Bothering at my TDR250
- Been thanked: 2499 times
Re: Bothering at my TDR250
The broken case will be a long time being fixed, I want to get the bike on the road first and then twitch at the pretty bits.
- Potter
- Has thanked: 2216 times
- Been thanked: 4610 times
TDR carbs are notorious for gunking up, I had the same when I put mine back together.
A single run through the ultrasonic cleaner didn't do it, they needed to be stripped and run through a warm chemical clean a few times, then they were ok - but you can't get decent chemicals these days, so even then they weren't perfect - the bike ran a lot better once it had had a few tanks of decent petrol through it, the super unleaded eventually cleaned out the bits that even the ultrasonic cleaner didn't get to.
TBF it has been languishing at the back of the workshop for several years. I've an ultrasonic cleaner and several tins of carb cleaner, and also an outboards carbs to do.
- Has thanked: 2318 times
- Been thanked: 3373 times
Not sure how similar TDR carbs are to LC/YPVS ones, but one area that can cause problems is a buildup of crap behind the 'brass balls'. The only way to clean that part out is by removing said balls and manually cleaning the little air passages. Or taking everything physically removeable off the carb(s), including brass balls, and giving it multiple passes in the ultrasonic bath. After that you've done as much as you can and it just needs to be used regularly.
