New lid
Has thanked: 6196 times
Been thanked: 5088 times
Re: New lid
Scootabout wrote: Fri Jun 16, 2023 11:13 pm
Supermofo wrote: Wed Jun 07, 2023 11:35 pm
Money no object I might get another Arai but I'm the reverse of KFB, I don't think I'd want to be without an internal drop down visor now. Just way more convenient. So I'd probably never buy another Arai again unless it was track only
I went on a hunt for a new lid recently and started with the same premise: internal drop-down visor, so not Arai.
After trying on 12-15 lids, I bought....an Arai Quantic. It was by far the best fit for me. Unfortunately the legal tint visor I bought as a not-very-satisfactory substitute for the drop-down has lost an eyebrow vent already and so has gone back to Sportsbikeshop. Hey ho. I still think I made the right choice, though, as fit matters to me more than most criteria.
Don't Arai do an external clip-on shade visor?
Edit: Pro Shade
Has thanked: 1829 times
Been thanked: 1469 times
Re: New lid
Horse wrote: Mon Feb 05, 2024 2:42 pm
Edit: Pro Shade
I have one of those on one of the arais - and it actually works effectively, once you get used to it
The reason why I started looking at a new helmet is because the Retro fitted Pro-shade is about 100 quid
As I have a Chaser V and a Chaser X they had different visor fitments
Has thanked: 7819 times
Been thanked: 2529 times
Re: New lid
Edit: Pro Shade
I've seen them, tbh it looks a bit flimsy and a couple of strips of tape will do a far better job.
Has thanked: 15961 times
Been thanked: 10248 times
Re: New lid
I switched from aria to hjc some years ago now, albeit the cheaper ones. I find them a more comfortable fit for my head. Can’t comment too much about quality but they get worn 4 days a week no have held up well. Only downside now is the latest one I got has a stupid seat belt type clip in which I’m still finding fiddly and I’d prefer the double D rings.
Re: drop down visors, last year I discovered the joy of reactolite sunglasses which are brilliant!
Re: New lid
Taipan wrote: Mon Feb 05, 2024 6:56 pm I switched from aria to hjc some years ago now, albeit the cheaper ones. I find them a more comfortable fit for my head. Can’t comment too much about quality but they get worn 4 days a week no have held up well. Only downside now is the latest one I got has a stupid seat belt type clip in which I’m still finding fiddly and I’d prefer the double D rings.
TBH - I didn’t think reactolite worked once screened from UV. (Windscreen/ visor)
Re: New lid
Mr Moofo wrote: Mon Feb 05, 2024 7:27 pm
Specsavers told me car windscreens stop them working. but they seem to work fine behind my visor. WhenI’m riding through London they are great as they lighten well in the tunnels and shaded areas etc.
Re: New lid
Taipan wrote: Mon Feb 05, 2024 7:42 pm
Taipan wrote: Mon Feb 05, 2024 6:56 pme double D rings.
But they'll never clear as quickly as flipping up a built-in visor.
And the great things about strips of insulation or masking tape across the top of the visor (as per Ricey's post) are that they can be 'personalised' to your eyeline and its height can be 'adjusted' by dipping your head.
Using sunnies (of any sort) will darken the entire field of view. Additional visors or sunstrips block the sun but keep the rest of your view clear.
Scootabout
Has thanked: 479 times
Been thanked: 310 times
Re: New lid
Post by Scootabout »
I had the Arai Pro Shade on my previous helmet. It works OK-ish, but I didn't go for it again because:
- it's pretty expensive
- it's vulnerable to damage (I broke the last one's fitment by dropping the helmet on long grass on a campsite)
- it gets dirty easily - you have to clean both the visor and the flip-up, and it's not easy to remove, so fiddly to clean
- it's not very aerodynamic when flipped up, and can occasionally flip itself down
- it creates some unwanted reflections.
So I now manage with a clear visor, Horse's electrical tape, and yellow polarising clip-ons when needed.
Has thanked: 229 times
Been thanked: 575 times
Re: New lid
I have a Pro shade on my current Arai - it was on a last year’s model I bought at the NEC a few years ago. I used it a couple of times at the start, because it was there. But: if you don’t clip it back in place firmly when it’s up, it’ll flip down again with a shoulder check, not ideal in the dark. And if you do clip it back, then it’s a bugger to un clip when you’re wearing gloves, which you are. It’s also just as vulnerable to micro scratching as the visor itself, and that makes 2 layers of micro scratches to look through.
I think it’s one of those clever ideas which don’t actually work in practice. Black insulation tape across the top of the visor is still the answer, but Arai don’t do it. B and Q do.
Re: New lid
Horse wrote: Mon Feb 05, 2024 8:06 pm
Rather depends on if you're in a position to flip up the visor. In traffic, you don't want to lift your hand off the bar to start raising visors, and I've certainly never felt damn these glasses don't react quickly enough! There is noticeable darkening or lightening effect. Its pretty seamless. I can walk out of the sunshine into a dark room without waiting for them to catch up and I never fumble around trying to put lights on. They barely retain any tint when indoors, so I could wear them for working in if i wanted.
I think we've all moved on from tape on the visors, although I did that for years. I am fortunate to ride in and out of work with the sun behind me too, so it's just everyone else's blindness i have to look out for!
Normal glasses and reactolites
Re: New lid
I've been using light reactive specs for about 40 years. I have a fair idea of how quickly - or slowly, it's certainly not immediate - they change.
You really can't take one hand off the bars for the few moments it takes to nudge the lift button?
Re: New lid
Horse wrote: Tue Feb 06, 2024 10:05 am I've been using light reactive specs for about 40 years. I have a fair idea of how quickly - or slowly, it's certainly not immediate - they change.
How old are yours then? Mine work just fine and i've never felt endangered by the transition speed. I can't imagine there is ever a time when that would be an issue!
No, there are lots of times on my commute I certainly wouldn't take my hand off the bars, not with lane changing vehicles, cyclists and pedestrians all around me, and now, with reaction lenses, I don't even have to consider that risk.
Re: New lid
Taipan wrote: Tue Feb 06, 2024 10:37 am How old are yours then?
Current set, no more than18 months. Zeus lenses.
I don't know which of these three types.
https://www.zeiss.co.uk/vision-care/eye ... enses.html
Can't find times specified for them. Here:
https://www.onlineopticiansuk.com/photo ... ained-i149#
Says:
"How Long Do Transitions Lenses Take To React?
"They typically take around 30 seconds to fully darken and between two to five minutes to return to a clear state."
Re: New lid
Horse wrote: Tue Feb 06, 2024 10:47 am
Says:
But you're never in a total dark to light situation. Outside has constantly varying levels of light so the reaction lenses are constantly reacting! So that is a pointless comparison to a permanently dark visor.
Re: New lid
Taipan wrote: Tue Feb 06, 2024 11:06 am
You will be in situations where you're riding towards low sun?
In those, the complete light block of tape is unbeatable. A drop-down internal tinted visor will reduce light but allow you to see the road surface.
Both better than tinted glasses.
What about situations such as riding under tree cover, through tunnels, etc.? Immediate light to dark and back.
Re: New lid
What about my question about HJC lids?
Re: New lid
Horse wrote: Tue Feb 06, 2024 12:30 pm
It isn't immediate light to dark and back at all. It's just varying levels of light and depending on speed you'd be past it before you noticed or had time to flip up and back down a visor or nod your head to the right angle.
Oh yeah, HJC, very nice and comfortable! No drop down internal visor but I have reaction lenses so dont need one, or tape... :silent: :lol:
Re: New lid
Taipan wrote: Tue Feb 06, 2024 12:51 pm
You do, but just won't admit it :D :obscene-birdiedoublered: :banana-dance:
Has thanked: 4362 times
Been thanked: 2852 times
Re: New lid
Mr Moofo wrote: Tue Feb 06, 2024 12:35 pm What about my question about HJC lids?
Never owned one, but my brother did for a while. He moaned a lot about the visor ratcheting system. On the Shark and Arai you could have the visor where you wanted it but on his HJC it only had a few set positions none of which he liked so he bought a Shark in the end. Not sure that's all HJC's though so might not be an issue.
Whysub
Has thanked: 1054 times
Been thanked: 861 times
Re: New lid
Post by Whysub »
Taipan wrote: Tue Feb 06, 2024 9:45 am
I am fortunate to ride in and out of work with the sun behind me.
I had this too. Got offered a move out of London (1 to 1½ hours each way commute) to Ipwich (30 minutes each way).
Didn't take it as riding into the sun both ways never appealed.
Work used to buy me a new helmet every 18 months, so I always chose top of the range Arai's, Schuberth's and Shoei's before finding out that some other (cheaper) brands were more comfortable to wear.
Had a few HJC's, as they fitted my head better than Arai's did and so were more comfortable. Important if you are wearing it 10 plus hours a day.
Only downside of the HJC,'s I had was that the liner was poorer quality, so some were well worn out by replacement time.
Main helmet now is a Nolan X70 ADV type. Great peripheral vision, plenty of room for goggles, inbuilt headset, and, importantly as the road to my house goes west, a peak as well as an internal sunvisor. The peak is adjustable and removable for long distance/ fast road riding.
