpty builder / roofer didn’t leave sufficient overhang so rain is lashing onto the wall and running down the 3” gap between my garage and neighbouring garages.
I must also remember to get new foam tips for my isotune earphones to block out some of the noise!
Re: Tool purchases
Its not really doing much harm when you're just nailing studs together but deffo something to keep an eye on when nailing OSB on.
Worth getting a nail bar to remove misplaced nails also.
Ive kissed a few frogs as far as nailbars are concerned and IMO the best ate the foot long Estwing ones.
Piss all over the fancy pants Stiletto Titanium jobbie.
Has thanked: 12565 times
Been thanked: 8521 times
Re: Tool purchases
demographic wrote: Thu May 16, 2024 6:30 pm Its not really doing much harm when you're just nailing studs together but deffo something to keep an eye on when nailing OSB on.
Nailbars and stilettos?
Sounds like @gremlin
Re: Tool purchases
Expensive, nice and lightweight but the claws on the long end are a bit shite.
About a third of the price, a bit heavier on the belt but just designed right.
Well, apart from the blue rubber bit, I just cut that off with a knife.
Re: Tool purchases
demographic wrote: Thu May 16, 2024 7:41 pm Expensive, nice and lightweight but the claws on the long end are a bit shite.
For levering up ring pulls on cans. Amirite? :thumbup:
Has thanked: 1099 times
Been thanked: 5865 times
Re: Tool purchases
Yorick wrote: Thu May 16, 2024 6:38 pm
:wave:
Re: Tool purchases
Skub wrote: Thu May 16, 2024 8:14 pm
Ammonite? :thumbup:
:eh:
dern
Has thanked: 1180 times
Been thanked: 2276 times
Re: Tool purchases
Post by dern »
Very excited about this. Done mig before but wanted to learn tig. The seller gave me a lesson on aluminium and stainless that has give me loads of confidence. Have a load of off cuts and now it’s practice time…
Been thanked: 3208 times
Re: Tool purchases
A pair of hose clamp pliers, I'm fed up of clamps pinging out of normal pliers and or me pinching my palm
Re: Tool purchases
MrLongbeard wrote: Fri Jul 05, 2024 6:29 pm A pair of hose clamp pliers, I'm fed up of clamps pinging out of normal pliers and or me pinching my palm
Aww. Did them little clamps hurt you? Poor little wee lamb.
dern
Re: Tool purchases
Post by dern »
dern wrote: Fri Jul 05, 2024 5:01 pm Very excited about this. Done mig before but wanted to learn tig. The seller gave me a lesson on aluminium and stainless that has give me loads of confidence. Have a load of off cuts and now it’s practice time…
Well, 9,999.5 hours to go but for my first play I'm extremely pleased and encouraged. A little mild steel 2mm plate with no filler, some filler and then a go at a but weld. You can give me tips or take the piss if you like but this was literally my first half an hour so...
I enjoyed doing it, it was good fun and I won't be making any actual parts and/or repairs for quite a while, obviously.
Re: Tool purchases
I have the cable operated type, that one looks quite handy.
Has thanked: 2278 times
Been thanked: 2657 times
Re: Tool purchases
dern wrote: Sat Jul 06, 2024 8:15 pm You can give me tips or take the piss if you like but this was literally my first half an hour so...
Bucket of water next to you where you're welding. This serves two purposes:
1, Can put fires out.
2, Can plunge you hand, arm, foot or head in it when you get molten metal in your glove, sleeve, boot or nostril.
Get some bits of thin steel plate (1 & 2mm) & go burn rods for an hour a day for two weeks.
Then start on the aluminum once you have the muscle memory sorted from the steel plate.
You could also buy some flux coated brazing rods & burn those too if you don't want to use all your Argon etc... talking of which, where's the gas bottle & flow meter?
Also:
Some welding places sell kits of all sorts of gubbins for TIG welders so you don't have to buy a bunch of separate items. Not sure if one is available for your machine though.
dern
Re: Tool purchases
Post by dern »
ZRX61 wrote: Sat Jul 06, 2024 10:39 pm
Also:
I haven't burnt myself yet, unlike mig where I learned to where a hat pretty quickly.
The place that sold me the welder gave me a half hour lesson and in all honesty I found the aluminium a lot easier than I'm finding the steel. Like I say though, half an hour in isn't much. I've bought a pile of steel offcuts so will be doing exactly that, line after line.
There is a 10l refillable bottle on the floor strapped to the bench leg.
Re: Tool purchases
When my kid was 9 or 10 she turned a 6x6in piece of 1/4in plate into a 6x6 piece of 1inch plate just by running beads on it. She got pretty good at it.
