Has thanked: 532 times
Been thanked: 7217 times
Compare the planform of the Vulcan B1 wing with the B2 :)
Has thanked: 5944 times
Been thanked: 4926 times
Rockburner wrote: Tue Oct 31, 2023 7:12 pm
Horse wrote: Tue Oct 31, 2023 3:49 pm Not totally random because a. there's a theme and, b. there's a question.
Back to the Concordes. You know the wing shape? A long, flowing, S curve, yes?
But viewed from above, it has kinks!
There are very good, but very complicated reasons. ;)
I'm sure there are reasons beyond a £multi-million practical joke :)
Gowon, give us a hint :D
NB my guess was to do with difference in air flow for the 'engine' and 'lift' parts of the wing.
Yes, I spent some time looking and wondering ...
Has thanked: 2609 times
Been thanked: 6012 times
They're even funkier if you look at them head on!
There's not gonna be a single reason, it's just the interaction of loads of (often conflicting) requirements. Not just aerodynamics, but also structural engineering, manufacturability etc.
But as above, loads of planes have 'kinked' wings, for loads of reasons.
Someone mentioned Vulcans? They have kinks...
Whereas B2s (and F22s and F35s) have only a very few angles, see how the tail is parallel to the wings and the front of the intakes/fuselage. There are only 2 or 3 'main angles' on the entire aircraft. That's for stealth reasons primarily.
Has thanked: 2560 times
Been thanked: 2182 times
Lots ok wing kinks, wing fences and sawtooth leading edges, on earlier generations of fast aircraft. Mostly to do with controlling spanwise flow, and ensuring the wingtips stall first.
I suspect that the latest stuff is designed using computer modelling to avoid the problems that kinks, wing fences and sawtooths were invented to cure.
The early B1 Vulcan's didn't have kinks. The B2 did.
Modern aircraft can be incredibly unstable, but it's not a problem because they fly by wire and a computer keeps everything in check.
Mr. Dazzle wrote: Tue Oct 31, 2023 8:49 pm They're even funkier if you look at them head on!
I tried getting as high as possible, then taking a series of shots from different points :)
Here's another
Has thanked: 15601 times
Been thanked: 9847 times
Has thanked: 776 times
Been thanked: 4514 times
Gawd blimey, it's the Pearly Kings of old Pyongyang Town.
kendo57
Has thanked: 241 times
Been thanked: 567 times
Post by kendo57 »
You wouldn't think it was possible to put that engine in that plane.
There must have been some crazy pilots in those days.
Has thanked: 6263 times
Been thanked: 4613 times
kendo57 wrote: Sat Nov 04, 2023 10:59 am You wouldn't think it was possible to put that engine in that plane.
Wouldn't want to set the tappets. :D
Has thanked: 10113 times
Been thanked: 6649 times
Last night walking into town
Yorick wrote: Tue Nov 07, 2023 10:03 am Last night walking into town
You look nothing like I expected! :wtf:
:lol:
Has thanked: 9677 times
Been thanked: 9700 times
Kawa-psychedelic :lol: 70s ads rock.
Off for an MRI scan shortly. The pre-scan instructions are mildy amusing for somebody as puerile as me...
1 - Not a problem. Well, it is a fucking problem, hence the MRI. :(
2 - Been beating Mrs G off with a shitty stick for the last two days. 8-)
3 - Is it acceptable to ask the nurse to pull the proffered finger and then force one out for comedy, as well as medical, reasons? :twisted:
Has thanked: 216 times
Been thanked: 666 times
gremlin wrote: Thu Nov 09, 2023 1:02 pm Off for an MRI scan shortly. The pre-scan instructions are mildy amusing for somebody as puerile as me...
No.3...GO FOR IT GREMMERS!!!!!
Lutin
Has thanked: 251 times
Been thanked: 323 times
Post by Lutin »
Visitor to our bird feeding tree a few minutes ago -
Sparrow Hawk 231110.jpg (309.98 KiB) Viewed 619 times
Has thanked: 1707 times
Been thanked: 2010 times
Has thanked: 579 times
Been thanked: 2288 times
Cheeky little ankle tap
