Yebbut, you're Mr Dazzle so when you're around everyone is blinded, hexagons or no.Mr. Dazzle wrote: ↑Fri Nov 24, 2023 7:10 pm I never knew being colour blind made you see cop cars as hexagons.
Do auxiliary lights help you be seen?
- Has thanked: 6375 times
- Been thanked: 4746 times
Re: Do auxiliary lights help you be seen?
- Has thanked: 6186 times
- Been thanked: 5087 times
I think it's a Traffic Officers truckMr. Dazzle wrote: ↑Fri Nov 24, 2023 7:10 pm I never knew being colour blind made you see cop cars as hexagons.
Every day is a school day.
- Has thanked: 221 times
- Been thanked: 878 times
I used to call auxilliary lights the "Triangle of Wankerdom"
Usually some fat cunt on a GS expecting everyone to get the hell out of his way, now as a fat cunt on a GS, I'm thinkong of a pair like the ones I had on my old Airhead ratfighter thing, purely to help me see in the dark. Ive had people pull out on a bright pink double decker with HID lights on it, so they'll pul out on a bike no matter how many lights are on it.
Anither thing that boils my piss is trucks lit up like a coke advert. My mate has a huge Scania with no fewer than 21 lights on the front, that's before the huge LED V8 in the cab. It's the same on the back of the unit, although I think they're wired so when there's a trailer connected they go off.
- Has thanked: 1373 times
- Been thanked: 253 times
While I agree that acting smarter is the higher priority, you suggested yellow lights could aid conspicuity.The Spin Doctor wrote: ↑Wed Nov 22, 2023 1:35 pm Have some Science Of Being Seen...
https://scienceofbeingseen.org/17-strat ... tive-drls/
I expect you’re correct — with the usual caveats that nothing is guaranteed, no single measure is foolproof, proactive riding matters more, etc.
- Has thanked: 1346 times
- Been thanked: 1722 times
Ha, there's a bit of a Scania thing going on and yeah I've also noticed that the ones with the V8"s do seem especially chuffed about it to the point wbere they need to advertise the fact to everyone within line of sight.Bigjawa wrote: ↑Sat Nov 25, 2023 2:31 pm I used to call auxilliary lights the "Triangle of Wankerdom"
- Has thanked: 2550 times
- Been thanked: 6241 times
When I turn my car on, the headlights project an animated swooshy thing with the brand badge that slides into view (assuming you're parked infront of a vertical surface ) which then turns into projected 'rain'. LED Scania badges are old hat.
Jeez, is it possible to programe it so it doesn't do tbat?Mr. Dazzle wrote: ↑Sat Nov 25, 2023 8:48 pm When I turn my car on, the headlights project an animated swooshy thing with the brand badge that slides into view (assuming you're parked infront of a vertical surface ) which then turns into projected 'rain'. LED Scania badges are old hat.
- Has thanked: 479 times
- Been thanked: 310 times
That's quite sobering, put like that.It take a LOT of imagination to be able to put yourself into the position of each car driver in the vehicles around you, and then figure out what they can and can't see, and then a huge spark of understanding and self-realisation to realise, and then accept, that you yourself might be the one at fault in any given scenario.
It's no wonder that bikers find that sort of self-introspection hard to do: to it have enough confidence to ride something that is going to fall over at the first opportunity takes a certain amount of egotism; simply to have the confidence to ride the thing: that will work against any ability to see oneself as being in the wrong. Factor in as well that a distinct lack of imagination is required to be able to ignore (or at least dismiss) the risks involved, especially when riding at higher speeds, or in higher levels of traffic without constantly freaking out.
It's only all the rest, though, not us?
- Cousin Jack
- Has thanked: 2549 times
- Been thanked: 2285 times
Surprise yes, at least the first time, but marketing people must be easily delighted.
- Has thanked: 2635 times
- Been thanked: 1523 times
Absolutely...Hot_Air wrote: ↑Sat Nov 25, 2023 5:39 pmWhile I agree that acting smarter is the higher priority, you suggested yellow lights could aid conspicuity.The Spin Doctor wrote: ↑Wed Nov 22, 2023 1:35 pm Have some Science Of Being Seen...
What do they call it when it goes wrong?
Where did you clip that from?Scootabout wrote: ↑Sat Nov 25, 2023 10:04 pmThat's quite sobering, put like that.It take a LOT of imagination to be able to put yourself into the position of each car driver in the vehicles around you, and then figure out what they can and can't see, and then a huge spark of understanding and self-realisation to realise, and then accept, that you yourself might be the one at fault in any given scenario.
I don't think it's that difficult... what prevents us is lack of imagination, and a peculiar groupthink mentality which casts us as victims.
I got some real abuse from some MAG laddos for suggesting that just possibly if we remembered that a car waiting to pull out at a junction do only two things - say put or pull out - and that if we prepared for the second rather than the first we'd have fewer SMIDSYs.
As your man says, I live up to my user name.
- Has thanked: 7810 times
- Been thanked: 2527 times
Who, me?The Spin Doctor wrote: ↑Sat Nov 25, 2023 10:43 pmWhere did you clip that from?Scootabout wrote: ↑Sat Nov 25, 2023 10:04 pmThat's quite sobering, put like that.It take a LOT of imagination to be able to put yourself into the position of each car driver in the vehicles around you, and then figure out what they can and can't see, and then a huge spark of understanding and self-realisation to realise, and then accept, that you yourself might be the one at fault in any given scenario.
Nowhere, it's what i think.
A manufacturing fault.
(Or, more likely, "user error")
Darkness. Or 'recall' or 'Error code 143c2by8z'.
What sort of car is that, so I can never buy one.Mr. Dazzle wrote: ↑Sat Nov 25, 2023 8:48 pm When I turn my car on, the headlights project an animated swooshy thing with the brand badge that slides into view (assuming you're parked infront of a vertical surface ) which then turns into projected 'rain'. LED Scania badges are old hat.
Several companies offer it now, I've been trying to find out who actually makes the system (it'll be Hella, Philips or someone like that).
On a more useful note, they're bloody amazing at doing their actual job. Beam pattern is absolutely perfect. The animation is just frippery added on to show the level of detail the system can achieve.
- Been thanked: 7526 times
You mentioned the other day that you drove a car far above your station... and now we know the lights can project images.Mr. Dazzle wrote: ↑Sun Nov 26, 2023 4:10 pm Several companies offer it now, I've been trying to find out who actually makes the system (it'll be Hella, Philips or someone like that).
https://www.motortrend.com/news/new-may ... ct-images/
It's a Maybach, innt!
