- MrLongbeard
- Has thanked: 779 times
- Been thanked: 3222 times
Pffft even my 2018 tractor is 100% LED.
The little red indicator light on the oven, and also often on kettles, is also not an LED typically because it means you can wire them in parallel with the heaters and fire the full 240V through them without additional circuitry. I can't remember the exact tech they use though.Count Steer wrote: Wed May 28, 2025 1:53 pm I think oven bulbs work and, as far as I know, they're still incandescent.![]()
- Has thanked: 10967 times
- Been thanked: 3999 times
I can't remember the term... but IIRC it's a mis-use of the word: ie, they're a certain type of incandescant bulb, but the commen useage term is something like "sodium" (it's not), but the bulbs aren't "sodium" bulbs - it's just the term that has come into common useage. (that's the sort of thing that mildly irritates me)Mr. Dazzle wrote: Wed May 28, 2025 1:59 pmThe little red indicator light on the oven, and also often on kettles, is also not an LED typically because it means you can wire them in parallel with the heaters and fire the full 240V through them without additional circuitry. I can't remember the exact tech they use though.Count Steer wrote: Wed May 28, 2025 1:53 pm I think oven bulbs work and, as far as I know, they're still incandescent.![]()
They're a kind of Neon lamp, I remember now. Also used on power strips.
https://en.wikipedia.org/wiki/Neon_lamp ... _indicator
As above, it's cause you can put mains power through them without additional changes. But they're not incandescent.
That's it neons.Mr. Dazzle wrote: Wed May 28, 2025 2:16 pm They're a kind of Neon lamp, I remember now. Also used on power strips.
OK - so I learnt something new today - I didn't realise they were actually using a neon tube - I though they were just referred to as neons. cool.
- Has thanked: 7630 times
- Been thanked: 5934 times
Although neither was an original 'proper" one, I've just binned two of them because the wax had deteriorated.Rockburner wrote: Wed May 28, 2025 1:40 pm ... although the only use-case I can think of at the moment is Mathmos lava lamps which use both the heat and the light).
So, if that affects all of them, don't worry about ongoing lamp availability.
- MrLongbeard
Some of us are more frugal / environmentally conscious, I'd just buy some replacement waxHorse wrote: Wed May 28, 2025 2:49 pm Although neither was an original 'proper" one, I've just binned two of them because the wax had deteriorated.
You can buy replacement bottles.Horse wrote: Wed May 28, 2025 2:49 pmAlthough neither was an original 'proper" one, I've just binned two of them because the wax had deteriorated.Rockburner wrote: Wed May 28, 2025 1:40 pm ... although the only use-case I can think of at the moment is Mathmos lava lamps which use both the heat and the light).
- Has thanked: 8046 times
- Been thanked: 5697 times
Really?! Mine's been going for 20+ years* (not switched on permanently, obvsHorse wrote: Wed May 28, 2025 2:49 pmAlthough neither was an original 'proper" one, I've just binned two of them because the wax had deteriorated.Rockburner wrote: Wed May 28, 2025 1:40 pm ... although the only use-case I can think of at the moment is Mathmos lava lamps which use both the heat and the light).
Edit: Ah. Mine's a Mathmos, just realised Hosses weren't. Must read posts properly.
TBH it could be nearly double that. I can't really remember when we didn't have it.
It's inside a sealed glass container which is full of oil (or some other fluid). Good luck on replacing the wax!MrLongbeard wrote: Wed May 28, 2025 2:53 pmSome of us are more frugal / environmentally conscious, I'd just buy some replacement waxHorse wrote: Wed May 28, 2025 2:49 pm Although neither was an original 'proper" one, I've just binned two of them because the wax had deteriorated.
Some of us have more sense than to try
- MrLongbeard
There are kits and tutorial on how to go about it, the original wax got in there somehowHorse wrote: Wed May 28, 2025 4:55 pmIt's inside a sealed glass container which is full of oil (or some other fluid). Good luck on replacing the wax!MrLongbeard wrote: Wed May 28, 2025 2:53 pmSome of us are more frugal / environmentally conscious, I'd just buy some replacement waxHorse wrote: Wed May 28, 2025 2:49 pm Although neither was an original 'proper" one, I've just binned two of them because the wax had deteriorated.
Some of us have more sense than to try![]()
Yup, I'm sure there are people daft enough to botherMrLongbeard wrote: Wed May 28, 2025 5:16 pmThere are kits and tutorial on how to go about it, the original wax got in there somehowHorse wrote: Wed May 28, 2025 4:55 pmIt's inside a sealed glass container which is full of oil (or some other fluid). Good luck on replacing the wax!MrLongbeard wrote: Wed May 28, 2025 2:53 pm
Since I was intending to give them away, it's not something that I'd invest time and money to bother with.
But you raise a good point. Many things that could be so are not built to be repairable. With both a kettle and iron I've tried to carry out repairs. Either replacement parts weren't available, or only at high cost.
I suppose, using your 'it got in somehow' reasoning, it would be possible to replace the filament, or gas, in an incandescent lamp
They managed to do it more than 100 years ago, probably while wearing a top hat. Can't be that hard.
- MrLongbeard
A kit? probably not, a tutorial, I'd be concerned beyond reason if there weren't, as D points out above they were doing it long before the internet was a thing, before exotic gasses, clean rooms, H&S, t' good old days by eck.Horse wrote: Wed May 28, 2025 5:44 pm I suppose, using your 'it got in somehow' reasoning, it would be possible to replace the filament, or gas, in an incandescent lamp . Is there a kit and YouTube tutorial for that?
I though you lot were the make do and mend generation, scornful of fast fashion and todays throw away society, for shame old timer, for shame.
Edit; I was half way to having a look for said tutorial and it struck me, why would I want to replace like for like, why can't I replace the old and busted for new LED hotness, and just use the old lamp as a vessel for dodgy fuckery.........
My post was supposed to be sarcastic.
The thing which made lightbulbs a feasible technology was the development of proper manufacturing facilities, including clean working, the right gases, chemistry and controlled metallurgy. They're only bulbs at all because you need to keep the filament clean and surrounded by inert gas.
- Has thanked: 19600 times
- Been thanked: 4957 times
I know I'm being daft, but every time I read that description and it always makes me ask why they are so damned angry
You would be too if someone stuck 240V up your arse with no warning.
- MrLongbeard
A feasible, somewhat long life technology, I agree 100%, but that doesn't mean they can't be bodged together to get maximum life out of them;Mr. Dazzle wrote: Wed May 28, 2025 6:12 pm My post was supposed to be sarcastic.The thing which made lightbulbs a feasible technology was the development of proper manufacturing facilities, including clean working, the right gases, chemistry and controlled metallurgy. They're only bulbs at all because you need to keep the filament clean and surrounded by inert gas.
If anyone is desperate for incandescent household bulbs (rough service I think they got called for some reason) I think I've got a box of 'em somewhere. BiL was bemoaning the light quality from those new-fangled things so I got him a box full. Don't think he wanted them all. Haven't noticed them for some time though...they may have gone in the skip.
I'll have a proper rummage during garage/loft clearing.........Phase 9.
Guy who used to sit behind me at R-R, nearly 20 years ago come to think of it, used to have a box of incandescent bulb filaments in his desk. He loved to show people how brand new filaments can be stretched to arms length without breaking, whereas once they've been hot in the lightbulb they get extremely brittle as we all know.
I never asked where he got a box of 1000 light bulb filaments, which feels like a mistake in hindsight.
