I'm about 5 ft 10, and when loading a bike with bars higher than clip-ons, your hands are up quite high and forward before you pull yourself up onto the van deck to finish off the loading process. I'm definitely going to get myself a step or a milk crate before I do it again. Perhaps your van has a lower deck height than the ones others are using? My old T4 has a load platform height of about 55cm above floor level.dern wrote: ↑Fri Jul 15, 2022 9:40 pmAre you all midgets?Yorick wrote: ↑Fri Jul 15, 2022 8:47 pmI used a milk crate. Then the engine pulled me upmangocrazy wrote: ↑Fri Jul 15, 2022 8:45 pm A small stool with its height midway between the floor and the van deck makes life much easier. But having two ramps is the gold standard...
Van or MPV to carry two track bikes
- Has thanked: 2405 times
- Been thanked: 3630 times
Re: Van or MPV to carry two track bikes
- dern
- Has thanked: 1016 times
- Been thanked: 1767 times
- Has thanked: 16210 times
- Been thanked: 3926 times
I used a little folding steppie - could keep it bungied to the side behind the rear wheel. Ded handymangocrazy wrote: ↑Fri Jul 15, 2022 9:54 pmI'm about 5 ft 10, and when loading a bike with bars higher than clip-ons, your hands are up quite high and forward before you pull yourself up onto the van deck to finish off the loading process. I'm definitely going to get myself a step or a milk crate before I do it again. Perhaps your van has a lower deck height than the ones others are using? My old T4 has a load platform height of about 55cm above floor level.
- dern
Did 300 miles in it today and very happy with it. Exceptionally easy to drive, comfortable and pretty economical.
- Has thanked: 2551 times
- Been thanked: 6247 times
Took me far too long to picture this. I was thinking "how does sitting down next to the van help?"mangocrazy wrote: ↑Fri Jul 15, 2022 8:45 pm A small stool with its height midway between the floor and the van deck makes life much easier. But having two ramps is the gold standard...
You forgot to factor in my hydraulic extendable arms...Mr. Dazzle wrote: ↑Sat Jul 16, 2022 8:28 pmTook me far too long to picture this. I was thinking "how does sitting down next to the van help?"mangocrazy wrote: ↑Fri Jul 15, 2022 8:45 pm A small stool with its height midway between the floor and the van deck makes life much easier. But having two ramps is the gold standard...
- dern
- dern
The fact that this goes in so easily means I’ll take it to Salisbury plain a more. It’s only an hour away but an hour there and back on the drz is about the least amount of fun you can have on two wheels imo.
- dern
Reorganised the van after the last track day and bolted the chocks to removable 18mm ply panels that slot between the guides. Moved all the hanging space so it didn’t get in the way as much. Should be able to easily carry both bikes and all the kit including gazebo now.
- dern
Sleeping solution for over night stays. Surprisingly comfortable.
- Has thanked: 6378 times
- Been thanked: 4755 times
Q? Do you roll up in a quilt to keep warm in the hammock? There's not much insulation underneath. Always thought they were nice when it's warm but vans can get quite cool at night.
- Has thanked: 1747 times
- Been thanked: 2085 times
I'd put a mattress underneath it if i was you.
- dern
I need to get something that attaches underneath as anything you sleep in or on compresses and so loses its insulation ability. I haven’t got anything yet, I wanted to prove it would fit and be comfortable before spending any more.Count Steer wrote: ↑Mon Sep 26, 2022 9:30 pm Q? Do you roll up in a quilt to keep warm in the hammock? There's not much insulation underneath. Always thought they were nice when it's warm but vans can get quite cool at night.
- Been thanked: 7530 times
Sleeping a van is ace, especially the bit when your breath condenses on the roof and drips back on your face.
The pair of us did a big tour of Scotland in an Escort van umpteen years ago. Couldn't be bothered with pitching the tent one night and tried to kip in the (uninsulated) van. It was like sleeping in the rain.KungFooBob wrote: ↑Tue Sep 27, 2022 7:37 am Sleeping a van is ace, especially the bit when your breath condenses on the roof and drips back on your face.
(Great holiday though, some of the popular bits were still pretty much off-grid...long-life milk and yesterdays papers ).
- dern
You definitely need some air circulation, that's for sure. I've installed one of those rotary vents in the roof of the van and that draws air from the lower vents. Would be grim without.
You guys must breathe heavily!! I've never had that issue in the/any van!!! I did always leave a window open a bit (do the same at home) so maybe that's it. But I always liked sleeping in the vanCount Steer wrote: ↑Tue Sep 27, 2022 7:50 amThe pair of us did a big tour of Scotland in an Escort van umpteen years ago. Couldn't be bothered with pitching the tent one night and tried to kip in the (uninsulated) van. It was like sleeping in the rain.KungFooBob wrote: ↑Tue Sep 27, 2022 7:37 am Sleeping a van is ace, especially the bit when your breath condenses on the roof and drips back on your face.
Mind you, I did also have a mattress (a topper really) tied to the side of the van - meant that the bike could be tied down to it, leaning to the side of the van. THen, bike out, mattress down and no rain dripping onto me from the roof
- dern
Fitted some security hook locks to the back doors and the side door over the break. Wish I'd waited until it was warmer as I'd have had more patience and would have read the somewhat ambiguous instructions more closely. Some of the measurements on the instructions were well off though and some rivets were missing. Due to the missing hardware I can't install the deadlocks on the front doors yet but these were the more important. Despite the difficulties and having to use some steelstik in places to tidy up I'm pretty happy with the results.
- Has thanked: 5451 times
- Been thanked: 13087 times
Nice job buddy. You're braver than me.
Was it worth the £80 you saved on fitting
- Has thanked: 836 times
- Been thanked: 1239 times
