The Boeing 737 thread redux.
- Has thanked: 1507 times
- Been thanked: 1411 times
- Has thanked: 6187 times
- Been thanked: 5087 times
Re: The Boeing 737 thread redux.
Looks to be held in by a dozen or so M8s.
- Has thanked: 9819 times
- Been thanked: 10144 times
- wull
- Has thanked: 880 times
- Been thanked: 1544 times
Door found in garden, 2 lost phones found as well
Whilst we’re all still searching the garage for that 10mm socket
- Has thanked: 2550 times
- Been thanked: 6244 times
Just hope one of them wasn't a Nokia 3210, you wouldn't one of them coming down like a meteor.
- wull
Mr. Dazzle wrote: ↑Mon Jan 08, 2024 11:00 am Just hope one of them wasn't a Nokia 3210, you wouldn't one of them coming down like a meteor.
- Has thanked: 261 times
- Been thanked: 1265 times
https://www.bbc.co.uk/news/world-us-canada-67919436
Bolts in need of "additional tightening" have been found during inspections of Boeing 737 Max 9s, United Airlines has said.
Inspections began after a section of the fuselage fell from an Alaska Airlines 737 Max 9 on Friday.
United Airlines said "installation issues" relating to door plugs would be "remedied" before the aircraft type would return to service.
Some 171 planes of the same type remain grounded by the US regulator.
In its statement, United said: "Since we began preliminary inspections on Saturday, we have found instances that appear to relate to installation issues in the door plug - for example, bolts that needed additional tightening."
- Has thanked: 2402 times
- Been thanked: 3625 times
That is scary A F. Loose bolts in a door plug? Scarcely believable.
- wull
What concerns me is the Alaska airlines plane had 3 separate instances of a pressurisation warning going off hence the restriction of flight over water yet they never managed to find the fault, the culprit.
I’m guessing they performed a pressurisation test which would have helped them pin point where it was, you’d also think their attention would be drawn to the door plugs and at least check the door fixings, which they would have found were loose like the UA 737.
With it being relatively new, a few months old it’s clear it’s been a case of poor installation, bolts not tightened to spec and possibly a poor job of lock wire installation or whatever fail safe measures that are in place.
Scarcely? Try this:mangocrazy wrote: ↑Mon Jan 08, 2024 10:28 pmThat is scary A F. Loose bolts in a door plug? Scarcely believable.
Alaska Airlines says it has since found "some loose hardware" on some Max 9s.
So far as I can work out the bolts don't directly hold the door plug in. They hold it in the right place and a set of seats/pads bear the actual loads.
Still...bolts kinda need to be done up right?
Far from the first time this sort of thing has happened, and far from being a Boeing issue specifically. The most famous case being that BA windscreen, which is one of the classic school room examples in this area.
I suggest those of a nervous disposition don't think too hard about how you know if a bolt is done up You basically don't, the best you can ever get to robustly is that it's probably still tight
As mentioned earlier, incorrect undersized bolts were used.Mr. Dazzle wrote: ↑Tue Jan 09, 2024 7:38 amThe most famous case being that BA windscreen, which is one of the classic school room examples in this area.
Yes, and demonstrably there was ultimately nothing to stop that happening. Lots of things which were supposed to stop it, but in the end they all failed. The swiss cheese lined up.Horse wrote: ↑Tue Jan 09, 2024 8:31 amAs mentioned earlier, incorrect undersized bolts were used.Mr. Dazzle wrote: ↑Tue Jan 09, 2024 7:38 amThe most famous case being that BA windscreen, which is one of the classic school room examples in this area.
That's why it's a classic case study you get taught.
And the final slab of no-holes cheese would be to have a window fitted from the inside.Mr. Dazzle wrote: ↑Tue Jan 09, 2024 8:43 amYes, and demonstrably there was ultimately nothing to stop that happening. Lots of things which were supposed to stop it, but in the end they all failed. The swiss cheese lined up.Horse wrote: ↑Tue Jan 09, 2024 8:31 amAs mentioned earlier, incorrect undersized bolts were used.Mr. Dazzle wrote: ↑Tue Jan 09, 2024 7:38 amThe most famous case being that BA windscreen, which is one of the classic school room examples in this area.
In that particular case the dashboard was in the way
It's the same with these 737 'doors'. Ultimately the preferred design would be one it's impossible to open, but then it wouldn't be able to operate an emergency escape hatch in the versions which use it as such. The preferred design would actually be "just don't have the hole on planes without that exit", but that'd cost more and airlines might want to change their mind later.
- Has thanked: 836 times
- Been thanked: 1238 times
If a plane windscreen is going to detatch would it be better if it blows inward or outward?Horse wrote: ↑Tue Jan 09, 2024 10:29 amAnd the final slab of no-holes cheese would be to have a window fitted from the inside.Mr. Dazzle wrote: ↑Tue Jan 09, 2024 8:43 amYes, and demonstrably there was ultimately nothing to stop that happening. Lots of things which were supposed to stop it, but in the end they all failed. The swiss cheese lined up.
Pretty much anything on an airliner at altitude is gonna blow outwards, regardless of which way you'd prefer Air pressure inside is way higher than outside because the plane is err...pressurised. That's why wherever possible all the doors and windows are fitted from the inside, so they're forced into their frames and you don't need anything else to hold them in place.Mussels wrote: ↑Tue Jan 09, 2024 10:46 amIf a plane windscreen is going to detatch would it be better if it blows inward or outward?Horse wrote: ↑Tue Jan 09, 2024 10:29 amAnd the final slab of no-holes cheese would be to have a window fitted from the inside.Mr. Dazzle wrote: ↑Tue Jan 09, 2024 8:43 am
There are exceptions of course, as we've now seen!
Is the pressure always going to be higher inside, on a windscreen during takeoff and landing?Mr. Dazzle wrote: ↑Tue Jan 09, 2024 10:49 amPretty much anything on an airliner at altitude is gonna blow outwards, regardless of which way you'd prefer Air pressure inside is way higher than outside because the plane is err...pressurised. That's why wherever possible all the doors and windows are fitted from the inside, so they're forced into their frames and you don't need anything else to hold them in place.
No, but the forces associated with that are generally lower (excluding encounters with rogue pigeons). The internal pressurisation is generally the sizing case.
