Page 3 of 3
Re: Nostalgia - I have begun to look at Early 90's Triumph triples
Posted: Sun Dec 06, 2020 8:01 pm
Spotted this on Friendface Marketplace...
Posted: Sun Dec 06, 2020 10:49 pm
by Druid
bevvo wrote: Thu Dec 03, 2020 5:29 pm
IF we're doing early speed triples here's mine. Not 90s though, sorry.
The post-2002 ones had more grunt and the engines were quieter they reckon.
I quite liked it after a few tweaks - smaller front cog, fast action throttle. Never got round to changing the front MC but it needed it.
I liked mine too. I did the quick action throttle mod and the front master cylinder. The seat was uncomfortable, the factory gel seat was marginally better but it was ok apart from that.
I loved the engine. The 1050 was better in every way but that was definitely not a 90s bike
Posted: Fri Jan 29, 2021 2:02 pm
by Ditchfinder
Got me a Sprint 900 sat in the garage waiting for me to make it look a little less ugly. Got inspired by this
https://rocket-garage.blogspot.com/2016 ... built.html.
If mine turns out half as good as that I'll be chuffed.
Posted: Mon Sep 26, 2022 10:51 am
by Mr Moofo
Rode the Speed Triple the other day - and it started to misfire like a bastard - and felt like one cylinder wasn't fully working. The backfiring suggested that petrol was igniting is the end can. The locals weren't impressed.
On taking advice from people who know it was suggested:
a) plugs
b) carbs / pilot jets
c) coils
d) It's an old triumph - what do expect
Body work off - plugs out (the T300 has very narrow plug channels - so it took two goes on Amazon to get something that fitted). No 1 plug (on the left, lowest position when on side stand) came out looking tile it had been swimming in the sump and was completely loose - as in less than hand tight. No 2 (middle) was slightly better in terms of oil but still just below hand tight.. No 3 was a clean as a whistle and torqued properly
Conclusion: Cam seal has gone - possible just the ones around the plug channels - but if you are going to do it, put in new around.
Triumph want 109.60 for the seals
Sprint Manufacturing wanted considerably less
Posted: Tue Sep 27, 2022 8:00 am
by Supermofo
Good luck sorting it
Posted: Tue Sep 27, 2022 8:07 am
by Ditchfinder
Got a link to that spark plug socket? I think I'll have the plugs out in mine as I have some backfiring on the sprint
Posted: Tue Sep 27, 2022 9:50 am
by Mr Moofo
@Ditchfinder
As requested :-
The plug channels fill with oil because the cam cover seal leaks at the o shaped seals around the plugs. This caused the issue with mine because it was screwed in much / at all - so the plug was dripping in oil.
Stick coils can also help
I was worried that it was going to be a carb issue - and getting the carbs out seems to be universally seen as a complete bitch!
I know that your's is not a Speedy - but this is a good repository of info
https://www.mk1speedtriple.co.uk
And then there is also T300 on FB
Posted: Tue Sep 27, 2022 9:59 am
by Ditchfinder
Cheers @Mr Moofo , I've had a good read of that site and also been on a few FB forums. My carbs were fettled by someone who knows what they're doing last year and the knackered pilot jets replaced so I'm inclined to think my issues are on the ignition side. Stick coils might happen but mines a shed so not sure I can justify the cost. Hoping the plugs will tell me which pot is playing up and then I can play swap the coils to see if that is the problem.
Posted: Thu Sep 29, 2022 11:25 am
by McSatan
I had an M reg Tiger 900. That was a brilliant bike. Dropping the yokes by 20mm and putting 20mm spacers on top of the springs in the non-adjustable forks made a *huge* difference to the ponderous handling. It would have made a great tourer, massive tank and supremely comfy.
https://www.ebay.co.uk/itm/204102856665 ... 1197.m1850
Posted: Thu Sep 29, 2022 11:37 am
by Mr Moofo
McSatan wrote: Thu Sep 29, 2022 11:25 am
The model after that had shocking soft forks - I wanted to buy one - but the test ride showed me the GS was far better
