Classic Triumph Bonneville
Mr. Dazzle wrote: Tue Aug 03, 2021 9:17 am
JackyJoll wrote: Tue Aug 03, 2021 9:11 am For future reference:
The thing is, even if it's previous broken state it certainly felt fast. Even by today's standards it's by no means slow. Obviously it's not a patch on a big modern bike, but she'll outrun alot of stuff on the road. It must have felt like a rocket in 1969.
That'll be big power pulses and traction, my 45bhp Husqvarna 610 would out accelerate Fireblades coming out of slow corners, it was purely down to traction and riding position - two stroke MX bikes feel incredibly fast, but they're actually not making very much power, even the 500s are only about 60bhp.
As for the working on old engine thing - I find it immensely therapeutic compared to my day job in IT, it's nice to do something where you can see what you're doing and the effect it has, old engines are pretty simple to work on, which helps.
Has thanked: 2552 times
Been thanked: 6257 times
Further disassembly tonight....it got the middle bit out of the clutch using the right sized socket and a mallet. There are twenty tiny roller bearing bits in there and I still have all twenty!
The centre bit was still shitty and wobbly even after removal from the clutch basket, so clearly the issue was in there. So I split that bjt apart too....
I'd heard in loads of places that the rubbers are tight and a twat to get in/out. These ones just fell out on to floor. Probably the source of my wobble....I think all those gunky black surfaces are supposed to be bare metal, which would at least explain where the rubber went.
Has thanked: 261 times
Been thanked: 1266 times
Well done. The vanes on the spider aren’t broken, so you could try putting new rubbers in.
Been thanked: 7535 times
Looks like it's coated with oil that's been in an old skool diesel car for the last 20,000 miles.
Looks like it's got seriously hot at some point
Le_Fromage_Grande wrote: Tue Aug 03, 2021 9:50 pm Looks like it's got seriously hot at some point
Heat in the clutch would go for the plates first.
A whole new hub is about £100 - hardly bank breaking. A 7 plate upgrade is another ton.
Tempted just to spend the two hundred quid and a have nice new clutch. Especially as I've just got a big cash injection from the sale of my shares in an EV business - little bit ironic there :D
Has thanked: 218 times
Been thanked: 689 times
Do it.....it's only money....and a Triumph is more than a bike.
If you put the clutch back together as standard, you are likely to have slip problems in future. It’s a chronic fault that took them from 1957 to about 1982 to seriously address.
Lots of people say the 7 plate kit fixes that. The home-made cork and extra plate bodge worked for me, but it was a surprisingly big task.
There have been pattern replacement friction plates on the market that fixed the slippage too, but I couldn’t tell you which ones to buy from where.
Nidge
Has thanked: 705 times
Been thanked: 701 times
Post by Nidge »
I can only speak from my own experience but installing the 7 plate kit meant I didn't have to choose between slip or drag (of course it may have simply been my old plates were contaminated/knackered), but the biggest plus was that I could run with 650 springs rather than the stiffer 750 ones which significantly reduced the lever pull. Of course with all your performance mods you might want to put my old 750 springs in....
JackyJoll wrote: Wed Aug 04, 2021 10:50 am If you put the clutch back together as standard, you are likely to have slip problems in future. It’s a chronic fault that took them from 1957 to about 1982 to seriously address.
Barnett plates are good, but I've no idea if they make ones for this Triumph.
Has thanked: 15962 times
Been thanked: 10248 times
Mr. Dazzle wrote: Wed Aug 04, 2021 9:13 am A whole new hub is about £100 - hardly bank breaking. A 7 plate upgrade is another ton.
Deffo do it. £200 in the scheme of things is nothing and the bikes an appreciating classic. Be plain wrong not to tbh...
Nidge
Post by Nidge »
The only note of caution I would add is that sometimes the repro parts are not as good as slightly worn originals. Centre stands are good case in point but I’ve not had any experience with clutch baskets
Pattern clutch baskets for LCs are terrible, they wear in 2000 miles like a genuine one does in 40000 miles.
I cleaned up the steel clutch plates today. I wanted to clean them and check them for flatness before buying new parts in case I needed any replacements.
They were pretty good, although one was covered in pitting. Another has a tiny bit on the teeth but I think that will be OK. The sixth was like this all over, its also the one at the end of the stack....dunno if that's related. It was pitted on both sides though. They've also clearly been scrubbed at least once before.
I'm gonna get the Hyde 7 plate kit. That comes with 7 friction and 1 steel plate (and you reuse your original 6). I'll get another spare steel one too.
BTW the little IKEA biscuit tins are the perfect size for immersing Triumph clutch plates. I'm not sure how corrosion resistant this steel is so they're sat in engine oil now.
It’s mild steel, but a trace of rust isn’t the end of the World.
Oh yes and washed in petrol and had stronger springs installed and all these vain efforts.
Just ordered the 7 plate clutch from Norman Hyde :thumbsup:
BTW it was actually £179 :D
Just about to order a centre, new springs (I don't know what the old ones are, so getting three new T120 ones), new spring end caps/nuts, one extra steel clutch plate, a new thrust washer and new primary casing gasket.
So I'm actually spending £350 on upgrading the clutch. That's still less than one clutch assembly for my wife's Nissan Note :lol:
Think I'll get a new Venhill PTFE/Stainless cable too. Then there's no bloody excuse for the clutch being shit.
Has thanked: 2554 times
Been thanked: 2287 times
Mr. Dazzle wrote: Thu Aug 05, 2021 3:50 pm ......... Then there's no bloody excuse for the clutch being shit.
Always leave yourself an excuse. You may need it.
