Binstore
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Re: Binstore
Post by Screwdriver »
Yambo wrote: Tue Sep 27, 2022 1:23 pm
Ant wrote: Tue Sep 27, 2022 12:37 pm
The number one problem I have these days is everything takes me ages, I can't cut in a straight line.
Work on boats. A lot of the time you don't have to. :P
Carpentry: nearest half inch
Joinery: nearest 1/8th"
Cabinetry: nearest 1/32"
Boatbuilding: nearest boat...
Has thanked: 485 times
Been thanked: 1428 times
Re: Binstore
I could not saw in a straight line also. Most of my problem was sawing up and down the drawn line. Once i switched to a flatter angle i never have an issue with wiggles now.
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Re: Binstore
Post by Yambo »
Felix wrote: Tue Sep 27, 2022 6:12 pm I could not saw in a straight line also. Most of my problem was sawing up and down the drawn line. Once i switched to a flatter angle i never have an issue with wiggles now.
A flatter angle is much better for long straight cuts. The other trick with any cutting is to let the saw do the work. You have to move it backwards and forwards of course but you don't have to put in huge amounts of effort. That just makes the blade flex a bit and suddenly you're off line.
Ant
Has thanked: 39 times
Been thanked: 227 times
Re: Binstore
Post by Ant »
Screwdriver wrote: Tue Sep 27, 2022 4:54 pm
That reminds me of a conversation we were having with the guys at work, about builders squares.
