Fancy doing a test?
exportman
Has thanked: 8 times
Been thanked: 56 times
Re: Fancy doing a test?
Post by exportman »
47 DIdnt put the steering lock on, I would be braking with my front brake so left arm waiving and it appears Im not too good at CPR
Past my Bike test in 77 so I suppose not too bad
Has thanked: 2551 times
Been thanked: 2286 times
Bigjawa wrote: Sat Jan 07, 2023 8:20 pm 43. There are no trams in NI.
NI is closer to trams than I am. Nary a tram within 200 miles of the Duchy, nor any likelihood of getting any. FFS, they are closing all the bus routes.
Has thanked: 1507 times
Been thanked: 1412 times
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Post by Bigyin »
49/50
Only one I got wrong was the specific signage for tram drivers which I have never heard of or seen before so guessed. I was pissed off I got one wrong till I saw it was that one.
Ironically the only time I have had any experience of trams while riding bikes was on my DAS instructor assessment when the examiner took me into an area on the outskirts of Manchester with fucking tram lines everywhere on a torrential raining day as part of my “riding in built up/town” area
Has thanked: 1746 times
Been thanked: 2085 times
42 again..God dam it. Got the slowing down arm wave wrong, right arm not left. 🤷🏻‍♂️
westers151
Has thanked: 459 times
Been thanked: 235 times
Post by westers151 »
Yorick wrote: Sat Jan 07, 2023 6:59 pm Anyone want to explain the last few. Made no sense.
If I remember correctly, it was (in no particular order):
Tram lines are slippery
Let the bus pull out
A lorry turning left will swing out to the right to make sure the back axle doesn't mount the pavement
Bus stop - The paint will be slippery, so try and avoid.
Can't remember the last one.
westers151
I remember the last one, Trams have diamond shaped signs.
I only know that as Nottingham has trams.
Has thanked: 229 times
Been thanked: 575 times
48. Got the CatA licence power wrong, and the tram sign shape. "That'll do, pig".
Has thanked: 6191 times
Been thanked: 5087 times
Bigyin wrote: Sat Jan 07, 2023 11:22 pm 49/50
49 here. Licence/ engine power was my let down.
Used the same logic as someone else for the tram signs, excluding three left the one.
Hot_Air
Has thanked: 1373 times
Been thanked: 253 times
Post by Hot_Air »
Dodgy69 wrote: Sat Jan 07, 2023 11:57 pm Got the slowing down arm wave wrong, right arm not left. 🤷🏻‍♂️
Why does the right arm make the slowing down signal? It means taking your hand off the throttle to signal — meaning you could slow more rapidly than the following vehicle expects.
But if the left arm makes the slowing down signal, it gives considerably more (throttle) control over the rate of slowing, increasing safety. And as it’s movement that attracts attention, the left arm’s as conspicuous as the right.
I wonder if the arm signals originated with cyclists, not motorcyclists riding a large-capacity twin cylinder.
Has thanked: 836 times
Been thanked: 1238 times
Hot_Air wrote: Sun Jan 08, 2023 1:22 pm
Arm signals were for car drivers, the only difference is the left signal.
Been thanked: 6245 times
Yeah that ^^^.
Honestly, as someone who rides a bike without indicators quite often, I'm 50/50 on whether there's any point arm signalling! Even indicators seem to make little difference to what other drivers do, although it could be argued arm signals are actually more obvious.
Have any of you tried the hazard perception clips? I can't get better than 9/15 - if I try really hard I get 2!! As has been said before, I think it teaches you NOT to respond till it's too late.....
I'd love to see an example of how to get full marks.
I did hazard perception to get my licence, so obviously passed. Dunno if I still would.
To a certain extent its like GCSE maths. They teach you how to pass the test, not how to solve problems with maths.
Mussels wrote: Sun Jan 08, 2023 1:25 pm Arm signals were for car drivers, the only difference is the left signal.
New-fangled cars?
Yep, I thought exactly the same, the left arm would make it safer for sure. But, nothing surprises me any more. It also may indicate that your slowing and stopping on the left. 🤷🏻‍♂️
Has thanked: 2405 times
Been thanked: 3630 times
I got the answer to the same Q wrong - except that now I know what I'm supposed to do I will carry on doing the same as I've always done and use my left arm for the signal, because it makes absolute sense to do so. Dolloping along on a closed throttle (especially on a big V-twin) would make the plot borderline unstable. It's a silly idea and it can fuck right off.
mangocrazy wrote: Sun Jan 08, 2023 2:18 pmDolloping along on a closed throttle (especially on a big V-twin) would make the plot borderline unstable. It's a silly idea and it can fuck right off.
Ironically, it dates from when people dolloped along mainly on singles, but coped :)
Has thanked: 10265 times
Been thanked: 6886 times
I use arm signals all the time here on both bikes when turning left (your right). The sun is usually so strong that you can't see the indicators.
Especially on the Enduro bike coz we often turn into a dirt road which other road users won't expect as there'll be no obvious signage.
Druid
Has thanked: 276 times
Been thanked: 898 times
Post by Druid »
I can't remember the last time I used one of the Highway Code hand signals, probably on 13th February 1981 ;)
