Are heavy bikes bad?
- Has thanked: 5 times
- Been thanked: 215 times
Re: Are heavy bikes bad?
Even a lightweight feels excessively heavy when you've protected it from harm by throwing yourself underneath it.
Trust me. I know these things.
- Has thanked: 5945 times
- Been thanked: 4933 times
Almost all of themdemographic wrote: ↑Fri Apr 02, 2021 5:31 pmAhh, the police bikes had heavy gear stored in the rear panniers with some bikes, weaved over the road a bit.
Can't remember if it was the BMWs or the Pan Ams or both.
R80RT
Pans - certainly the 13
When it was the R80, I talked with a guy who was involved with a court case, from a Uni. He reckoned it was the rigid radio mounting. Civvie panniers and topbox flex, but the rigidity and weight set the rear swinging.
- Has thanked: 9688 times
- Been thanked: 9704 times
A friend of mine was in the black rats at the time of the new ST1300 and he threw his up the motorway after a terminal weave. He said the ST1100 was ok but the police gear badly effected the 13.demographic wrote: ↑Fri Apr 02, 2021 5:31 pmAhh, the police bikes had heavy gear stored in the rear panniers with some bikes, weaved over the road a bit.
- Has thanked: 7727 times
- Been thanked: 2401 times
I think Guzzi can claim that, they had their own wind tunnel in the 30s.
The BM likely had better analysis of the testing though.
- Has thanked: 2632 times
- Been thanked: 1498 times
Speed and a BMW RS in the same sentence?
- Has thanked: 16269 times
- Been thanked: 3747 times
I guess that after 6 months on a heavy 600 then 8 years riding a Blackbird as my first bikes, I found the TLs and ZX10r lighter than I should!!
I am not bothered about the weight of a bike - till I drop it!! I wouldn't have been able to pick up any of my bikes alone (except one - see next line!)
Apart from the 390 Duke being the most fun and laughs of any other bike, it was also the only bike I've owned that I could pick up!!
But, that won't stop me getting another big (heavy) bike in the future - just need to learn to manhandle it round hairpins!!
Zackerly!!! I never realised the Blackbird was 'that' heavy (had not bike experience really) and definitely didn't realise that it 'doesn't go round corners'Rockburner wrote: ↑Fri Apr 02, 2021 12:47 am Heavy bikes are just different, they can still be a load of fun when ridden the right way.
Fair point. If a 'BMW' then probably 'making safe progress' might be more appropriate?
- rodbargee
- Has thanked: 352 times
- Been thanked: 969 times
THE ZZR1400 is 220 KG which is heavy but it doesn't feel heavy, the KZ1300 felt really weighty by comparison and much more precarious. edit Just checked the KZ 1300 weighed 297 KG no fucking wonder it felt heavy
- Has thanked: 2915 times
- Been thanked: 1846 times
My ZH2 is a heavy lump (240kg wet), it is a bit of a pig paddling around at walking pace but once on the move it carries its weight well. I suspect on track it’d be tiring but it’s fine on the road.
- Has thanked: 2323 times
- Been thanked: 3374 times
Kawasaki's web site quotes the kerb weight (wet weight) as 261 kg. That's h e a v y (maan...)
- rodbargee
seems t'internet has a few all up weights for the zzrmangocrazy wrote: ↑Fri Apr 02, 2021 11:20 pmKawasaki's web site quotes the kerb weight (wet weight) as 261 kg. That's h e a v y (maan...)
- Has thanked: 15612 times
- Been thanked: 9850 times
For me a lack of steering lock/movement worsens the weight. If you have to shunt a bike about to park it and its got no lock its seems to get heavier with every step!
I had a K100RS years ago. Lovely bike on the open road but commuting on it was a nightmare. It was just so heavy and I could see gaps that I could easily fit through but the bikes weight killed its manoeuvrability as you couldn't shunt it back and forth to make the turn iyswim?
My NCX is no lightweight and sometimes that hampers it, but I can flick it about surprisingly well, although I often see gaps I'd have already been through on a scooter. But I love the NCX and it has the perfect riding position for me, so I'd forgive it most things.
- Has thanked: 626 times
- Been thanked: 4070 times
Why would you want a heavy bike if there was a lighter bike that did the same job, though heavy bikes can have shit suspension and still be okay as the ratio of sprung to unsprung weight is heavily in favour of the sprung.
Hmm, had the new to me 1200gs two up & panniered up for the first time yesterday and despite winding the peload right up & setting the tyre pressure the extra weight really made it wallow around the bends might have to get the scales out as max load is 219kg...though heavy bikes can have shit suspension and still be okay as the ratio of sprung to unsprung weight is heavily in favour of the sprung
BM is 256kg & guzzi is 235kg but that extra 20kg and higher up def seems more, would def prefer something sub 200kg
