Modern ICE vehicles are designed to burn oil
- Been thanked: 9505 times
Re: Modern ICE vehicles are designed to burn oil
IIRC the 'Campus' was the Gen 2 Clio that they made after the Gen 3 was released, for poor people.
- Has thanked: 1059 times
- Been thanked: 1646 times
So, no thoughts on piston ring tensions being reduced over the years, y'know like the OP mentioned?
Personally I've not had the chance to test various ones over the years but anecdotally can say my 05 Toyota van doesn't use a significant amount of oil and its over 250k miles.
If it was using a litre evsry thousand miles I'd think it was fucked.
- MrLongbeard
- Has thanked: 780 times
- Been thanked: 3224 times
- Has thanked: 2558 times
- Been thanked: 4168 times
Sir clearly hasn't watched the video. The first thing he did was to show unopened packs of genuine OE piston rings (Toyota) from different model years prior to doing his tests.
- Has thanked: 222 times
- Been thanked: 788 times
I is a poor pensioner....it cost me £450.....KungFooBob wrote: Sun Jun 22, 2025 8:40 pm IIRC the 'Campus' was the Gen 2 Clio that they made after the Gen 3 was released, for poor people.
It wouldn't surprise me at all of this is the case.demographic wrote: Sun Jun 22, 2025 10:59 pm So, no thoughts on piston ring tensions being reduced over the years, y'know like the OP mentioned?
The bit I would dispute is that it means engines burn loads more oil now. It is much more likely that OEMs have just got way better at calculating how tight they need to be. They've been optimised, like lots of things.
It might not only be the tension which has changed. The metal they're made from, the shape of them (i mean the cross section, not the fact they're circles
The one thing I DO know for sure about friction, wear and sealing is that it's waaaaayyy more complicated than you'd think.
- Has thanked: 8048 times
- Been thanked: 5698 times
Has anyone explained this yet?Rockburner wrote: Wed Jun 18, 2025 8:35 am Someone is going to have to explain to me how burning oil helps meet emissions standards....
It doesn't
Reducing frictional losses within the engine does however.
This is one of the reasons manufacturers like downsizing and turbocharging too. As my old boss used to say "make the engine spin less, make each spin do more".
- Has thanked: 10971 times
- Been thanked: 4004 times
Well - exactly - that's why I'm confused.Mr. Dazzle wrote: Mon Jun 23, 2025 9:21 am It doesn'tReducing frictional losses within the engine does however.
Err - If I'm reading that right... your boss is advocating things like US style big-bore V8s, or 500cc singles with heavy flywheels - one big explosion that does a lot, reproduced infrequently. Low revving, but big bangs? Is that right?? Or have I misunderstood (which I might easily have done)Mr. Dazzle wrote: Mon Jun 23, 2025 9:21 am This is one of the reasons manufacturers like downsizing and turbocharging too. As my old boss used to say "make the engine spin less, make each spin do more".
Sounds logical to me RB...that's how I read it too.Rockburner wrote: Mon Jun 23, 2025 12:04 pmWell - exactly - that's why I'm confused.Mr. Dazzle wrote: Mon Jun 23, 2025 9:21 am It doesn'tReducing frictional losses within the engine does however.
Maybe my old Panther was the future, not the past.
Engine mechanical losses broadly speaking come down to pumping and friction.
Spinning slower reduces both because some are related to speed of movement.
Spinning fewer times in total reduces both also, because you slides all the bits over each other for shorter distances and move less gas.
Smaller engines move less gas and have smaller bits sliding over each other. But they make less power too, which is one reason to turbo. The other is that turbochargers increase the overall compression ratio of the engine (remembering that it's the difference between the outside world and the cylinder which really matters) for a smaller increase in mechanical losses. Increasing compression ratio is pretty much.the gold standard way of increasing engine torque, power and efficiency.
- Has thanked: 2852 times
- Been thanked: 1611 times
All I can say is that it does the catalytic converter no good at all - middle kids Shitroen C3 is always flagging up cat faults, no doubt full of unburnt oil from the dodgy PureTech engine!Count Steer wrote: Mon Jun 23, 2025 7:38 amHas anyone explained this yet?Rockburner wrote: Wed Jun 18, 2025 8:35 am Someone is going to have to explain to me how burning oil helps meet emissions standards....![]()
- MrLongbeard
One watched half and listened to the other half of the video, I must have missed him stating they were OE rings and didn't see any thing on the packaging to clearly ID them as Toyota.mangocrazy wrote: Mon Jun 23, 2025 6:53 amSir clearly hasn't watched the video. The first thing he did was to show unopened packs of genuine OE piston rings (Toyota) from different model years prior to doing his tests.
Surely the amount of gas being moved is only related to the swept volume (essentially) : if all the other parts can be made (effectively) the same size (ie valves etc) then the amount of gas flowed can vary quite a bit for very little difference in the mechanical parts effects (ie, just make the piston/cylinder bigger - bigger bang for same friction (more or less).)Mr. Dazzle wrote: Mon Jun 23, 2025 1:22 pm Engine mechanical losses broadly speaking come down to pumping and friction.
Just re-watched the first few minutes of the vid and the rings are for Toyota models but are in fact made by Goetze, so not OEM. But Goetze manufacture 'to OEM standards' so that's all right...
Swept volume and volumetric efficiency remember. I.e. how much gas flows Vs the geometric swept volume. We deliberately reduce volumetric efficiency by strangling the incoming air...we throttle it.Rockburner wrote: Mon Jun 23, 2025 4:24 pm Surely the amount of gas being moved is only related to the swept volume (essentially)
Violent things, engines. Throttles, chokes, clutches
With the ring thing though the performance boost just comes from making the rings easier to drag up and down the cylinders. Gotta remember they travel quite literally miles over the surface of the cylinder on even a short drive.
- Has thanked: 7636 times
- Been thanked: 5937 times
A pedant notes that 'OEM' means 'company that manufactures components', not the one that assembles the vehicle.mangocrazy wrote: Mon Jun 23, 2025 4:37 pm Just re-watched the first few minutes of the vid and the rings are for Toyota models but are in fact made by Goetze, so not OEM. But Goetze manufacture 'to OEM standards' so that's all right...![]()
So, feasibly, Goetze might have made them for Toyota.
NB Mr. Dazzle says the definition has altered to mean, or encompass, the vehicle manufacturer. Pah. Youth of today, what do they know?
Tha naas worra meen...
Toyota would be the vehicle OEM, the ring company would be a Tier 1 or 2.
However once you've got the ring out of the engine and you start talking about it in depth you might reasonably say "The ring OEM"
Clear as mud. Or a smokey exhaust.
- MrLongbeard
No wonder I missed it.mangocrazy wrote: Mon Jun 23, 2025 4:37 pm Just re-watched the first few minutes of the vid and the rings are for Toyota models but are in fact made by Goetze, so not OEM. But Goetze manufacture 'to OEM standards' so that's all right...![]()
You have to, or at least I do, have to ask to what extent is this reduction in tension down to materials being downgraded by 3rd party suppliers to save money in addition to / instead of OEM materials specs.
