The Level 1 / 2 are still valid for protective clothing.Hot_Air wrote: Sat May 30, 2020 12:43 pmWhile that's sound advice, it can be hard to follow because some manufacturers use labelling that's baffling. E.g. Dainese clobber often has a cardboard label - not stitched into the garment - that says "CE Cat. II". What does this mean? Is the clothing EN 13595 certified (to Level 1 or 2)? Or should it have an AAA - C rating by now?Mascagman wrote: Thu May 28, 2020 10:00 pm Make sure you are buying reputable jeans that are certified.
But my guess is that your label appiles to the body armour - the manufacturers can clear old stock - and still were, last time I looked, so these will have the old, slightly deceptive, CE labels for the armour only.
