Condensation , perfect storm.
Tricky
Has thanked: 3043 times
Been thanked: 3309 times
Re: Condensation , perfect storm.
Post by Tricky »
Skub wrote: Wed Nov 27, 2024 2:01 pm
Tricky wrote: Wed Nov 27, 2024 2:00 pm
weeksy wrote: Sun Nov 24, 2024 1:55 pm Does that require the garage to be pretty much air tight though? Otherwise you're just sucking water out of constant airflow?
Doesn't on mine, as I have a typically draughty up and over door, and previously had the dampest garage known to man due to it's height relative to the garden immediately behind it, but since I've had the dehumidifier in there, never a hint of damp or corrosion on the bikes or tools. I just leave it going 24/7, and it pulls multiple litres of water out of the air every day
Do you run yours on the low setting,@Tricky ?
I'm embarrassed to say I can't remember- , I haven't changed it since I bought it and I never turn it off, I've got a feeling it's on high but I'll have a look and report back
Has thanked: 10959 times
Been thanked: 3995 times
My wooden, unlined workshop has the dehumidifier (a biggish one, but don't know the brand, might be an older Meaco?) running 24/7: well - it's on 24/7, but that means it's not actually "running" 24/7. Takes a few days, maybe a week or more to fill the jug up. We're right down south and only about 5 miles from the coast, so it's humid and not too cold. Mind you - it's also quite breezy here, which probably helps keep the moisture in the air lower than otherwise?
Since I have a radiator out in the garage,I was considering adding one of these to push the warm air about a bit better.They sit atop of the radiator. Anyone used one?
Tricky
Post by Tricky »
Tricky wrote: Wed Nov 27, 2024 2:05 pm
These are my settings-
it always seems to be on but as far as I can tell uses 3/5 of fuck-all electricity, and I never have damp worries in there any more so have never bothered changing the settings from what it's on in the pic, I just I clean the filter every month or so
Been thanked: 3504 times
We've got a dehumidifier we keep in the spare room for drying washing. Was gonna put it in the garage Friday morning, opened the door and all is dry. Magic init. 👍
Has thanked: 8034 times
Been thanked: 5693 times
Dodgy69 wrote: Sun Dec 01, 2024 9:47 am We've got a dehumidifier we keep in the spare room for drying washing. Was gonna put it in the garage Friday morning, opened the door and all is dry. Magic init. 👍
Reminds me of a bloke I worked with. Bought some tyre sealant gunk in the 80s (think it was called OK or something like that). Never got round to putting in his bike tyres. Put it on a shelf in the garage and used to touch it for luck before taking the bike out.
Never got a puncture in a bike tyre in all the time I knew him. :lol:
Tricky wrote: Wed Nov 27, 2024 2:26 pm Image
I bought a Meaco dehumidifier today to help with my laundry over winter (it's crap at ironing).
I'd never heard of the brand before yesterday, I'm glad to see your very-obviously-more-vintage one is still going strong!
Has thanked: 1059 times
Been thanked: 1646 times
After the 2005 (or thereabouts) Carlisle floods Chemdry (the .ain company doing the drying out of the houses) generally put dehumidifiers in the houses, drying out took ages.
After the 2015 floods they put the dehumidifiers in but also put pretty big fans i as well to move the air about. The homes dried out waaay faster.
I have no idea what relative the lecky bills were, I just worked in the houses and saw the difference.
Has thanked: 2287 times
Been thanked: 2673 times
demographic wrote: Sun Dec 01, 2024 6:21 pm After the 2005 (or thereabouts) Carlisle floods Chemdry (the .ain company doing the drying out of the houses) generally put dehumidifiers in the houses, drying out took ages.
That's SOP here after water pipe failures that flood homes. We've had it twice over the past 10 years or so. Just a couple of fans, but 6-8 dehumidifiers damn near the size of washing machines. First time was a hallway & bathroom, second was the bathroom, walk-in closet & hallway in the primary bedroom. Sounded like someone left a Harrier idling in the house for a week.
Brickie
Has thanked: 4 times
Been thanked: 24 times
Post by Brickie »
I refer to the original post / poster: I feel your pain. I had the same thing the same weekend, shiny new 4 jaw scroll chuck gone orange, milling bed, lathe ways and cross feed ditto, water on everything.
My take is that after 4 or 5 days and nights around or below zero (so everything in the shed bloody cold, but dry) the wind went westerly, temperatures rose to 13/14 degrees and it peed down solid. Any significant lump of metal (a motorcycle for example) stays cold for a few days and water condenses on the cold surface. (Also inside of window glass, everywhere). With horrible results. The shed though insulated and a bit draft tight is way too big and high for any dehummer, which work brilliantly in a smaller space
I cleaned the machines up in the same way: like you said, light machine oil and Scotcbrite pad, everything off the mill table, tool post stripped (all of which was doubly painful as I have stuff set up) etc. Some hand tools.....Then sprayed with ACF50. A few weeks later now and we've had a few cold warm cycles since, albeit not on the scale and its all immaculate, and also reminds me what clean and tidy machines look like. (In the interim I've been on another job so none of it has been touched since).
But: wipe it all off the chuck before you spin up the lathe, it sprays out in all directions and you are pretty much in the firing line. I discovered.
Interesting thread.
Has thanked: 3008 times
Been thanked: 1747 times
This just popped up on my Facebook page. A bloke pops a camphor tablet in his toolbox to prevent rusting.
https://www.facebook.com/share/r/14nD3JFnoeA/
Brickie wrote: Sun Dec 15, 2024 7:36 pm Then sprayed with ACF50....
Use Gibbs oil instead of ACF50
Brickie
Post by Brickie »
Best I can tell, they're much the same thing - aimed at the same market in any case. If I'd had any to hand I'd have used Duck oil, - the cheapest of the cheap. But: I looked around the shed for a suitable spray, grabbed the nearest to hand and used that.
I do have a 5 ltr can of wd40, but thought the acf50 more appropriate (for no scientific reason , but its more 'oily')
Why Gibbs? Or anything else?
Either way it works. I've enjoyed your monster truck thread, I have no desire to own one which makes it easier😉
Brickie wrote: Thu Dec 26, 2024 1:24 pm Best I can tell, they're much the same thing - aimed at the same market in any case. If I'd had any to hand I'd have used Duck oil, - the cheapest of the cheap. But: I looked around the shed for a suitable spray, grabbed the nearest to hand and used that.
Gibbs isn't oily to the touch. There's some guys in Colorado driving a 1940's Plymouth pickup that is bare metal, no rust thanks to Gibbs:
https://www.motortrend.com/news/airplan ... ly-radial/
ZRX61 wrote: Thu Dec 26, 2024 1:25 am
£106 for 2 12oz cans.... :shock:
After the prolonged subzero figures,which will have all metal parts well chilled,the temperatures are to rise this weekend,so stand by your dehumidifiers to preempt a wave of condensation in your garage/workshop.
lol not here they're not... still 3-4 tops.. that's not enough
Skub wrote: Thu Jan 09, 2025 9:57 am After the prolonged subzero figures,which will have all metal parts well chilled,the temperatures are to rise this weekend,so stand by your dehumidifiers to preempt a wave of condensation in your garage/workshop.
I've got a length of tubing arriving in the next day or two so that I can run my Meaco permanently and expel the collected water out of the shed, instead of it collecting in a tub that needs emptying virtually daily. I switched over to a newer Meaco a few weeks ago because it uses half the power of the old Fedder I had before, but the collection tub is only half the volume. :(
weeksy wrote: Thu Jan 09, 2025 10:04 am lol not here they're not... still 3-4 tops.. that's not enough
Saturday through Sunday there'll be a step,but yeah still freezing here.
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Yep I reckon Sunday might be a bad day for me , I've already started spraying oil on everything.
