State of the roads
- Has thanked: 20863 times
- Been thanked: 13684 times
Re: State of the roads
My local roads are dreadful but I blame the repeated cheap, poor quality and unsuitable repairs. They are just infills and not sealed so as soon as it rains the start washing out and once we get icy temps, they water inside expands and breaks them. Complete financial inefficiency by the county councils.
- Ditchfinder
- Has thanked: 861 times
- Been thanked: 1069 times
Each of the local authorites with responsibility for highway maintenance are being under funded by the Conservatives because of their austerity measures in place since Cameron.
If a local authority has to choose between social care and potholes it's always choosing social care.
- Has thanked: 7623 times
- Been thanked: 5930 times
If all roads with issues were to be resurfaced completely, how many years would that take?Ditchfinder wrote: Tue May 14, 2024 9:40 am Each of the local authorites with responsibility for highway maintenance are being under funded by the Conservatives because of their austerity measures in place since Cameron.
And, of course, no-one would complain about roadworks and road closures
- Has thanked: 5954 times
- Been thanked: 3572 times
Yup stuff either gets repaired cheaply or they'll go the dreaded surface dressing route rather than doing it properly. Within a year both tend to start breaking down and you're back to square one. Must be great for the contractors it's a rolling ticket.Taipan wrote: Tue May 14, 2024 9:29 am My local roads are dreadful but I blame the repeated cheap, poor quality and unsuitable repairs. They are just infills and not sealed so as soon as it rains the start washing out and once we get icy temps, they water inside expands and breaks them. Complete financial inefficiency by the county councils.
- Cousin Jack
- Has thanked: 3005 times
- Been thanked: 2522 times
Other countries manage to repair roads without causing the chaos that we manage in this country. They close the lane they are working on, when they are working on it, rather than 5 miles of closure for a fortnight to do 2 days work on 3 short stretches.Horse wrote: Tue May 14, 2024 10:07 amIf all roads with issues were to be resurfaced completely, how many years would that take?Ditchfinder wrote: Tue May 14, 2024 9:40 am Each of the local authorites with responsibility for highway maintenance are being under funded by the Conservatives because of their austerity measures in place since Cameron.
And, of course, no-one would complain about roadworks and road closures![]()
So you're already complainingCousin Jack wrote: Tue May 14, 2024 11:25 amOther countries manage to repair roads without causing the chaos that we manage in this country. They close the lane they are working on, when they are working on it, rather than 5 miles of closure for a fortnight to do 2 days work on 3 short stretches.Horse wrote: Tue May 14, 2024 10:07 am And, of course, no-one would complain about roadworks and road closures![]()
FWIW, you can't "close the lane they are working on, when they are working on it" for the simple reason that you need space in the adjacent lane too.
- Cousin Jack
I'm already complaining at the stupidity of Councils, on many subjects, including but not limited to, road maintenance.
How do you justify what I saw about a week ago, 3/4 mile of lane closed on a dual carriage way, no sign of workmen, vans, plant or anything else. Just a significant queue.
Or the other, same day, 50 miles away. 1/2 mile lane coned off, 1 van ar one end, no visible activity, 1 van at the other end, 3 men on the (wide) grass verge conferring.
The crew that install the signs and cones aren't the same as the people who remove the old surfacing and put down the new.
You might hope that there would be marvellous synchronised choreography to get things working together. Back on earth ...
Re length of works Vs work being done in them. Ahead of the works there needs to be space for equipment and vehicles to park. Before that, the access point. Before that, a safety zone, then the lane-closing cone taper (length depends, minimum 135m, up to 200m per lane closed). Then advance warning signs starting for short duration works 1 mile before the taper.
And there needs to be space between the works, it's not permitted to have the start of signing for one set at the end of previous works. Just as drivers started to use the lane again, they'd have to move out again.
Edit: above is for high speed roads, 50mph and higher. See TSM Chapter 8. For slower roads, see 'The Red Book'. Differences in signing and lengths apply if longer-duration works. Above is for 'relaxation' works, in low traffic flows installed for limited duration.
- Cousin Jack
I have no doubt all that is true. However other countries, eg Spain, manage with very different rules.
- Has thanked: 2852 times
- Been thanked: 3505 times
We've had very little frosts this winter and the roads are worse than ever. It must be rain they don't like. Our road's have just gone the same way as everything else.
It's unlikely that they'll resurface a full lane width without impacting, some way or another, on the adjacent lane.Cousin Jack wrote: Tue May 14, 2024 1:05 pm I have no doubt all that is true. However other countries, eg Spain, manage with very different rules.
I can only tell you about UK works, where there would be a safety margin outside of the work area.
Even if they don't have that, presumably there would still be some sort of demarcation by cones? And they can't be on the bit you're digging out or filling in.
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
There's a particularly bad bit of road that I always veer to avoid on my occasional commute that makes me feel like an F1 driver heading down to Mirabeau from Casino Square, so it's not all bad.
This ^Ditchfinder wrote: Tue May 14, 2024 9:40 am Each of the local authorites with responsibility for highway maintenance are being under funded by the Conservatives because of their austerity measures in place since Cameron.
Fixing road takes money (don't even start with the road tax argument
Partly cause they're under funded and partly cause everyone is either old or sick and for some reason we make councils pay for that.
Roads on the back burner for sure.
- Has thanked: 602 times
- Been thanked: 4529 times
Councils have plenty of money, it's what they spend it on that's the problem, I love paying council tax so the last useless twats that work for the council have a far better pension than mine.
- Ditchfinder
The old days of gold plated pensions and retiring at 55 are long gone. I worked local authority for 15 years and left 15 years ago when they removed those benefits. The lower wages were no longer worth putting up with without the benefits.Le_Fromage_Grande wrote: Tue May 14, 2024 10:12 pm Councils have plenty of money, it's what they spend it on that's the problem, I love paying council tax so the last useless twats that work for the council have a far better pension than mine.
The generation of workers who retired 10 years ago will still have got those great pensions but please be aware that they aren't available any more.
Sweeping generalisations such as those who work at a local council are useless twats aren't correct or very nice, you could take up your grievances with your local councillors or even better become one if you want them held to account.
Go and work there, then. Sort it all out, get the decent pensionLe_Fromage_Grande wrote: Tue May 14, 2024 10:12 pm Councils have plenty of money, it's what they spend it on that's the problem, I love paying council tax so the last useless twats that work for the council have a far better pension than mine.
Oh dear, I wasn't very nice, how sad, never mind.
Maybe if more people made it clear they were unhappy with the shit state of councils they might start doing the things we pay council tax for.
That's the thing though, they do do the stuff council tax is for, s'just that roads are fairly far down the list
I don't quite get why a bunch of the stuff councils do is done at their level (social care and schools basically), but that's the system at the moment.
Oooh touchyLe_Fromage_Grande wrote: Wed May 15, 2024 7:21 am Oh dear, I wasn't very nice, how sad, never mind.
So what do you want them to stop paying for that could, instead, resurface roads?
- Been thanked: 9495 times
Orphanages.Horse wrote: Wed May 15, 2024 8:21 amOooh touchyLe_Fromage_Grande wrote: Wed May 15, 2024 7:21 am Oh dear, I wasn't very nice, how sad, never mind.
So what do you want them to stop paying for that could, instead, resurface roads?![]()
