Getting old....
- Has thanked: 16228 times
- Been thanked: 3930 times
Re: Getting old....
This thread makes me giggle every time I see the title!!
As someone who just does not feel her age and forgets just how high that number is sometimes, I forget that I'm pretty sure I'm older than Rockburner - then I remember and wonder when age will become a factor in biking for me
But I try to do more of the than the
- Cousin Jack
- Has thanked: 2555 times
- Been thanked: 2287 times
Re: Getting old....
IME gravel is a PITA, not so much for the bike sinking in, wheel spinning, or whatever. It is my bloody feet that lose traction, so I can't push it around, or save it if it starts to topple over.
BTW, it is fine 'refusing to you acknowledge getting older', but one day you will wake up and discover you ARE old. .No ifs, no buts, you are knocking on towards 80 with no way back. All your friends and family are falling off their perch and even your kids will be discussing pensions
DAMHIKT.
DAMHIKT.
- Has thanked: 2407 times
- Been thanked: 3636 times
Re: Getting old....
Gravel is an enemy in so many ways. At its simplest it makes pushing a bike much harder, as there is much more resistance, and can easily 'dig in' to the gravel. Why do race tracks have gravel traps? There is also the tendency for the bike to fall over, and as CJ says, gravel does not provide a solid base for feet to gain traction. I really cannot understand how anyone can think that gravel and motorbikes are a positive combination.
- Has thanked: 6198 times
- Been thanked: 5089 times
Re: Getting old....
When doing back to biking courses for people who had just bought a bike from the dealer, we always ended the session at their home.mangocrazy wrote: ↑Sun Jul 16, 2023 12:11 pm I really cannot understand how anyone can think that gravel and motorbikes are a positive combination.
Always, before setting off, "Do you have a gravel drive?" So often, 'yes'. So we had to cover a little bit more and trust that they remembered it.
- Has thanked: 7820 times
- Been thanked: 2530 times
Re: Getting old....
Its already got that. Main problem is that the gravel isn't level, and the bottom of the slope, where the gravel tends to gather, is right in front of the workshop door!
Re: Getting old....
As I posted earlier, set slabs into the gravel.Rockburner wrote: ↑Sun Jul 16, 2023 5:24 pmIts already got that. Main problem is that the gravel isn't level, and the bottom of the slope, where the gravel tends to gather, is right in front of the workshop door!
Scrape some away, level the trackway, place slabs, backfill around the slabs so they're not proud.
Re: Getting old....
So I presume your garden slopes down to the shed/workshop where the bike is kept, and gravity tends to cause a build up of gravel by the shed door? And I seem to remember you saying that you have to use a ramp to get the bike out of the shed/workshop?Rockburner wrote: ↑Sun Jul 16, 2023 5:24 pmIts already got that. Main problem is that the gravel isn't level, and the bottom of the slope, where the gravel tends to gather, is right in front of the workshop door!
Personally I'd be inclined to put some of that gravel to good use in a concrete mixer and make a level concrete causeway from the workshop door to wherever it naturally joins to the slope down to the workshop. Make the causeway at least a metre wide and use shuttering to stop the concrete mix from going where you don't want it to. That would remove the most troublesome aspects (as long as I've understood your layout correctly, of course).
- Been thanked: 7537 times
Re: Getting old....
If you ignore the weight requirement, it would see that Sir's ideal motorcycle is a 700 Honda Deauville.
- MrLongbeard
- Has thanked: 599 times
- Been thanked: 2449 times
Re: Getting old....
With all this talk of slabs etc, don't forget to bear in mind that anything over 5m2 on your front drive / garden requires planning permission
Re: Getting old....
RB could be a little more extravagant and hunt down a Pacific CoastKungFooBob wrote: ↑Sun Jul 16, 2023 8:11 pm If you ignore the weight requirement, it would see that Sir's ideal motorcycle is a 700 Honda Deauville.
Re: Getting old....
The 700 dullville is newer and more fasterer, due to the EFI and the extra valve per cylinder.Horse wrote: ↑Sun Jul 16, 2023 8:23 pmRB could be a little more extravagant and hunt down a Pacific CoastKungFooBob wrote: ↑Sun Jul 16, 2023 8:11 pm If you ignore the weight requirement, it would see that Sir's ideal motorcycle is a 700 Honda Deauville.
Re: Getting old....
Indeed, but RB is renowned for 'less usual' bike choices, the Mirth, big K, Rocksters ...KungFooBob wrote: ↑Sun Jul 16, 2023 8:25 pmThe 700 dullville is newer and more fasterer, due to the EFI and the extra valve per cylinder.Horse wrote: ↑Sun Jul 16, 2023 8:23 pmRB could be a little more extravagant and hunt down a Pacific CoastKungFooBob wrote: ↑Sun Jul 16, 2023 8:11 pm If you ignore the weight requirement, it would see that Sir's ideal motorcycle is a 700 Honda Deauville.
- Has thanked: 2870 times
- Been thanked: 554 times
Re: Getting old....
I was going to suggest an R1200RT until I saw the wet weight was 260kg. I knew it wouldn't hit the 200kg but I didn't think it would be as much as 260kg. In practice, the RT feels a lot more manageable than my GSA though a lot of that could be down to the difference in seat height. I've been having similar thoughts about my GSA, it's a big unit to be pushing around.
- Has thanked: 2248 times
- Been thanked: 1242 times
Re: Getting old....
I tired one for a short period of time. I'm usually good with 'utilitarian' bikes but it was shocking - weighed about the same as a London bus and painfully slow, anything over 75mph and it didn't feel happy. Struggled to break the 100mph barrier, let alone cruise at 110.....KungFooBob wrote: ↑Sun Jul 16, 2023 8:25 pmThe 700 dullville is newer and more fasterer, due to the EFI and the extra valve per cylinder.Horse wrote: ↑Sun Jul 16, 2023 8:23 pmRB could be a little more extravagant and hunt down a Pacific CoastKungFooBob wrote: ↑Sun Jul 16, 2023 8:11 pm If you ignore the weight requirement, it would see that Sir's ideal motorcycle is a 700 Honda Deauville.
Re: Getting old....
Oh I know. But for now I'll keep pretending! I do often find people my own age quite old though - that's pretty weird!! LOL But luckily I'm finally starting to meet people here around the same age that are similarly mental. I mean mentally young!!Cousin Jack wrote: ↑Sun Jul 16, 2023 12:01 pm BTW, it is fine 'refusing to you acknowledge getting older', but one day you will wake up and discover you ARE old. .No ifs, no buts, you are knocking on towards 80 with no way back. All your friends and family are falling off their perch and even your kids will be discussing pensions
I totally know I won't be doing some things here just because of age/risk, but I will keep doing the other stupid shit that I already know (mostly) how to do until I really can't!!
Ermmm -huh????
- Cousin Jack
Re: Getting old....
Exactly my thoughts. A year or two back when I was a Citizens Advice advisor I used to see people 10 years younger than me who were complaining that they couldn't do stuff, usually on-line stuff, or filling in forms, or understanding anything even vaguely complicated. Basically they had switched their brain off 40 years ago, and their body had followed 20 years later, so at 60 they were brain dead and fit only for an old people's home.Noggin wrote: ↑Mon Jul 17, 2023 11:42 am
Keep thinking, keep learning, keep active and you may not live any longer but you will enjoy it a lot more.
Re: Getting old....
I've seen people here do that - turn 50 and get old?? FFS!!! I do know age is more than a state of mind, but if you allow a number to tell you what you can and can't do anymore, well, you bloody will get old, fast!!!Cousin Jack wrote: ↑Mon Jul 17, 2023 12:30 pm
- Has thanked: 6382 times
- Been thanked: 4763 times
Re: Getting old....
I was looking at the R850(R?) yesterday and they weigh in over 200kg too. (Did a France trip with a bunch of people and one of the women had one...because it was a lighter bike. They just seem like an 1150 with smaller holes in the cylinders!). They're getting a bit old now too.Beancounter wrote: ↑Mon Jul 17, 2023 10:40 am I was going to suggest an R1200RT until I saw the wet weight was 260kg. I knew it wouldn't hit the 200kg but I didn't think it would be as much as 260kg. In practice, the RT feels a lot more manageable than my GSA though a lot of that could be down to the difference in seat height. I've been having similar thoughts about my GSA, it's a big unit to be pushing around.
Re: Getting old....
Yes the 850 is the same bike, just slightly smaller bore on the cylinders.Count Steer wrote: ↑Mon Jul 17, 2023 12:56 pmI was looking at the R850(R?) yesterday and they weigh in over 200kg too. (Did a France trip with a bunch of people and one of the women had one...because it was a lighter bike. They just seem like an 1150 with smaller holes in the cylinders!). They're getting a bit old now too.Beancounter wrote: ↑Mon Jul 17, 2023 10:40 am I was going to suggest an R1200RT until I saw the wet weight was 260kg. I knew it wouldn't hit the 200kg but I didn't think it would be as much as 260kg. In practice, the RT feels a lot more manageable than my GSA though a lot of that could be down to the difference in seat height. I've been having similar thoughts about my GSA, it's a big unit to be pushing around.
