Oddest/daftest thing you've ridden/driven?
- Has thanked: 469 times
- Been thanked: 308 times
Re: Oddest/daftest thing you've ridden/driven?
Probably the Saab 96 I co-owned with three friends in the late '70s. Two-stroke, with no oil reservoir, so you had to put a cup of oil in with each fill-up. Clapped-out engine, so clouds of blue smoke going uphill. Three-speed column change, with no synchromesh between 1st and 2nd.
- Has thanked: 6264 times
- Been thanked: 4614 times
Did it do that weird freewheel thing? I did wonder if/how they coped with that when they were racing/winning rallies.Scootabout wrote: ↑Mon Sep 06, 2021 9:40 pm Probably the Saab 96 I co-owned with three friends in the late '70s. Two-stroke, with no oil reservoir, so you had to put a cup of oil in with each fill-up. Clapped-out engine, so clouds of blue smoke going uphill. Three-speed column change, with no synchromesh between 1st and 2nd.
- Has thanked: 626 times
- Been thanked: 4072 times
I don't think the Saab had the free wheel on a closed throttle, Wartburgs did, I've raced one of those in Autocross, when you took your foot off the throttle it felt like it speeded up.Count Steer wrote: ↑Tue Sep 07, 2021 9:28 amDid it do that weird freewheel thing? I did wonder if/how they coped with that when they were racing/winning rallies.Scootabout wrote: ↑Mon Sep 06, 2021 9:40 pm Probably the Saab 96 I co-owned with three friends in the late '70s. Two-stroke, with no oil reservoir, so you had to put a cup of oil in with each fill-up. Clapped-out engine, so clouds of blue smoke going uphill. Three-speed column change, with no synchromesh between 1st and 2nd.
The 2T Saabs had it so that lubrication demand was reduced when travelling at speed with low throttle 'cos the lube is in the fuel etc...but, IIRC, they even retained it for a while on the 4T!Le_Fromage_Grande wrote: ↑Tue Sep 07, 2021 9:54 amI don't think the Saab had the free wheel on a closed throttle, Wartburgs did, I've raced one of those in Autocross, when you took your foot off the throttle it felt like it speeded up.Count Steer wrote: ↑Tue Sep 07, 2021 9:28 amDid it do that weird freewheel thing? I did wonder if/how they coped with that when they were racing/winning rallies.Scootabout wrote: ↑Mon Sep 06, 2021 9:40 pm Probably the Saab 96 I co-owned with three friends in the late '70s. Two-stroke, with no oil reservoir, so you had to put a cup of oil in with each fill-up. Clapped-out engine, so clouds of blue smoke going uphill. Three-speed column change, with no synchromesh between 1st and 2nd.
It must be really strange, I never feel quite in control when freewheeling on a (motor)bike. I can only imagine what it was like for drivers like Erik Carlsson when driving at the limits. Brakes must have been beefy!Le_Fromage_Grande wrote: ↑Tue Sep 07, 2021 9:54 amI don't think the Saab had the free wheel on a closed throttle, Wartburgs did, I've raced one of those in Autocross, when you took your foot off the throttle it felt like it speeded up.Count Steer wrote: ↑Tue Sep 07, 2021 9:28 amDid it do that weird freewheel thing? I did wonder if/how they coped with that when they were racing/winning rallies.Scootabout wrote: ↑Mon Sep 06, 2021 9:40 pm Probably the Saab 96 I co-owned with three friends in the late '70s. Two-stroke, with no oil reservoir, so you had to put a cup of oil in with each fill-up. Clapped-out engine, so clouds of blue smoke going uphill. Three-speed column change, with no synchromesh between 1st and 2nd.
They weren't on a Wartburg, it was about the same size as a Lada and had drums all round, on loose surfaces it went from nothing much to locked wheels very quickly, you had to cadence brake.Count Steer wrote: ↑Tue Sep 07, 2021 11:16 am
Fortunately it caught fire when we tried to weld a roll cage into it so we only raced it once.
I don't have a clear recollection of that, maybe because it was such an odd thing to drive anyway. A friend who knows about old cars told me it had a freewheel (or was it flywheel?) and that this meant it wasn't necessary to double de-clutch despite the lack of synchromesh. All that effort I could have saved if I'd known..Count Steer wrote: ↑Tue Sep 07, 2021 10:25 amThe 2T Saabs had it so that lubrication demand was reduced when travelling at speed with low throttle 'cos the lube is in the fuel etc...but, IIRC, they even retained it for a while on the 4T!Le_Fromage_Grande wrote: ↑Tue Sep 07, 2021 9:54 amI don't think the Saab had the free wheel on a closed throttle, Wartburgs did, I've raced one of those in Autocross, when you took your foot off the throttle it felt like it speeded up.Count Steer wrote: ↑Tue Sep 07, 2021 9:28 am
Incidentally we were told we shouldn't go over 50 in it. I later discovered a couple of my co-owners hadn't exactly stuck to that. Maybe that was why it had a tendency to break down. One occasion was on a trip from Oxford to London to see a Gilbert & Sullivan performance (yep, 'fraid so) when it conked out in West London, so we had to finish the journey on the tube from West Ruislip.
Dunno about the flywheel but it probably had synchro on everything but 1st gear. G&S? Some cracking tunes (better that than Gilbert O'Sullivan ).Scootabout wrote: ↑Tue Sep 07, 2021 9:25 pmI don't have a clear recollection of that, maybe because it was such an odd thing to drive anyway. A friend who knows about old cars told me it had a freewheel (or was it flywheel?) and that this meant it wasn't necessary to double de-clutch despite the lack of synchromesh. All that effort I could have saved if I'd known..Count Steer wrote: ↑Tue Sep 07, 2021 10:25 amThe 2T Saabs had it so that lubrication demand was reduced when travelling at speed with low throttle 'cos the lube is in the fuel etc...but, IIRC, they even retained it for a while on the 4T!Le_Fromage_Grande wrote: ↑Tue Sep 07, 2021 9:54 am
How did you get home?
- Has thanked: 2636 times
- Been thanked: 1498 times
Lucky you weren't headed to Penzance, then!Scootabout wrote: ↑Tue Sep 07, 2021 9:25 pm One occasion was on a trip from Oxford to London to see a Gilbert & Sullivan performance (yep, 'fraid so) when it conked out in West London, so we had to finish the journey on the tube from West Ruislip.
- Has thanked: 216 times
- Been thanked: 668 times
Yes, eary Saabs had a freewheel, as did some of the "Auntie" Rovers (75, 95, 110's).
And yes, it obviated the need for synchro
I don't remember for sure, but the car did have a habit of conking out, then reviving later - overheating, I suppose (?). So we may have retrieved it and driven it back.Count Steer wrote: ↑Tue Sep 07, 2021 10:32 pm
